  3. Transmitting only battery status
3 Posts 2 Posters 1.3k Views 1 Watching
  • B Offline
    B Offline
    bengele
    wrote on last edited by bengele
    I am using the Serial Gateway example and the example door sensor from the sensor_api page. It looks like I have a good connection but the only thing that gets sent to the gateway is the battery level.
    Output from serial monitor
    Gateway
    0;0;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0:
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    Sensor
    sensor started, id 255
    req node id
    send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,st=ok:
    req node id
    req node id
    req node id
    req node id
    req node id
    req node id
    Any ideas on why it is not sending the door open message?
    • D Offline
      daulagari
      Looking at your log it looks like the node is requesting a Node ID from the gateway but the gateway is not providing it meaning the sensor will execute the normal code.
      255;255;3;0;3;
      See http://www.mysensors.org/build/serial_api, this is an internal message of the type I_ID_REQUEST.
      The Node ID is normally provided by a controller.
      • B Offline
        B Offline
        bengele
        Thanks for the reply. Not sure how I translated that to the battery level. That is what I get for trying to figure it out late at night.
