  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 499.7k Views 73 Watching
  • rvendrameR
    rvendrameR
    rvendrame
    @tekka said:
    I meant to update the Gateway node with the most recent Serialgateway sketch...
    Yep, I'm already on latest version on GW. My GW runs on a pro-mini, with standard bootloader --- I guess this is not a issue?
    ESP8266 GW + mySensors 2.3.2
    Alexa / Google Home
    tekkaT 1 Reply Last reply
    • rvendrameR rvendrame
      tekkaT
      tekkaT
      tekka
      and MYSController is connected via USB/FTDI to the GW...?
      • rvendrameR
        rvendrameR
        rvendrame
        It is connected via USB/FTDI into a mac-mini running a TCP-to-serial SW. (so both Vera and MYSController can reach it using IP address). Works like a charm, I can see all nodes and messages, no connection issues so far.
        Is it required the GW running on MYSBootloader? I hope not...
        Alexa / Google Home
          tekkaT
          tekkaT
          tekka
          @rvendrame Sensor nodes with MYSBootloader (unless they are Sensebender boards) and GW with original bootloader. Curious to see your logs.
          • tekkaT tekka
            @rvendrame said:
            Yes, I connect the radio and start the node, but nothing happens --- No serial monitor, nothing in MYSController. Just the pin 13 led flashing randomly.
            Just flashed MYSController.hex on my Arduino pro mini 3V3 and the fuses as mentioned in the boards.txt (L: 0xF7 E: 0x06 H: 0xDA), using USBasp and everything works smoothly...
            Please keep in mind: There is no serial monitor for MYSBootloader and the 13 led flashing is normal
            Can you try this (in the indicated order):
            0) Update Arduino IDE to 1.6.5
            1. burn the original bootloader and upload the clear eeprom sketch
            2. burn MYSController, disconnect flasher and connect nRF24L01+ module
            3. download the most recent MySensors 1.5 library and upload the GW sketch
            4. launch MYSController 0.1.2.282, activate AutoID, Logging and connect to the serial GW
            5. let it run for a few mins and upload the log-file here
            rvendrameR
            rvendrameR
            rvendrame
            wrote on last edited by rvendrame
            #185
            EDIT: @tekka, @scalz , after so many tries, I don't know why I decided to replace the nRF radio , and guess what?
            Funny thing is that the previous radio is working with regular bootloader. Dam fake chips! But I will sort it out later, now I want to play with my OTA ;-)
            Thanks a lot!
            Alexa / Google Home
            • scalzS
              scalzS
              @rvendrame: so cool. I am happy for you!
              See you soon
              • FrancoisF
                FrancoisF
                Francois
                @tekka do MYSBootloader also work with the RFM69 radios?
                  Thanks a lot!
                  tekkaT
                  tekkaT
                  tekka
                  @rvendrame excellent :)
                  • FrancoisF Francois
                    tekkaT
                    tekkaT
                    tekka
                    @Francois No, in it's current stage only nRF24L01+, but porting to RFM69 should not be too difficult...
                    • 5546dug5
                      5546dug5
                      5546dug
                      @tekka silly ?
                      But still last night changed from serial to Ethernet gw using iboard wiz5100 and the h/w changes.
                      No issues but for later problems do I ---use myscontroller by way of FTDI connector>usb or
                      -- continue to plug the original serial gw into laptop leaving Ethernet still in use ( plugged in).
                      • 5546dug5 5546dug
                        @tekka silly ?
                        tekkaT
                        tekkaT
                        tekka
                        @5546dug said:
                        @tekka silly ?
                        I'm not quite sure I understand your question. Are you having issues with the EthernetGW?
                        • 5546dug5
                          5546dug5
                          5546dug
                          @tekka No everything is ok now but there will be problems in the future to sort out if history repeats itself.
                          So it is just a learning question for troubleshooting later.
                          To "see" Ethernet gw in your gui use FDTI>usb>laptop (with gw still connected to the router) or use the serial gw I had from before connected remotely to laptop via usb..
                          As of now I use only Ethernet gw plugged into router and the serial gw is no longer plugged into my vera.
                          • C cdr
                            @tekka I feel really, really, REALLY stupid;
                            I changed the channel in the mysensors config.h to 77, this was the reason no node would ever show up since the default mysbootloader uses the default channel 76.
                            D'OH
                            Thanks for your patience and help, everything is working now and I'm really happy!
                            :+1:
                            N
                            N
                            NewFolk
                            D'OH
                            :+1:
                            @tekka is there a way to change the default channel in MYSbootloader ?
                            • P
                              P
                              Pendragon
                              What ware the designed values for "type" in the fimware_config.csv?
                              Can I use this variable for my sensor IDs?
                              • rvendrameR
                                rvendrameR
                                rvendrame
                                @tekka, I've being playing with MYSController and MYSBootloader over last days, I'm totally amazed by them ;-) Thank you so much for developing such nice tool!
                                If you allow me, I have only one ask for the santa-claus list: Perhaps it is possible for MYSBootloader capture serial output from a node, allowing OTA Serial monitor via MYSController? I know you guys are doing a miracle within 2KB, but who knows...
                                Again, thanks a lot!
                                Alexa / Google Home
                                • N NewFolk
                                  D'OH
                                  :+1:
                                  tekkaT
                                  tekkaT
                                  tekka
                                  Yes, but for that you'll have to re-compile it.
                                  N 1 Reply Last reply
                                  • P Pendragon
                                    tekkaT
                                    tekkaT
                                    tekka
                                    Yes, but this is only an internal reference and not being used for AutoFW assignment
                                    • NeverDieN
                                      NeverDieN
                                      #198
                                      This sounds like a great app! What is the current status? I clicked on the link in the OP expecting it would connect with GitHub (where there might be a ReadMe.txt which tells what the current status is), but instad of that it just downloaded the app right then and there! There are now 197 posts on this thread, which is a bit many to sort through to find the status....
                                      Move it to Github?
                                        tekkaT
                                        tekkaT
                                        tekka
                                        Thanks, I'm glad you like the tools. :)
                                        Unfortunately your suggestion is not possible: bootloader and sketch run sequentially, not in parallel, and thus, cannot communicate with each other.
                                        • NeverDieN NeverDie
                                          Move it to Github?
                                          tekkaT
                                          tekkaT
                                          tekka
                                          @NeverDie said:
                                          This sounds like a great app! What is the current status? I clicked on the link in the OP expecting it would connect with GitHub (where there might be a ReadMe.txt which tells what the current status is), but instad of that it just downloaded the app right then and there! There are 197 posts on this thread, which is a bit many to sort through to find the status....
                                          Move it to Github?
                                          The first post is updated once a new version is released :)
                                          NeverDieN 1 Reply Last reply
