  3. What did you build today (Pictures) ?
1.1k Posts 105 Posters 752.4k Views 98 Watching
  • dbemowskD
    dbemowskD
    Today's progress on the new switch consists of finishing the basic 3D model of the wall switch plate and working on some of the programming.
    For the wall plate design I do not have buttons as of yet, but the main part of the wall plate turned out good. I did the initial print in yellow because I am out of white at the moment. I am still trying to figure out the best way of printing it. In the video, you will see that the tabs are looking a bit rough. That is because I printed this one face down with supports for the tabs. If I decide to print them that way, it won't be bad because the tabs will be hidden under the wall plate cover. I will try printing them both ways to see which comes out better.
    For the programming, I created a couple bitmap icons and did a sample of those icons animated on the screen. The animations toggle back and forth and each runs for about 10 seconds. One bitmap is a rain drop, and the other is a snow flake. The idea is to use these to display weather conditions. I will probably design some clouds and a sun as well and have 4 possible animated weather displays.
    https://youtu.be/icre7xeprJI
    dbemowskD 1 Reply Last reply
    • NeverDieN NeverDie
      @boozz What are those 3 pin male connectors called?
      B
      B
      boozz
      @neverdie
      Yes these are 'molex' pcb connectors.
      An ebay alternative can be found at: Ebay shop cayin34
      • andrewA andrew
        one step further...
        ISP works, FTDI works, test code works, and looks like a genuine board :)
        now comes the hard part :D
        mtiutiuM
        mtiutiuM
        mtiutiu
        @andrew
        Where did you buy that green thing that sits on your work desk (it has some kind of ruler on it and squares). I don't know how it's called but I keep seeing it and I think I want one too. Thanks.
        andrewA gohanG 2 Replies Last reply
        • scalzS
          scalzS
          wrote on last edited by scalz
          #224
          @mtiutiu
          here I use esd safe mate etc when I do electronics (maybe too much paranoid.. and I don't know if there are with ruler), but these green mates are nice for tinkering, sure.
          if you google "cutting mate ruler" you'll find what you want
          • mtiutiuM mtiutiu
            @andrew
            andrewA
            andrewA
            andrew
            @mtiutiu just search for "cutting mat"
            • mtiutiuM mtiutiu
              @andrew
              @mtiutiu I got one of those blue silicon heat resistant mats with magnets so I can use the heat gun over it
              NeverDieN 1 Reply Last reply
                NeverDieN
                NeverDieN
                #227
                @gohan said in What did you build today (Pictures) ?:
                Do you have a link for that? Sounds very useful, especially when soldering things that might get very hot (though maybe I won't need it as much after I get the PCB holder).
                gohanG 1 Reply Last reply
                  #228
                  Trying to get a programmer for Sigfox/LoRaWAN devices to work for a non-MySensors project. (the programmer is from a nice Dutch company called 1M2M)
                  I like the Swedish-branded usb cable :)
                  • andrewA
                    andrewA
                    andrew
                    from my previous posts the PCB CNC milling came out as an interesting topic. maybe another method, working with photo resist PCBs and UV exposure, could be interesting for others. so, for those, who are interested in this, I just documented my solution (not the technique, but my tool) recently.
                    YveauxY 1 Reply Last reply
                      @neverdie they get on sale quite often on banggood but are also available on aliexpress: usually they are on 3 sizes and the biggest has some slots with a lid and others with magnets; there are also some small slots with numbers to keep track of the screws you are disassembling and a ruler at the bottom
                      • andrewA andrew
                        YveauxY
                        YveauxY
                        #231
                        @andrew nice! Read about it on hackaday today!
                        andrewA 1 Reply Last reply
                        • YveauxY Yveaux
                          andrewA
                          andrewA
                          andrew
                          wrote on last edited by andrew
                          #232
                          @yveaux thanks :) I finally managed to document it, there are some other stuff in the queue as well ;)
                          • dbemowskD dbemowsk
                            @sincze I should have known. All you had to say was memory and it would have made sense, or should I say sincze. LOL. With needing to hold states of 900 LEDs, I am going to guess that they are WS2812 LED strips.
                            sinczeS
                            sinczeS
                            sincze
                            MySensors Evangelist
                            @dbemowsk You are correct ;-) , well at least I thought I bought those but got: SK6812 RGBW (comparable to ws2812b). The pretty work just fine.
                              dbemowskD
                              dbemowskD
                              Some more sample display layouts.
                                Reverse-engineering a bluetooth battery monitor from Conrad.
                                The battery monitor has an Android and iOS app that displays voltage, but I wanted to read the data from an ESP32 (lower right corner of the pic).
                                This hack is probably worth a thread on its own, will add that later.
                                  More info on my ble hack: https://forum.mysensors.org/topic/8773/reverse-engineering-a-gl10-ble-bluetooth-battery-monitor-using-esp32
                                  • bjacobseB
                                    bjacobseB
                                    bjacobse
                                    Maybe a bit off-topic, but I use octoprint as server for my 3d printer, and use Domoticz as homeautomation server. I want to know when 3D print is done, so I created a node-red flow that connects this via MQTT, so domotics shows print progress...
                                    https://www.domoticz.com/forum/viewtopic.php?f=21&t=14021&p=162935#p162935
                                    • bjacobseB bjacobse
                                      dbemowskD
                                      dbemowskD
                                      @bjacobse I literally just started using octoprint about a week ago. I am curious how you get the progress data into node-red to send over MQTT?
                                      bjacobseB 1 Reply Last reply
                                        Well.. I didn't build it as it was already assembled, but I did had to some soldering to put it together and also did a mod to the case by adding 2 extra binding posts to the front. Btw it is a DPS5015 with a BT module that I fitted behind the screen
                                          bjacobseB
                                          bjacobseB
                                          bjacobse
                                          wrote on last edited by bjacobse
                                          #240
                                          @dbemowsk
                                          hi did you check the link I supplied? I rather discuss the topic in domoticz forum, as it could benefit other Domoticz/octoprint userrs
                                          but I have installed on the octoprint the mqtt plugin, as my domoticz is also running both mosquitto and node-red, I specify the ip adress for domoticz in setup the broker in octoprint plugin mqtt,
