  3. Sensor causing a gateway reboot
5 Posts 2 Posters 1.8k Views 2 Watching
  • ThucarT
    ThucarT
    Thucar
    I'm building a sensor for my honeybee hive. For some reason quite often when I reboot the sensor, the gateway gets stuck in a reboot loop. When I cut the power from the sensor, then the gateway boots up without issues. I have 8 other misc sensors working fine with that gateway.
    Some other information that might be useful:
    Using MysBootloader for OTA (Pro Mini 8MHz 3.3v)
    The sensor is temperature/humidity sensor. Using 5x DS18B20 and 1x DHT22
    Powering the Pro mini directly via the VCC pin from a 18650 battery. (4.2v - 3.6v)
    Gateway log
    Sensor code
    Am I missing something or doing something no-no in the code?
    Controller: Node-Red
    Gateway: SerialGateway & GSMMQTTGateway
    MySensors: 2.2.0
    • ThucarT
      ThucarT
      Thucar
      Oh, forgot. The Gateway is simple serial gateway running on Nano.
      MySensors: 2.2.0
      • tbowmoT
        tbowmoT
        tbowmo
        One thing that I notice, is that the gateway reports as being a repeaternode, which it shouldn't.
        Could you post the code that you used for your gateway as well?
        / Thomas
        • ThucarT
          ThucarT
          Thucar
          wrote on last edited by Thucar
          The gateway code is unmodified Serial Gateway example. No inclusion mode and no traffic lights. As simple as it gets.
          * The ArduinoGateway prints data received from sensors on the serial link.
          * The gateway accepts input on seral which will be sent out on radio network.
          * The GW code is designed for Arduino Nano 328p / 16MHz
          * Wire connections (OPTIONAL):
          * - Inclusion button should be connected between digital pin 3 and GND
          * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
          * LEDs (OPTIONAL):
          * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
          // Enable serial gateway
          #define MY_GATEWAY_SERIAL
          // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
          #if F_CPU == 8000000L
          #define MY_BAUD_RATE 38400
          // Enable inclusion mode
          // Set blinking period
          // Flash leds on rx/tx/err
          MySensors: 2.2.0
          • ThucarT
            ThucarT
            Thucar
            Ok, so I replaced the 3.3V 8MHz Pro Mini with a 5V 16MHz one. Still running it from that same power source, so currently supplying 4.1V to the VCC. And no more gateway reboots.
            Both Pro Minis have the MysBootloader on them, no other component or code changes. So I guess the next thing is to wire up another 3.3V Mini, flash the bootloader on it and see how it goes.
            MySensors: 2.2.0
