  3. Problem with battery level value
12 Posts 3 Posters 8.5k Views 3 Watching
    Mattia Reggiani
    Good morning,
    Congratulations for this fantastic project ; are my first steps with Arduino and I have a litle problem with battery monitor on Arduino Pro Mini 5V, I use the sketch and instructions find in this page http://www.mysensors.org/build/battery , but the value read in pin A0 is always 1023, i have try othe analog pin with the same result
    In touch point however the value is 1,4 /1,5 measured with digital multimeter, in pin a0 the value is the same.
    The sensor is powered from 4 AA battery 1,5V .
    I do not understand where wrong.
    Sorry for the English is not perfect
    Mattia
    B 1 Reply Last reply
    • M Mattia Reggiani
      Good morning,
      Mattia
      B
      B
      boozz
      wrote on last edited by boozz
      @Mattia-Reggiani
      In the sketch a internal voltage reference of 1.1 V is used. This means that if a value of 1.1V or higher is measured at the A0 input, you'll read the max int value, which is 1023.
      Two options :
      1. Change the voltage divider to get maximum of 1.1 V if the batteries supply app. 6 V (4x1.5 V). instead of the 470k you could use 230k or instead of the 1M you could use 2M.
      or
      2. don't use the internal reference of 1.1V.
      I would go for the first option.
      some additional info on the internal voltage reference of the arduino to be found here
      Note that 4x1.5 VDC is 6 VDC, with a fresh set of batteries possibly higher. you probably connect it to the raw input, so that the step down converter build on the pro-mini will do its work.
      Succes!
      Boozz
        Mattia Reggiani
        @boozz
        Many Thanks, now I understand but I still have doubts, in the skecth i have change this
        float batteryV = sensorValue * 0.003363075;
        in
        float batteryV = sensorValue * 0.00575035;
        because if I understand it ((1e6+470e3)/470e3)*1.1 = Vmax = 3.44 Volts
        in my case is ((1+0,23)/0,23)*1,1 = 5,88 and after 5,88/1023 = 0,0057478
        Now, however with new battery the output is
        99
        Battery Voltage: 0.57 V
        Battery percent: 9 %
        The code i used is
        // get the battery Voltage
        Serial.println(sensorValue);
        Mattia
        • T
          TimO
          Did you change the divider?
          In my temperature sensor i measure the battery level with:
          R1: 1 MOhm
          R2: 220 kOHM
          float batteryV = sensorValue * 6.1 / 1023;
          With an input voltage of 7.2 V the dividers gives 1.1 V (1023) on the analog input.
          Don't forget to place a capacitor between AREF & GND to stabilize the measurement.
          • M Mattia Reggiani
            @boozz
            in
            99
            The code i used is
            Mattia
            B
            B
            boozz
            @Mattia-Reggiani
            As TimO already asked: did you change the divider? (replace the resistor 470k into a resistor 220k or the 1M into 2M)? it's essential.
            Boozz
              Mattia Reggiani
              I have change R1 to 2M and R2 470k , I think to have some problem with resistors, tomorrow will buy new resistors and try again from scratch.
              Thanks for your help
              Mattia
                Mattia Reggiani
                I have rebuild the dividers with R1 1M ohm and R2 220k ohm, i have try with pin A1 and A0 and have strange value
                990
                Battery Voltage: 5.59 V
                Battery percent: 99 %
                1023
                Battery Voltage: 5.78 V
                Battery percent: 102 %
                First read is correct, but after this all other value have value 1023, if use multimeter on R1 and R2 have a value of 0,93 on touch point have 0,93 and on the Pin A0 or A1 have the same value.
                It is possible that Arduino read the wrong value ?
                • T
                  TimO
                  Did you place a capacitor between AREF and GND?
                    Mattia Reggiani
                    @TimO
                    Sorry, but Whatsapp is AREF? Is the Pin thai I use to measure the battery voltage (A0) ? Bcause on Google i find some Arduino Board with AREF pin but my Arduino mini pro has not that pin.
                    Mattia
                    • T
                      TimO
                      wrote on last edited by TimO
                      Oh, I'm sorry, at the Arduino pro mini there already is a capacitor between AREF & GND, so don't worry about it.
                      Here is my working example, a sensor for humidity, temperature and status of the battery:
                      link text
                      It's basically:
                      line 30: with "analogReference("INTERNAL)", did you call that?
                      The function in line 70 measures the battery status.
                        Mattia Reggiani
                        @TimO @boozz
                        Finally there I did, the problem was due by the resistances; I bought the new resistors
                        2M Ohm and 470k Ohm and now works correctly.
                        Thank you all for your support and for your patience
                        (Now I have a little more knowledge on electronics :) )
                        Mattia
                        • M Mattia Reggiani
                          @TimO @boozz
                          Mattia
                          B
                          B
                          boozz
                          @Mattia-Reggiani
                          Good to see that you solved it and learned by doing. Congrats!
                          Boozz
