  3. What did you build today (Pictures) ?
1.1k Posts 105 Posters 750.3k Views 98 Watching
  • S scalpel
    I use raspberry for watching television, movies etc. Today I build raspberry hat to turn on from remote control. Attiny85 recognizes programmed remote code and by optocoupler short circuit on pins.
    rozpruwaczR
    rozpruwaczR
    rozpruwacz
    wrote on last edited by rozpruwacz
    #121
    @scalpel how do You program the ir code for the power button ? can it be programed from the linux running in the rpi ? or it is just hardcoded into atiny code ?
    • S
      scalpel
      Hardcoded In attiny. Learn arduino irremote library.
      Pozdrawiam / regards
      • S scalpel
        rozpruwaczR
        rozpruwaczR
        rozpruwacz
        @scalpel yeah, I did this kind of project also and I wonder if there is a software for that :) It would be fun to be able to set the wakeup ir code from the linux os, with for example i2c or 1-wire interface.
        gohanG 1 Reply Last reply
        • rozpruwaczR rozpruwacz
          @rozpruwacz how often would you need to change the IR code for that?
          • rozpruwaczR
            rozpruwaczR
            rozpruwacz
            rarely, but still it would be fun to make such thing :)
            • sinczeS sincze
              @dbemowsk while you are at it..consider :)
              The dishwasher can be added as well. My devices dishwasher / washing machine / dryer send messages to all tvs that are turned on. Identifying themselves and invite you to come and clean them :). It comes in handy and absolutely jaw dropping on your visitors.
              If you turn on the stove air circulation system in the kitchen... Why not greet the wife with automatically start the TV in the kitchen and play her favourite radio channel at her preferred volume...
              D
              D
              dakipro
              @sincze said in What did you build today (Pictures) ?:
              @sincze hi, could you elaborate a bit more the TV messages, do you have any link with more info? Was that the LG tv with Mqtt that was mentioned on the forum?(or I mixed forums)
              sinczeS 1 Reply Last reply
              • D dakipro
                sinczeS
                sinczeS
                sincze
                MySensors Evangelist
                @dakipro we use kodi on al lgl tvs. The libreelec TV box has cec and can turn on the TV via hdmi. If TV is on I am able to control the volume via the LG webserver. Kodi (api) can display the notifications for Me :). Not that fancy but it works like a charm.
                bjacobseB 1 Reply Last reply
                • wallyllamaW
                  wallyllamaW
                  wallyllama
                  Side note. I did a quick search, there is a cec library for arduino!
                  https://github.com/stefslon/cec-arduino
                  • sinczeS sincze
                    bjacobseB
                    bjacobseB
                    bjacobse
                    @sincze
                    If it works like a charm - it's fancy ;-)
                    • sundberg84S
                      Back to topic! Last night I made some changes to my ATX Power supply because the variable settings was to sensitive:
                      0_1511953574080_upload-c7feca62-d22d-435e-9c73-9599ca0c9044
                      0_1511953586756_upload-3bb65a38-91b8-4dc8-9dd7-3a0af6fd45f9
                      • sundberg84S sundberg84
                        zboblamontZ
                        zboblamontZ
                        zboblamont
                        @sundberg84 Did you find that taking the cover off improved the accuracy at all ?
                        :laughing:
                        • maghacM
                          maghacM
                          maghac
                          I built a lithophane lamp for my grandson. The electronics is basically only a pro mini and 36 neopixels. Sadly this version is not mysensorized but maybe I'll do that in version 2 :)
                          NeverDieN 1 Reply Last reply
                          • maghacM maghac
                            NeverDieN
                            NeverDieN
                            #133
                            @maghac Cool. How were you able to convert the photos into that embossed material (or whatever it is)? Is that a CNC process, or something else? It seems to have very good resolution.
                              I have seen a video where you can convert your pictures and print them using a 3D printer
                              maghacM 1 Reply Last reply
                                maghacM
                                maghacM
                                maghac
                                @gohan said in What did you build today (Pictures) ?:
                                Correct, these are 3D printed lithophanes (https://en.wikipedia.org/wiki/Lithophane). I used http://3dp.rocks/lithophane/ to convert jpg files to STL files for printing.
                                • Nca78N
                                  Nca78N
                                  wrote on last edited by Nca78
                                  #136
                                  After failing to assemble a completely functional version of my new livolo switch board, I assembled a first prototype of my new "22" sensor board. Unfortunately I didn't receive the sensors yet so it only has a switch, a hall sensor for door and a led, but that's enough for the first testing.
                                  Board is made to cut headers when it will be finished, but meanwhile I can use the headers to make it a breakout board for the nrf51 module or for each of the sensors.
                                  • scalzS
                                    scalzS
                                    wrote on last edited by scalz
                                    #137
                                    @Nca78 nice :+1: it looks like familiar to me, i don't know why ;) I agree with you, I prefer rounded square shape as it fits more easily everywhere than circles
                                    Nca78N 1 Reply Last reply
                                    • NeverDieN
                                      NeverDieN
                                      #138
                                      :+1: Have you settled yet on what kind of connector you're going to use on future boards?
                                      • scalzS scalz
                                        Nca78N
                                        Nca78N
                                        #139
                                        @scalz said in What did you build today (Pictures) ?:
                                        Not sure which one you're talking about, as it's some kind of child between @NeverDie 's board (same nrf51 module and small size) and your aeos (shape, on board sensors). But it's more like a challenge to me, make the smallest board possible (22*22mm) with as many sensors as possible (at the moment, door, TH, light, accelerometer) and I have a bit of margin to add more like the leak detection from @NeverDie it's really nice to be able to do it with such a tiny sensor.
                                        I'll do a more complete and flexible 33 board later, I will try to make it some kind of a hand-solderable version of aeos ;)
                                        • NeverDieN
                                          NeverDieN
                                          #140
                                          As far as minimizing size goes, I think you're right: square (or some kind of rectangle) is going to be better. I end up throwing away a lot of useable space going from square to circle, which, unfortunately, forced me into increasing the diameter (i.e. the size). So, in the end, square/rectangular is probably better. :) I think the allure of the circle is to try to fit the whole thing perfectly onto a coincell (which acts as a kind of limit on how small you can ultimately go), but unfortunately that can't happen with any of the coincell holders I've seen so far....
