  3. NodeManager
  4. How can I set parameter if there are multible instances of the sensor class?
3 Posts 2 Posters 2.2k Views 2 Watching
  • B
    B
    betonmoewe
    Hi (once again),
    I just try to create my own sensor class within NodeManager. I have Chirp sensors (https://www.tindie.com/products/miceuz/i2c-soil-moisture-sensor/) at home for monitoring the mositure of the soil of my plants.
    My current (minimal) implementation of the class works fine, but now. I have 3 problems:
    1.) The sensor produces 3 sensor readings (Capacitance,Light and Temperature). This creates 3 instances of my new Chirp class. If I try to set the class specific parameter (I would like to set an individual capacitance measurement offset because of the scattering of each individual sensor hardware) like in your description:
    SensorCHIRP* myCHIRP = (SensorCHIRP*)nodeManager.getSensor(nodeManager.registerSensor(SENSOR_CHIRP));
    myCHIRP->setMoistureOffset(330);
    myCHIRP->setMoistureRange(520);
    myCHIRP->setRreturnMoistureNormalized(true);
    It sets the parameter only in the last instance of the class, but this is not the instance for moisture (ok, I can rearrange the initialization, but maybe there is a better way).
    The only way I found, is to substract 2 from the sensorID:
    (SensorCHIRP*)nodeManager.getSensor(nodeManager.registerSensor(SENSOR_CHIRP)-2);
    because it is the first created instance of the class.
    Maybe my last c++ project was tooooooo long ago ....
    2.) that means: if I want to set (as an example) the setTrackLastValue parameter, I have to do this for all 3 instances?
    3.) every instance of the Chirp class does its own sensor initialization. It there a way to do this only once?
    If my Chirp class have no further errors (and a way to deal with the above), you can include this class into your package, if you wish ...
    Best regards and THANKS for this really helpfull NodeManager library
    Frank (Betonmowew)
    B 1 Reply Last reply
    • B betonmoewe
      Hi (once again),
      Frank (Betonmowew)
      B
      B
      betonmoewe
      wrote on last edited by betonmoewe
      ok ok ... I found a way: the word static is the key !
      I have declared all my needed variables as static and do a global initialization in NodeManager.cpp just in front of the code for my Chirp methods. The -2 is not necessary any more and with a helper variable, (address of the sensor) there is only one sensor initialization/reset.
      Now, only question 2 is open ...
      • U
        U
        user2684
        Hi, the workaround of using a static variable is ok but of course would not necessarily work well in any situation but I'm glad you got it working somehow :).
        However you're right, this is a known issue in NodeManager. https://github.com/mysensors/NodeManager/issues/176 should tell you why and answer your question #2. The solution unfortunately is not that easy since would require re-thinking the way sensors are mapped to child IDs. Work is in progress though :) (https://github.com/mysensors/NodeManager/issues/198)
