  3. What did you build today (Pictures) ?
1.1k Posts 105 Posters 752.7k Views 98 Watching
  • nagelcN nagelc
    @kalina
    Nice packaging. I'll be interested to hear how well they work.
    kalinaK
    kalinaK
    kalina
    @nagelc
    OK, I will keep you informed of developments on this project ...
    • kalinaK kalina
      I have assembled a few UPS ... now I am testing these hardware.
      2_1537103208634_UPS_3.jpg 1_1537103208634_UPS_2.jpg 0_1537103208633_UPS_1.jpg
      tsjoender
      @kalina said in What did you build today (Pictures) ?:
      Looks neat! How did you do the cutout of the sides of these enclosures?
      kalinaK 1 Reply Last reply
      • T tsjoender
        kalinaK
        kalinaK
        kalina
        @tsjoender said in What did you build today (Pictures) ?:
        No magic, this is the work of the CNC...)))
        • sundberg84S
          #624
          Today I had the ladder so I could get on the roof so while there I changed batteries on my rain node.
          YveauxY 1 Reply Last reply
          • sundberg84S sundberg84
            YveauxY
            YveauxY
            @sundberg84 But what did you build today? ;-)
            • YveauxY Yveaux
              @yveaux nothing that I can post here unfortunately... only a ladder for my cat 😂 non automated.
              Nca78N 1 Reply Last reply
              • nagelcN
                nagelcN
                nagelc
                wrote on last edited by nagelc
                #627
                It's a breakout for a Fanstel BT832 (NRF52832). Two experiments with this board, still a work in progress:
                • I wondered if it would be possible to hand solder to the LGA pads on the back of the BT832 using small plated thru holes (6 solder spots middle left in the first picture). Two pads connected. The rest did not. About what I expected.
                • Using just the microprocessor of the BT832 to make a LoRa node. (NRF5 radio turned off). So far the Ra-01 is not initializing. Edit (10/8). The RA-01 now initializes. I needed to update the pin assignments in MyBoardNRF5.h.
                  Nca78N
                  Nca78N
                  @sundberg84 said in What did you build today (Pictures) ?:
                  Just pretend you have automated your cat. We can't control from here.
                  • vladimirV
                    vladimirV
                    vladimir
                    Colleagues!
                    I am writing in this thread, because here are the most active users of the forum and the system MySensors.:raised_hands:
                    Perhaps you can help me with the solution of my problem: Improvement Xiaomi smart kettle (I need help!)
                    Maybe you had similar projects...
                    Then, I can finally publish a new project in this thread. :v:
                    • vladimirV vladimir
                      Colleagues!
                      YveauxY
                      YveauxY
                      #630
                      @vladimir please don't crosspost. Everybody is able to see the latest messages, so there is no need to point to your post from multiple threads.
                      vladimirV 1 Reply Last reply
                      • YveauxY Yveaux
                        vladimirV
                        vladimirV
                        vladimir
                        @yveaux Excuse me. I promise not to do it again!:man-gesturing-ok:
                        • sundberg84S
                          #632
                          @Nca78 Well, i automated my cat door.
                          • Andrew MaynardA
                            Andrew MaynardA
                            Andrew Maynard
                            The rules are simple - keep it simple with one picture (or a few) with a small text including a small exp
                            sick of breadboard so made the gateway more permanent. added a nice dc plug to it after pic
                            • sundberg84S
                              #634
                              Playing with how small I could create a EasyPCB if I only used SMD components and footprints for both RFM69 and Nrf24l01+... including MysX, Signing, Flash offcourse... and a coincell...
                              tbowmoT monteM 2 Replies Last reply
                                tbowmoT
                                tbowmoT
                                tbowmo
                                @sundberg84
                                cool, what dimensions are you down to now?
                                btw. what happened to the trace in lower right corner (the one that runs by the ISP connector)?
                                • tbowmoT tbowmo
                                  @sundberg84
                                  #636
                                  @tbowmo - Thanks!! :) 42mm diameter (round, but the 3d view doesnt show that).
                                  The track - well, it seems like I can only get KiCad to make 45dgr tracks... need to investigate it its possible to make other tracks...
                                  O 1 Reply Last reply
                                    monteM
                                    monteM
                                    monte
                                    @sundberg84 you can also use smd crystal. They are cheaply available on aliexpress. Are you using 0603 caps and resistors?
                                    • monteM monte
                                      @monte - 0805 res/caps, (for me easy to solder, while 0603 is possible but start to get hard).
                                      I was thinking about SMD crystal but left it since i couldnt find a common size. Do you know a good size for SMD crystal (with multiple brands?) like 0805 or a good searchword? I found HC-49S but they are the same size as the ones with pins.
                                      monteM 1 Reply Last reply
                                        O
                                        O
                                        Omemanti
                                        wrote on last edited by Omemanti
                                        #639
                                        @sundberg84 "well, it seems like I can only get KiCad to make 45dgr tracks"
                                        References => General Settings => Limit graphics lines to 45 degrees
                                        • bjacobseB
                                          bjacobseB
                                          bjacobse
                                          I recently hacked my Assa Abloy/Yale smart lock as it could only turn +-90° created a new washer ring, so it now can turn infinitely so it is usable to use a lock
                                          The needed 3D stl file or Freecad drawing is to be found here:
                                          https://www.thingiverse.com/thing:3155286
