  3. Mysensors Thermostat
5 Posts 5 Posters 6.0k Views 3 Watching
  • gigiG
    gigiG
    gigi
    I'm making a thermostat with mysensors
    define CHILD_ID_HEATER 0
    MyMessage msgHeater(CHILD_ID_HEATER, V_HEATER_SW);
    MyMessage msgTemp(CHILD_ID_HEATER, V_TEMP);
    MyMessage msgUp(CHILD_ID_HEATER, V_UP);
    MyMessage msgDown(CHILD_ID_HEATER, V_DOWN);
    gw.begin(incomingMessage, NODE_ID, false); //nodo 6
    gw.sendSketchInfo(SN, SV);
    gw.present(CHILD_ID_HEATER, S_HEATER);
    gw.send(msgTemp.set(tempVera));
    V_HEATER_SW has the current temperature, turn off the power and heat button and two buttons + and - inside the threshold temperature
    with gw.send(msgTemp.set(tempVera)); I send temperature to vera
    with gw.send(msgHeater.set("Off"),true); and gw.send(msgHeater.set("HeatOn"),true); send to vera off ed heaton.
    My BIG problem:
    how do I send through two buttons on Arduino + and - on Vera?
    if(digitalRead(BUTTON_PIN_MENO) == HIGH)
    //send - to vera
    if(digitalRead(BUTTON_PIN_PIU) == HIGH)
    //send + to vera
    Thank Gigi
    Vera lite - mysensors Ethernet gateway - AirWik sensor - Relay Module
    hekH 1 Reply Last reply
    • gigiG gigi
      My BIG problem:
      //send - to vera
      //send + to vera
      Thank Gigi
      @gigi
      You'll have to investigate the vera thermostat device files to find this information.
      It might be some missing commands for this as you are pioneer here.
      • P
        P
        punter9
        seems as easy as a temp sensor and a couple relays.......now making a neat looking virtual display to use.....
        • BigDogB
          BigDogB
          BigDog
          i am realy interested in this :) wil keep a eye on this topic :)
          been searching for a way to make a thermostat that can be managed localy and with domoticz
          1x Raspberry With Domoticz V2.3011 [Linux version 4.1.6+]
          PiRack With
          -1X PiFace Digital
          -1X RaZberry - OpenZWave
          1X RFXtrx433 USB Firmware: 183
          5X Arduino: mysensors V1.5(including)
          • First DoorBel Project -> WORKS! :)
            6x ESP8266: easy firmware(Testing)
          • korttomaK
            korttomaK
            korttoma
            I don't know about domoticz but I reacently put together a Thermostat device that I use with Vera UI5.
            I posted about it here and here
            • Tomas
