  3. Domoticz
  4. Push variable from domoticz to node?
4 Posts 3 Posters 1.9k Views 3 Watching
  • D
    D
    dmonty
    I'm new to Domoticz and MySensors.
    I've built a motion/door sensor node that turns on lights in the garage. At first I coded it so the Arduino node in the garage had logic to turn on the lights and maintain the countdown timer. Then later I moved the logic over to Domoticz Event script. Both work but I was thinking if the Domoticz Controller node was offline then my garage lights would fail to work. So I'd like to do a hybrid where Domoticz can send some parameter variables that get stored in the eprom of the arduino. e.g. Light On Countdown time.
    Are variables pushed using V_VAR1-5?
    https://www.mysensors.org/download/serial_api_20
    Thanks.
    dbemowskD 1 Reply Last reply
      You could also use like a dimmer control where you can adjust the value of the timer
      • D dmonty
        Thanks.
        dbemowskD
        dbemowskD
        @dmonty MySensors nodes can talk to one another by sending commands to a specific node, so you could move the countdown timer back to the motion sensor node and have that node talk directly to the light switch node to turn on/off the light.
          D
          D
          dmonty
          @gohan Thanks, dimmer works well.
