  3. [SOLVED] MySensors FOTA - Bare ATMega328p
2 Posts 1 Posters 1.3k Views 1 Watching
  • R
    R
    Robbie_
    I want to know if it is possible to upload firmware to a Bare ATMega328p working with MYSController (FOTA).
    Im using the latest Mysbootloader from https://github.com/mysensors/MySensorsBootloaderRF24
    This is the result i get from the Bare ATMega flash (0A...FFFFF..)..
    After a few tries it just continues normal booting procedure
    I use this firmware also on an Arduino Pro mini where FOTA works.
    Can someone give me some advice?
    Thank you in advance.
    Edit:
    Just tried a fresh bare atmega, same result :-(
    This is the boards.txt i'm using;
    MYSBLMOD.name=ATmega328 with MYSBootloader 1.3.0 8 MHz (2018/01)
    MYSBLMOD.upload.tool=arduino:avrdude
    MYSBLMOD.upload.protocol=arduino
    MYSBLMOD.upload.maximum_size=30720
    MYSBLMOD.upload.maximum_data_size=2048
    MYSBLMOD.bootloader.tool=arduino:avrdude
    MYSBLMOD.bootloader.unlock_bits=0x3F
    MYSBLMOD.bootloader.lock_bits=0x0F
    MYSBLMOD.build.mcu=atmega328p
    MYSBLMOD.build.board=AVR_PRO
    MYSBLMOD.build.core=arduino:arduino
    MYSBLMOD.build.variant=arduino:standard
    MYSBLMOD.f_cpu=8000000L
    MYSBLMOD.upload.speed=57600
    MYSBLMOD.bootloader.low_fuses=0xE2
    MYSBLMOD.bootloader.high_fuses=0xD2
    MYSBLMOD.bootloader.extended_fuses=0x06
    MYSBLMOD.build.f_cpu=8000000L
    MYSBLMOD.bootloader.file=MySensors/MYSBootloader_8MHz.hex
    • R
      R
      Robbie_
      Nevermind i fixed it! had something to do with my radio...
      Driving me nuts :-)
      #lovemysensors!!
      can close this topic when needed
