  3. Smartmeters inverted data software corrected?
6 Posts 4 Posters 2.7k Views 4 Watching
  • YFandSY
    YFandSY
    YFandS
    Re: Smartmeter sensors
    Above post was rather old, so the reply option suggested I create a new topic in reference.
    As of october 3th 2017 2 smartmeters are installed, gas (Honeywell BK GYEteB) and electricity (XS 210 ESMR5).
    As a domotic enthousiast of course I want to monitor the output. I prefer Mysensors with Domoticz. So I looked around and found the solution in the topic above. But almost every solution mention a hardware component to invert the signal, 1 -> 0, 0 -> 1. Why is there not a software solution ? A simple XOR would suffice I think?????
    Can somebody tell me what the pitfall is...
    Frank
    • BartEB
      BartEB
      BartE
      wrote on last edited by BartE
      @YFandS for some reason these smartmeters use a inverted implementation of the RS232 serial protocol. While Arduino's etc. use the standardized RS232 implementation.
      As far is i known the UART (the "chip" doing the RSR232 decoding fro Arduino) does not supports inverted mode.
      So yes a signal inverter is needed..
      • tbowmoT
        tbowmoT
        tbowmo
        What about implementing it with a software uart? Then you can flip the bits in the software instead. (if I remember right they use a baudrate of 9600, so should be doable in software.
        • YFandSY
          YFandSY
          YFandS
          Thanks guys, As I now understand from BartE the decoding must be first done by the Arduino RS232 hardware. In my opinion I would 'just' receive the inverted bits (via Arduino RS232 Hardware) and invert them later. But I guess that's not the way to do it. :-(
          On the other hand the sketch used in the above link uses the AltSoftSerial library, so the suggestion made by tbowmo might be an option.
          Regards
          Frank
          • YFandSY
            YFandSY
            YFandS
            Came across this link http://domoticx.com/p1-poort-slimme-meter-data-naar-domoticz-esp8266/ it uses the SoftwareSerial library (not the one provided with Arduino !!)
            and yes it can invert the P1 signals. Unfortunately it uses ESP8266 to send data to Domoticz.
            I will see if I can convert the sketch to mysensors.
            Frank
              Esp8266 can still be used as gateway with on board sensors, just in case...
