  3. What did you build today (Pictures) ?
1.1k Posts 105 Posters 780.5k Views 98 Watching
  • rozpruwaczR
    rozpruwaczR
    rozpruwacz
    @Yveaux I get it from the polish suplier (https://hurtowniaimport.pl/291-bb1-uchwyt-magnetyczny-samochodowy-do-telefonu-gps.html) but if you google for "magnetic phone holder 360" You wil get similar mounts.
    • rozpruwaczR
      rozpruwaczR
      rozpruwacz
      I found one on aliexpress: https://pl.aliexpress.com/item/GETIHU-360-Car-Magnetic-Phone-Holder-For-Phone-in-Car-Mount-Magnet-Universial-Mobile-Cell-Phone/32879720933.html?spm=a2g17.search0104.3.244.101611774LZhtS&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10151_10065_10344_10068_10342_10343_10340_10341_10696_10084_10083_10618_10304_10307_10820_10821_10301_10843_10059_100031_10103_10624_10623_10622_10621_10620,searchweb201603_1,ppcSwitch_2&algo_expid=17a12b56-7a20-49df-aab1-45b5519746f0-29&algo_pvid=17a12b56-7a20-49df-aab1-45b5519746f0&priceBeautifyAB=0
        Today I soldered the Velleman EDU09 oscilloscope kit. The kit is quite cheap (~50 EUR in local store). The specs aren't impressive (max 200kHz and min 100mV/division) but hopefully it can help me learn how to use a scope before I buy a real one.
        alexsh1A 1 Reply Last reply
        • tbowmoT
          tbowmoT
          tbowmo
          Not at all mysensors related, but I have been busy building a bartop mame cabinet the last week or so.. Still mis a couple of details, but it is in a "playable" state right now.
          The setup is using an old 19" lcd monitor that I had in surplus with a RPI-3B on the back, a couple of cheap Chinese arcade controllers, a partly homebuild audio hat for the rpi (adafruit i2s 3W amplifiers), and a switchmode capable of 5V @8A (if I remember right), and 12V @3A. So I have power for the marque lighting as well..
          Only game available right now is Bubble Bobble, and the kids loves it (as seen in the video linked to below).
          https://youtu.be/h_6FebqefcQ
          • bjacobseB
            bjacobseB
            bjacobse
            @tbowmo
            Quite impressive arcade game
            • NeverDieN
              NeverDieN
              For this project box that I'm making (actually printing it as I type this), I found an easy way to add ventilation: use a hex infill and turn off the upper and bottom layers.
              As you can see, it can still have standoffs for screwing down a PCB and for securing a lid.
              • NeverDieN
                NeverDieN
                Here's the finished unit:
                What it does is completely eliminate the audible PWM noise from the fan on the Prusa I3 MK3. Now it can run practically silent. :)
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @mfalkvidd Just a tip. You may be better of buying this one:
                  https://www.amazon.co.uk/KKmoon-Portable-Digital-Oscilloscope-Interface/dp/B07C4RTXF6/ref=sr_1_3?ie=UTF8&qid=1534094879&sr=8-3&keywords=oscilloscope+portable
                  Much better spec and the price is the same. AND you can save tons of time as it does not require soldering.
                  • tbowmoT tbowmo
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @tbowmo Now I want to build one :-)))
                    tbowmoT 1 Reply Last reply
                    • alexsh1A alexsh1
                      @alexsh1 thanks for the tip. I guess I'll have a hard time getting my money and time back now that the kit is soldered, but it might be interesting for someone else.
                      • alexsh1A alexsh1
                        tbowmoT
                        tbowmoT
                        tbowmo
                        @alexsh1
                        I used this as a base for my own build: https://www.instructables.com/id/2-Player-Bartop-Arcade-Machine-Powered-by-Pi/
                        • kalinaK
                          kalinaK
                          kalina
                          LED backlight for my CNC machine....
                            #613
                            Today I've been trying to get a MS5803_05BA sensor working. This is a pressure sensor that is commonly used in dive computers.
                            The sensor is tiny and handles 0-5 bar. So far I've not been able to communicate with it though. I use i2c and have tried two libraries, but none of them work (or maybe I killed the sensor when I soldered the cable).
                              At first I had a 25m cable. Turns out i2c isn't designed for that. It is designed for ~1m at 100kHz and ~10m at 10kHz. ESP8266 defaults to 400kHz and can't go lower than 50kHz without modifying the ESP8266 core files.
                              I got my first use case for the oscilloscope I built.
                              This was the signal at the start of the cable:
                              This was the signal at the end of the cable:
                              So no surprise that the communication didn't work.
                              I tried with a 2k pullup:
                              Much better! But still not very good.
                              I modified the library to use 7.5kHz:
                              Better again, but still not great. I lowered the speed to 0.75kHz:
                              Nice and clean!
                              But communication still didn't work so I decided to cut the cable (to the 10cm length seen above) and restore all my changes. But communication still doesn't work.
                              I bought the sensor from a reputable distributor in UK so I don't think I got a faulty sensor. But I don't seem to get any life signs at all from it. I tried an i2c scan sketch and it found nothing.
                              YveauxY 1 Reply Last reply
                                Nice and clean!
                                YveauxY
                                YveauxY
                                @mfalkvidd shot in the dark ; do you pull the PS pin high to select i2c protocol?
                                • YveauxY Yveaux
                                  #616
                                  @yveaux yes I do. I took the easy way: soldered the 3.3V wire to pads 5 and 6 at the same time.
                                  And I have tried putting a 104 ceramic capacitor between 3V3 and GND right next to the sensor.
                                  CSB is connected to GND.
                                  My next step is either to see if I can get SPI working (instead of i2c), or order a new sensor. But first sleep.
                                  • nagelcN
                                    nagelcN
                                    nagelc
                                    BT832 Thin Node prototype. Inspired by https://forum.mysensors.org/topic/2067/my-slim-2aa-battery-node and @neverdie nrf5 and am612 research. I noticed the BT832 is about the same width as a AA battery holder. I'm using one AA LiFePo4. This is my first sensor with nrf5, bme280, and am612. I also incorporated a jst-sh 6 pin connector for programming. It includes swd, power, and text. All sensors are working. It did not turn out to be very thin. Need to try some smaller PIR lenses and rearrange components for the next iteration.
                                    • NeverDieN
                                      NeverDieN
                                      Nice work! If you want to go thinner, you may have to use a coincell. Looks nice the way it is though.
                                      • kalinaK
                                        kalinaK
                                        kalina
                                        I have assembled a few UPS ... now I am testing these hardware.
                                        2_1537103208634_UPS_3.jpg 1_1537103208634_UPS_2.jpg 0_1537103208633_UPS_1.jpg
                                        nagelcN T 2 Replies Last reply
                                        • kalinaK kalina
                                          nagelcN
                                          nagelcN
                                          nagelc
                                          @kalina
                                          Nice packaging. I'll be interested to hear how well they work.
                                          kalinaK 1 Reply Last reply
