  3. Vera
  4. Don't see my Arduino node device in Vera
12 Posts 4 Posters 4.7k Views 4 Watching
  • B
    B
    billgoolsby
    I'm new to MySensors and Vera. I have a GoControl Z-Wave thermostat installed and working in Vera, so I know that Vera is working to that extent. I built a serial gateway using the GatewaySerialNano code and a genuine Arduino Nano board. I configured the gateway in Vera and I see "MySensors Plugin" in the "unknown category" devices. I then built a temp and humidity node using an Arduino Pro and a BME280 sensor. I don't see anything in Vera that indicates the BME280 is present. Here's the node code:
    // WNG mods
    // 8/08/17 - Used MySensors example plus Sparkfun BME280 example to make a sketch
    //   that uses BME280 sensor. Not tested yet.
    // Sparkfun example here:
    // https://github.com/sparkfun/SparkFun_BME280_Arduino_Library/blob/master/examples/I2C_ReadAllData/I2C_ReadAllData.ino
    // Original MySensors sketch here:
    // https://www.mysensors.org/build/humidity
     * Version 1.0: Henrik EKblad
    // Enable debug prints
    #include <SparkFunBME280.h>
    //BME Library allows either I2C or SPI, so include both.
    #include "Wire.h"  //I'm using I2C
    #include "SPI.h"
    //Global sensor object
    BME280 mySensor;
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 5000;
    #define CHILD_ID_HUM  0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = false;
      sendSketchInfo("BME280_Node", "1.0");
      present(CHILD_ID_HUM, S_HUM);
      //set up BME280
      //For I2C, enable the following and disable the SPI section
      mySensor.settings.commInterface   = I2C_MODE;
      mySensor.settings.I2CAddress      = 0x77;
      mySensor.settings.runMode         = 3; //Normal mode
      mySensor.settings.tStandby        = 0;  //0.5ms
      mySensor.settings.filter          = 0; //filter off
      mySensor.settings.tempOverSample  = 1;
      mySensor.settings.pressOverSample = 1;
      Serial.begin(115200);
      delay(3000);
      Serial.print("Program Started\n");
      Serial.print("Starting BME280... result of .begin(): 0x");
      //Calling .begin() causes the settings to be loaded
      delay(10);  //Make sure sensor had enough time to turn on. BME280 requires 2ms to start up.
      Serial.println(mySensor.begin(), HEX);
      Serial.print("Displaying ID, reset and ctrl regs\n");
      Serial.print("ID(0xD0): 0x");
      Serial.println(mySensor.readRegister(BME280_CHIP_ID_REG), HEX);
      Serial.print("Reset register(0xE0): 0x");
      Serial.println(mySensor.readRegister(BME280_RST_REG), HEX);
      Serial.print("ctrl_meas(0xF4): 0x");
      Serial.println(mySensor.readRegister(BME280_CTRL_MEAS_REG), HEX);
      Serial.print("ctrl_hum(0xF2): 0x");
      Serial.println(mySensor.readRegister(BME280_CTRL_HUMIDITY_REG), HEX);
      Serial.print("\n\n");
      delay(1000);
      float temperature = mySensor.readTempF();
      float humidity    = mySensor.readFloatHumidity();
      // Get temperature
      if (isnan(temperature)) {
        Serial.println("Failed reading temperature!");
        lastTemp = temperature;
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      // Get humidity
      if (isnan(humidity)) {
        Serial.println("Failed reading humidity!");
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
      sleep(UPDATE_INTERVAL);
    Here's the debug output of the BME280 node, including startup and a few sensor transmissions:
    4 TSM:INIT
    4 TSF:WUR:MS=0
    12 TSM:INIT:TSP OK
    14 TSF:SID:OK,ID=1
    16 TSM:FPAR
    51 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    149 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    153 TSF:MSG:FPAR OK,ID=0,D=1
    2060 TSM:FPAR:OK
    2060 TSM:ID
    2062 TSM:ID:OK
    2064 TSM:UPL
    2068 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2076 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2082 TSF:MSG:PONG RECV,HP=1
    2086 TSM:UPL:OK
    2088 TSM:READY:ID=1,PAR=0,DIS=1
    2093 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2101 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2109 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
    2119 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    4128 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=11,sg=0,ft=0,st=OK:BME280_Node
    4139 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
    4147 TSF:MSG:SEND,1-1-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4157 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
    4163 MCO:REG:REQ
    4167 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    4175 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    4179 MCO:PIM:NODE REG=1
    4184 MCO:BGN:STP
    Program Started
    Starting BME280... result of .begin(): 0x60
    ID(0xD0): 0x60
    Reset register(0xE0): 0x0
    ctrl_meas(0xF4): 0x27
    ctrl_hum(0xF2): 0x0
    8220 MCO:BGN:INIT OK,TSP=1
    8230 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:74.1
    T: 74.14
    8243 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:76.3
    H: 76.28
    8249 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
    8255 MCO:SLP:TPD
    8257 MCO:SLP:WUP=-1
    8267 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:76.3
    H: 76.28
    8275 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
    8282 MCO:SLP:TPD
    8284 MCO:SLP:WUP=-1
    8294 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:76.3
    H: 76.28
    8302 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
    8308 MCO:SLP:TPD
    8310 MCO:SLP:WUP=-1
    8321 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:76.3
    H: 76.28
    8329 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
    8335 MCO:SLP:TPD
    8337 MCO:SLP:WUP=-1
    8347 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:74.2
    T: 74.16
    8357 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:76.3
    H: 76.28
    8366 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
    8372 MCO:SLP:TPD
    8374 MCO:SLP:WUP=-1
    8384 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:74.1
    T: 74.14
    8394 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:76.3
    H: 76.28
    8402 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
    8409 MCO:SLP:TPD
    8411 MCO:SLP:WUP=-1
    8419 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
    8425 MCO:SLP:TPD
    8427 MCO:SLP:WUP=-1
    8435 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:74.1
    T: 74.12
    8448 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:76.3
    H: 76.28
    This looks normal to me, yes?
    My question: Why don't I see the node in Vera? There must be something I haven't set up.
    Thanks!
    B 1 Reply Last reply
    • B billgoolsby
      // WNG mods
      #include "SPI.h"
      BME280 mySensor;
      float lastTemp;
      float lastHum;
        //set up BME280
        delay(3000);
        delay(1000);
        // Get temperature
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesTemp++;
        // Get humidity
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesHum++;
      4 TSM:INIT
      4 TSF:WUR:MS=0
      12 TSM:INIT:TSP OK
      14 TSF:SID:OK,ID=1
      16 TSM:FPAR
      2060 TSM:FPAR:OK
      2060 TSM:ID
      2062 TSM:ID:OK
      2064 TSM:UPL
      2086 TSM:UPL:OK
      4163 MCO:REG:REQ
      4184 MCO:BGN:STP
      Program Started
      ID(0xD0): 0x60
      ctrl_hum(0xF2): 0x0
      T: 74.14
      H: 76.28
      8255 MCO:SLP:TPD
      8257 MCO:SLP:WUP=-1
      H: 76.28
      8282 MCO:SLP:TPD
      8284 MCO:SLP:WUP=-1
      H: 76.28
      8308 MCO:SLP:TPD
      8310 MCO:SLP:WUP=-1
      H: 76.28
      8335 MCO:SLP:TPD
      8337 MCO:SLP:WUP=-1
      T: 74.16
      H: 76.28
      8372 MCO:SLP:TPD
      8374 MCO:SLP:WUP=-1
      T: 74.14
      H: 76.28
      8409 MCO:SLP:TPD
      8411 MCO:SLP:WUP=-1
      8425 MCO:SLP:TPD
      8427 MCO:SLP:WUP=-1
      T: 74.12
      H: 76.28
      Thanks!
      B
      B
      billgoolsby
      Another question: Is there a way to see debug output from the serial gateway? Since its USB port is connected to Vera, I don't see a way to get debug info from it.
        If you have an esp8266 around you could make an ethernet gateway making it easier to debug
        • dbemowskD
          dbemowskD
          If you go to Apps>Develop apps>Serial Port configuration, do you have the settings there set correctly? This is what mine looks like:
          0_1509941483084_upload-476429e5-6791-44f6-8b2e-11fcd60e63e8
          Your name and device number may be different depending on your serial adapter that you are using. The other settings should be the same though. Baud should be 115200, Parity should be none, data bits should be 8 and stop bits should be 1. Then select your MySensors Plugin that you created under "Used by device". If these settings are not correct, the gateway will not work.
          • R
            R
            r-nox
            @billgoolsby said in Don't see my Arduino node device in Vera:
            MySensors Plugin
            Did you go into the MySensors Plugin setting and include the new sensor?
              B
              B
              billgoolsby
              @gohan, I do have a W5100 I could try, but I thought of a way to see the serial stream between the gateway and Vera: put a TTL-to-USB serial adapter on either the TX or RX lines from the Nano. I'll try that first.
              • dbemowskD dbemowsk
                B
                B
                billgoolsby
                @dbemowsk, This is my configuration:
                • R r-nox
                  MySensors Plugin
                  B
                  B
                  billgoolsby
                  @r-nox, No, didn't do that - where do I go in the Vera menus to do it? I don't see anything that looks likely.
                  dbemowskD 1 Reply Last reply
                  • B billgoolsby
                    dbemowskD
                    dbemowskD
                    @billgoolsby Go to Devices in the menu and click on the MySensors Plugin device. Next, click on Settings. You should now see something like this:
                    0_1510038912589_upload-ac61da1b-fef1-4158-8343-7f83a9e43cb1
                    Click on the start button and then reset your node that you built. The node should go through it's initialization process and present itself to the controller. Below the start / stop buttons you will see "0 devices found" at first, and then once the plugin sees the node, you will see that number change. If you have a node with one sensor, you should see 2 devices found. One is the sensor, and the other is an object for the node itself.
                    Once this process is complete, you can back out to the devices menu. Under "No Room" you should see something like this if your node is a temperature sensor for example:
                    0_1510039852960_upload-5a15b6ae-70b2-439e-b0e3-1d4e28b29fe6
                    Of your node has more than one sensor, then you will see an object for the "Arduino Node X" and an object for each sensor on that node.
                    Once the inclusion process is complete, you won't have to add the node again. You can then go into each object and set it's properties such as what room it is under, and any configuration properties for the device if any.
                    Let us know if you have further trouble.
                      B
                      B
                      billgoolsby
                      @dbemowsk, Wow! It worked! Thanks so much. Very happy to get to this point.
                      • B billgoolsby
                        dbemowskD
                        dbemowskD
                        @billgoolsby We were all there at one point. Happy to help.
                        • R
                          R
                          r-nox
                          There you have it!
