  3. Home Assistant
  4. MySensors lights not functioning correctly since upgrade to 0.61.1
6 Posts 3 Posters 2.2k Views 3 Watching
  • D
    D
    drock1985
    I've been using MySensors for a while now in their present hardware/software configuration with no problems running lights (relays), temp sensors, etc up until recently. I upgrade my HASS.IO install of home-assistant to 0.61.1 and ever since then I have not been able to get any of my light actuators to respond to commands from the UI. I do not know what is going on; and having not changed anything I do not think it's on my end. Was wondering what it could be? I connect to MySensors using a USB-Serial gateway.
    My Projects
    2 Door Chime Sensor
    Washing Machine Monitor
    • martinhjelmareM
      martinhjelmareM
      martinhjelmare
      Nothing has changed in the mysensors component lately. I don't know what Hass.io could have done to affect mysensors.
      Which was the last release of home assistant and Hass.io that worked properly? We need more info to pinpoint this.
      D 1 Reply Last reply
        D
        D
        drock1985
        @martinhjelmare Hi,
        The last version that worked correctly was 0.60.1; no issues at all. All other actuators seem to work fine too (Hue, ESP8266, Wemo, etc)
        My Projects
        2 Door Chime Sensor
        • D
          D
          drock1985
          Is there any logs I can look through to find a solution?
          My Projects
          2 Door Chime Sensor
          • D
            D
            drock1985
            Damn; I think I may have just fixed it. Changed USB ports......
            My Projects
            2 Door Chime Sensor
            • pepsonP
              pepsonP
              pepson
              wrote on last edited by pepson
              I have similary problem...
              https://forum.mysensors.org/topic/9046/mysensors-ethernet-2-2-0-problem-with-control-node-switches
              Anybody can help me please ?
