  3. Compile error
Compile error
7 Posts 3 Posters 1.8k Views 3 Watching
  • C Offline
    C Offline
    carpov
    Re: Water Flow sensor
    HI there
    I've got problem with scatch posted above. I've got error after compiling:
    C:\Users\Jacek\Documents\Arduino\libraries\MySensors/MySensors.h:328:2: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
    exit status 1
    Compile error for Arduino/Genuino Uno.``
    `Any ideas?
      you need to enable one the following defines
      //#define MY_RADIO_NRF5_ESB
      //#define MY_RADIO_RFM95
      • C Offline
        C Offline
        carpov
        Nothing change to me.
        I put
        #define MY_GATEWAY_SERIAL (I use usb connection)
        Error still occure :(
          wrote on last edited by gohan
          wait a second? Are making a gateway without radio or a node?
          check that #define MY_GATEWAY_SERIAL is written before #include <MySensors.h>?
          • C Offline
            C Offline
            carpov
            Hi there
            Yes I made gateway without radio. I need connect hallefect flow sensor to Domoticz.
            I use Arduino (as node) connected to RPi (controller) via USB cable.
            I already have good working skatch - measure water flow with 5% accuracy. Now I need to add gatewy feature to that sketch.
            I found similar skatch (TESTING SKATCH) in web https://forum.mysensors.org/topic/1282/water-flow-sensor/2
            and I wanted to check this solution. I need only current flow, i don't need counter.
            I checked and change positions of #define MY_GATEWAY_SERIAL and #include <MySensors.h>.
            now MY_GATEWAY is before MySensors.h...............and I have new error
            sketch_mar26a:17: error: 'MySensor' does not name a type
            C:\Users\Jacek\Desktop\sketch_mar26a\sketch_mar26a.ino: In function 'void setup()':
            sketch_mar26a:26: error: 'gw' was not declared in this scope
               gw.begin();
            C:\Users\Jacek\Desktop\sketch_mar26a\sketch_mar26a.ino: In function 'void loop()':
            sketch_mar26a:56: error: 'gw' was not declared in this scope
                   gw.send(flowMsg.set(flow));
            exit status 1
            'MySensor' does not name a type```
            And this is my TESTING sketch
            Insert Code Here
            ```#define MY_GATEWAY_SERIAL
            #define DIGITAL_INPUT_SENSOR 3                  // The digital input you attached your sensor.  (Only 2 and 3 generates interrupt!)
            #define SENSOR_INTERRUPT DIGITAL_INPUT_SENSOR-2        // Usually the interrupt = pin -2 (on uno/nano anyway)
            #define CHILD_ID 1                              // Id of the sensor child
            int READ_INTERVAL = 3;           // Read interval to count the pulses (in seconds).
            long lastReadStart;
            int flow;
            MyMessage flowMsg(CHILD_ID,V_FLOW);
            int READ_INTERVAL_MILLIS=READ_INTERVAL * 1000;        // Just to simple the math!
              gw.begin();
              gw.sendSketchInfo("Water Meter", "1.2");
              // Register this device as Waterflow sensor
              gw.present(CHILD_ID, S_WATER);
              pulseCount = 0;
              lastReadStart = millis();
              attachInterrupt(SENSOR_INTERRUPT, onPulse, RISING);
              unsigned long currentTime = millis();
              if (currentTime - lastReadStart > READ_INTERVAL_MILLIS)
                flow = pulseCount*60/READ_INTERVAL;  //Need to change here for the G type
                lastReadStart=currentTime;
                  Serial.print("l/hour:");
                  Serial.println(flow);
                  pulseCount = 0;
            void onPulse()
              pulseCount++;
              That example was written for MySensors 1.5. There is a post with instructions to convert code for MySensors 2.x
              • mfalkviddM Offline
                https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x
