Sensebender GW no output on serial
After being away for almost one year. I picked up some of my stuff lying around in my cellar :-) Part of that is a Sensebender Gateway which is supposed to replace my current ATMega Gateway. However, I have a really strange behavior (Arduino 1.8.5):
- Uploaded Gateway5100 code -> I can see in my OpenHab controller that it works
- However, I cannot see any output from serial.println. - I tried other MySensor sketches, like SecurityPersonalizer -> doesn't work
I tried it with some of the basic Arduino sketches where no MySensor code is involved: This works.
I tried a re-install of Arduino, also deleting everything under /Users/tom/Library/Arduino15 and installed the boards (MySensors SAMD Boards 1.05) again.
I am really stuck. Any ideas are highly appreciated.
Ok. I have some new findings. Serial.print works after I sent a couple of thousands. Here is some code (not nice, but anyway...)
This will not print anything in the Serial Monitor:
#define MY_CORE_ONLY #include <MySensors.h> int i = 0; void setup() { Serial.begin(9600); for (; i< 10000; i++) { Serial.println(i); } } void loop() { if (i < 150000) { i = 200000; Serial.println("Started clearing. Please wait..."); Serial.println("Clearing done."); } }Changing the loop end in the for loop in setup to 50000 for example, Serial.prints show up.
Ok, now I think I have a workaround...The sketch SecurityPersonalizer gave me the right hint. I need to extend the waiting time in setup. If I extend it to around 10secs it seems to work.
void setup() { unsigned long enter = hwMillis(); while (hwMillis() - enter < (unsigned long)10000); Serial.begin(115200); Serial.println("here you go"); }
