  3. What did you build today (Pictures) ?
1.1k Posts 105 Posters 752.1k Views 98 Watching
  • Nca78N
    Nca78N
    Today I soldered a tiny MYSX board to recycle my EasyPCBs in door sensors as compact as possible. I can also use the "vertical" CR2032 holders I had no use for and make some space in my drawers.
    It can use a normal or a NO/NC reed switch (for SMD allergies :D ) or a SMD ultra low power hall sensor and it has a footprint for a reserve capacitor to support the CR2032.
    I guess this board will be of interest for @sundberg84 ;)
    2_1516276346915_IMAG2152_1.jpg 1_1516276346913_IMAG2151_1.jpg 0_1516276346910_IMAG2150.jpg
    PS: sorry for the ugly soldering, my old 936 clone soldering station is in "zombie" mode and it's all I have until the new soldering iron arrives.
    • Nca78N
      Nca78N
      wrote on last edited by Nca78
      #322
      Not related to MySensors but I also assembled a first version of a battery powered led light, it's small and cheap and I will assemble a bunch to put around my home when there are some power cuts in evening/night. I'm using 3020 leds and they emit a lot of light for their small size, even with low current so I expect to get around 2 hours of battery life with the cheap aliexpress 16340 batteries, and way more than needed with the 18650 cells salvaged from my old laptop battery.
      My first board with a li-ion charger and it is working well, now I'm waiting for the battery protection ics (cheap DW01 from AliExpress) to arrive as my batteries are not protected.
      2_1516277652209_IMAG2158.jpg 1_1516277652209_IMAG2159.jpg 0_1516277652206_IMAG2161.jpg
      NeverDieN dbemowskD 3 Replies Last reply
      • Nca78N Nca78
        NeverDieN
        NeverDieN
        @nca78 Which 3020's did you get?
        Nca78N 1 Reply Last reply
        • NeverDieN NeverDie
          Nca78N
          Nca78N
          @neverdie said in What did you build today (Pictures) ?:
          Cheap ones from AliExpress, not disappointed especially for the low price. I'll see in the long run how they behave.
          https://www.aliexpress.com/item/100pcs-Light-LED-3020-Warm-White-SMD-Diode/32325994533.html
          • Nca78N Nca78
            dbemowskD
            dbemowskD
            @nca78 I have some similar looking panels that I had salvaged from some old document cameras. I was planning on building some MySensorized walkway lights in my hall Might be something good to make in the event of a power outage.
            • Nca78N Nca78
              dbemowskD
              dbemowskD
              This post is deleted!
              dbemowskD 1 Reply Last reply
              • dbemowskD dbemowsk
                [[topic:post-is-deleted]]
                dbemowskD
                dbemowskD
                • sundberg84S
                  Some more testings on my Logger... I want it to work great before moving on so alot of testing is needed. Why not do it on node #1 (note the old rev om EasyPCB).
                  • sundberg84S
                    Completely unrelated but a impossible project for me it seems...
                    Im building a wifi "babywatch" in a USB stick.
                    It sends sounds to a app/software which is build to run in the background. This to be able to game or watch video with headphones and still know if you have a angry child.
                    So pretty much Mic -> Amp -> ADC -> Esp8266 -> Wifi -> Software/App.
                    This seems impossible to do with all the interference. Everything works now (Rev1) but im now on Rev 6+ or something and I cant get rid of the noice in the Audio.
                    Seperate power supply + ground for analog and digital side but It seems like the Esp8266 inserts to much noice.
                    Well, it was a great idea but hard to accomplish.
                    nagelcN YveauxY 2 Replies Last reply
                    • sundberg84S sundberg84
                      nagelcN
                      nagelcN
                      nagelc
                      @sundberg84
                      I really like that case. Do you have a link where you purchased it?
                        YveauxY
                        YveauxY
                        @sundberg84 analog and esp8266 also beat me. Tried to play some music from an ESP8266 but result was barely usable. I switched to dac+amp connected via i2s which works fine.
                        Maybe you could try with a digital i2s microphone...
                        • YveauxY Yveaux
                          #332
                          @yveaux - thanks!!! A new hope ;) I will.
                          @nagelc - I use this: https://www.mouser.se/productdetail/789-p3a-220805s but note, there are 4 different variants. WIth and without opening for USB connector and other stuff. I can send you the footprint for the PCB if you wants.
                          nagelcN 1 Reply Last reply
                            nagelcN
                            nagelcN
                            nagelc
                            @sundberg84 Thanks. Looks like that company has several interesting enclosure shapes. Someday I might get a project complete enough that I will want to put it in an enclosure : )
                            • dbemowskD
                              dbemowskD
                              The nice thing about owning a 3D printer is that I don't have to buy enclosures any more. I just have to buy rolls of plastic. The sky is the limit when you have a 3D printer. I do like that enclosure though.
                                Nca78N
                                Nca78N
                                @dbemowsk said in What did you build today (Pictures) ?:
                                Can't agree more, made a quick box for the lights with "crystal" PLA. You need a lot of imagination to believe it's crystal, but it's nice for a light enclosure as it acts as diffuser.
                                • Nca78N Nca78
                                  dbemowskD
                                  dbemowskD
                                  @nca78 Nice. That would probably look cool in any translucent colored plastic. I have worked with clear, like this, red and green. Haven't used them for lighted enclosures though.
                                    Today I'm trying out Thingsboard, which sort of is a controller, but on steroids.
                                    So far, it seems quite capable, but I have a lot of learning to do. My first step was to integrate it with Sigfox, which seems to work.
                                    McQueen
                                    Hey @mfalkvidd were you able to get mysensors nodes to send data to thingsboard? If so, I'm interested to know how you did that. Wondering if thingsboard can be configured as a controller for mysensors. Thanks!
                                    • M McQueen
                                      @mcqueen I have not tried, and I have no plans to try. Sorry.
                                      M 1 Reply Last reply
                                        McQueen
                                        @mfalkvidd no problem, thanks
                                        • rozpruwaczR
                                          rozpruwaczR
                                          rozpruwacz
                                          So today I created a simple python script to bridge serial gateway with mqtt bus on my RPI:
                                          https://github.com/mczerski/MySensorsSerial2MQTT
                                          This is because I already use spi for nrf24 module mounted on a custom pcb so there is no room for another spi device.
