  3. [Resolved] accept: Bad file descriptor
4 Posts 3 Posters 3.0k Views 3 Watching
  • Suresh MaliS Offline
    Suresh Mali
    wrote on last edited by Suresh Mali
    I build a Gateway on Rpi. Post build it was working fine. I reboot and it stops working. Unable to interpret what this means. Please help. I did go through the forum but not able to solve it. I am using the latest 2.2.0 release. I ruled out hardware and radio issues as one of my node was able to communicate and send messages.
    Any help would be appreciated.
    pi@myhome:~/MySensors $ sudo ./bin/mysgw -d
    mysgw: Starting gateway...
    mysgw: Protocol version - 2.2.0
    mysgw: MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: bind: Address already in use
    mysgw: Failed to bind!
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    mysgw: accept: Bad file descriptor
      That's probably because the service is running in background. Type sudo service mysgw stop then the command you used
      • Suresh MaliS Suresh Mali
        mysgw: TSF:LRT:OK
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: MCO:BGN:STP
        @suresh-mali said in accept: Bad file descriptor:
        This means something else is already listening on the same port. My guess is that another instance of the gateway has already been started, or some other program is using the same port.
        You can use netstat -l -p to see the process id of the program that is already using the port.
          Suresh Mali
          Thanks @mfalkvidd and @gohan . That helped.
