  3. Flashed mysensors dev branch to my sensors - not showing up in home assistant
9 Posts 3 Posters 2.1k Views 3 Watching
  • A
    A
    alterfritz
    I wounding how I can do static configuration in home assistant?
    • A
      A
      alterfritz
      If possible I would avoid to rip all apart and refash...
        What exactly did you do? And what is your current setup?
        • A
          A
          alterfritz
          I'm trying both the raspi mqtt and the esp8266 mqtt gateway. I have flashed the dev 2.1.1 branch towards a set of arduino pro mini led light, communication seems to work - I can see the sensors publishing towards mqtt.
          My config in configuration.yaml:
          mysensors:
          gateways:
          - device: mqtt
          persistence_file: '/home/homeassistant/.homeassistant/mysensors.json'
          topic_in_prefix: 'mysensors-out'
          topic_out_prefix: 'mysensors-in'
          optimistic: false
          persistence: true
          retain: true
          version: '2.0'
          When I switch on the lights, I see messages appear on the mqtt:
          mysensors-out/1/255/0/0/17 2.2.0-beta
          mysensors-out/1/255/3/0/6 0
          mysensors-in/1/255/3/0/6 M
          mysensors-out/1/255/3/0/11 WallLight1
          mysensors-out/1/255/3/0/12 1.0
          mysensors-out/1/1/0/0/4 (null)
          mysensors-out/1/1/1/0/3 100
          mysensors-out/6/255/0/0/17 2.2.0-beta
          mysensors-out/6/255/3/0/6 0
          mysensors-out/5/255/0/0/17 2.2.0-beta
          mysensors-out/5/255/3/0/6 0
          mysensors-in/6/255/3/0/6 M
          mysensors-in/5/255/3/0/6 M
          mysensors-out/6/255/3/0/11 WallLight6
          mysensors-out/6/255/3/0/12 1.0
          mysensors-out/6/1/0/0/4 (null)
          mysensors-out/5/255/3/0/12 1.0
          mysensors-out/5/1/0/0/4 (null)
          mysensors-out/5/1/1/0/3 100
          mysensors-out/6/1/1/0/3 100
          mysensors-out/3/255/3/0/6 0
          mysensors-in/3/255/3/0/6 M
          mysensors-out/3/1/0/0/4 (null)
          mysensors-out/3/1/1/0/3 100
          mysensors-out/3/255/3/0/11 WallLight3
          mysensors-out/3/255/3/0/12 1.0
          mysensors-out/4/255/0/0/17 2.2.0-beta
          mysensors-out/4/255/3/0/6 0
          mysensors-in/4/255/3/0/6 M
          mysensors-out/4/1/0/0/4 (null)
          mysensors-out/4/1/1/0/3 100
          mysensors-out/4/255/3/0/11 WallLight4
          mysensors-out/4/255/3/0/12 1.0
          However - they do not show up ... home assistant log shows like this...:100:
          Jan 22 18:03:57 pi hass[744]: 2018-01-22 18:03:57 DEBUG (Thread-6) [mysensors.gateway_mqtt] Receiving 4;255;3;0;27;WallLight4
          Jan 22 18:03:57 pi hass[744]: 2018-01-22 18:03:57 DEBUG (Thread-13) [homeassistant.components.mysensors] Node update: node 4 child 255
          Jan 22 18:03:57 pi hass[744]: 2018-01-22 18:03:57 DEBUG (Thread-13) [homeassistant.components.mysensors] Not a child update for node 4
          Jan 22 18:03:58 pi hass[744]: 2018-01-22 18:03:58 DEBUG (Thread-4) [mysensors.gateway_mqtt] Receiving 4;255;3;0;11;WallLight4
          Jan 22 18:03:58 pi hass[744]: 2018-01-22 18:03:58 DEBUG (Thread-13) [homeassistant.components.mysensors] Node update: node 4 child 255
          Jan 22 18:03:58 pi hass[744]: 2018-01-22 18:03:58 DEBUG (Thread-13) [homeassistant.components.mysensors] Not a child update for node 4
          Jan 22 18:03:58 pi hass[744]: 2018-01-22 18:03:58 DEBUG (Thread-9) [mysensors.gateway_mqtt] Receiving 1;1;1;0;3;100
          Jan 22 18:03:58 pi hass[744]: 2018-01-22 18:03:58 DEBUG (Thread-13) [homeassistant.components.mysensors] Node update: node 1 child 1
          Jan 22 18:03:58 pi hass[744]: 2018-01-22 18:03:58 WARNING (Thread-13) [homeassistant.components.mysensors] Invalid values: {19: '356', 3: '100'}: light platform: node 1 child 1: S_DIMMER requires value_type V_STATUS @ data[2]
          Jan 22 18:03:59 pi hass[744]: 2018-01-22 18:03:59 DEBUG (Thread-7) [mysensors.gateway_mqtt] Receiving 1;1;1;0;3;100
          Jan 22 18:03:59 pi hass[744]: 2018-01-22 18:03:59 DEBUG (Thread-13) [homeassistant.components.mysensors] Node update: node 1 child 1
          Jan 22 18:03:59 pi hass[744]: 2018-01-22 18:03:59 WARNING (Thread-13) [homeassistant.components.mysensors] Invalid values: {19: '356', 3: '100'}: light platform: node 1 child 1: S_DIMMER requires value_type V_STATUS @ data[2]
          Jan 22 18:04:00 pi hass[744]: 2018-01-22 18:04:00 DEBUG (Thread-10) [mysensors.gateway_mqtt] Receiving 4;1;1;0;3;100
          Jan 22 18:04:00 pi hass[744]: 2018-01-22 18:04:00 DEBUG (Thread-13) [homeassistant.components.mysensors] Node update: node 4 child 1
          Jan 22 18:04:00 pi hass[744]: 2018-01-22 18:04:00 WARNING (Thread-13) [homeassistant.components.mysensors] Invalid values: {3: '100'}: light platform: node 4 child 1: S_DIMMER requires value_type V_STATUS @ data[2]
          Jan 22 18:04:00 pi hass[744]: 2018-01-22 18:04:00 DEBUG (Thread-8) [mysensors.gateway_mqtt] Receiving 4;1;1;0;3;100
          Jan 22 18:04:00 pi hass[744]: 2018-01-22 18:04:00 DEBUG (Thread-5) [mysensors.gateway_mqtt] Receiving 4;1;1;0;3;100
          Jan 22 18:04:03 pi hass[744]: 2018-01-22 18:04:03 INFO (MainThread) [homeassistant.components.http] Serving /description.xml to 192.168.10.211 (auth: True)
          Jan 22 18:04:04 pi hass[744]: 2018-01-22 18:04:04 DEBUG (Thread-11) [mysensors.gateway_mqtt] Receiving 6;255;0;0;17;2.2.0-beta
          Jan 22 18:04:04 pi hass[744]: 2018-01-22 18:04:04 DEBUG (Thread-3) [mysensors.gateway_mqtt] Receiving 6;255;3;0;6;0
          Jan 22 18:04:04 pi hass[744]: 2018-01-22 18:04:04 DEBUG (Thread-13) [mysensors.gateway_mqtt] Publishing 6;255;3;0;6;M
          Jan 22 18:04:04 pi hass[744]: 2018-01-22 18:04:04 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_call_id=1972866000-41, domain=mqtt, service=publish, service_data=payload=M, topic=mysensors-in/6/255/3/0/6, qos=0, retain=True>
          Jan 22 18:04:04 pi hass[744]: 2018-01-22 18:04:04 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=1972866000-41>
          Jan 22 18:04:04 pi hass[744]: 2018-01-22 18:04:04 DEBUG (Thread-9) [mysensors.gateway_mqtt] Receiving 6;255;3;0;11;WallLight6
          Jan 22 18:04:04 pi hass[744]: 2018-01-22 18:04:04 DEBUG (Thread-2) [mysensors.gateway_mqtt] Receiving 6;255;3;0;12;1.0
          Jan 22 18:04:04 pi hass[744]: 2018-01-22 18:04:04 DEBUG (Thread-4) [mysensors.gateway_mqtt] Receiving 6;1;0;0;4;
          Jan 22 18:04:04 pi hass[744]: 2018-01-22 18:04:04 DEBUG (Thread-7) [mysensors.gateway_mqtt] Receiving 6;1;1;0;3;100
          Jan 22 18:04:04 pi hass[744]: 2018-01-22 18:04:04 DEBUG (Thread-13) [homeassistant.components.mysensors] Node update: node 6 child 255
          Jan 22 18:04:04 pi hass[744]: 2018-01-22 18:04:04 DEBUG (Thread-13) [homeassistant.components.mysensors] Not a child update for node 6
          Jan 22 18:04:04 pi hass[744]: 2018-01-22 18:04:04 WARNING (Thread-13) [mysensors] child_id 1 already exists in children of node 6, cannot add child
          Jan 22 18:04:04 pi hass[744]: 2018-01-22 18:04:04 DEBUG (Thread-13) [homeassistant.components.mysensors] Node update: node 6 child 1
          Jan 22 18:04:04 pi hass[744]: 2018-01-22 18:04:04 WARNING (Thread-13) [homeassistant.components.mysensors] Invalid values: {3: '100'}: light platform: node 6 child 1: S_DIMMER requires value_type V_STATUS @ data[2]
          Jan 22 18:04:04 pi hass[744]: 2018-01-22 18:04:04 DEBUG (Thread-10) [mysensors.gateway_mqtt] Receiving 6;255;0;0;17;2.2.0-beta
          Jan 22 18:04:04 pi hass[744]: 2018-01-22 18:04:04 DEBUG (Thread-8) [mysensors.gateway_mqtt] Receiving 6;255;3;0;6;0
          Jan 22 18:04:04 pi hass[744]: 2018-01-22 18:04:04 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_call_id=1972866000-42, domain=mqtt, service=publish, service_data=payload=M, topic=mysensors-in/6/255/3/0/6, qos=0, retain=True>
          Jan 22 18:04:04 pi hass[744]: 2018-01-22 18:04:04 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=1972866000-42>
          Jan 22 18:04:05 pi hass[744]: 2018-01-22 18:04:05 INFO (MainThread) [homeassistant.components.http] Serving /api/camera_proxy/camera.balcony to 192.168.10.6 (auth: True)
          Jan 22 18:04:05 pi hass[744]: 2018-01-22 18:04:05 INFO (MainThread) [homeassistant.components.http] Serving /api/camera_proxy/camera.cellar to 192.168.10.6 (auth: True)
          Jan 22 18:04:12 pi hass[744]: 2018-01-22 18:04:12 INFO (MainThread) [homeassistant.components.http] Serving /description.xml to 192.168.10.211 (auth: True)
          Jan 22 18:04:15 pi hass[744]: 2018-01-22 18:04:15 INFO (MainThread) [homeassistant.components.http] Serving /api/camera_proxy/camera.balcony to 192.168.10.6 (auth: True)
          Jan 22 18:04:15 pi hass[744]: 2018-01-22 18:04:15 INFO (MainThread) [homeassistant.components.http] Serving /api/camera_proxy/camera.cellar to 192.168.10.6 (auth: True)
          • A
            A
            alterfritz
            That one seems wrong - but if possible I simply want to switch on / off the lights, no dimmer needed if I can avoid flashing the sensors again.
              What code did you flash on the node? BTW, are you sure you used the development version? You wrote version 2.1.1 while it should be 2.2
              • A
                A
                alterfritz
                Correct - I flashed it some time ago - actually I detect 1 min. ago if I remove some parts of the config ...
                customize:
                light.WallLight1_1_1:
                friendly_name: WallLight 1
                light.WallLight6_6_1:
                friendly_name: WallLight 2
                light.WallLight3_3_1:
                friendly_name: WallLight 3
                light.WallLight4_4_1:
                friendly_name: WallLight 4
                light.WallLight5_5_1:
                friendly_name: WallLight 5
                group.Wall_Lights:
                friendly_name: Wandleuchten
                the light appear ... I think I can get it working.
                • martinhjelmareM
                  martinhjelmareM
                  martinhjelmare
                  A child device represented by S_DIMMER requires both V_PERCENTAGE and V_STATUS in home assistant. This is mentioned here:
                  https://home-assistant.io/components/light.mysensors/
                  So you need to send initial values of both V_PERCENTAGE and V_STATUS, and update those value types when state changes, to have an operating device.
                  If you only need on/off you should present a S_BINARY child device with V_STATUS value type. This will be a switch in home assistant:
                  https://home-assistant.io/components/switch.mysensors/
                  • A
                    A
                    alterfritz
                    Thanks. I will do that...
