  3. GUVA-S12SD UV sensor sketch
2 Posts 1 Posters 1.3k Views 1 Watching
  • T
    tonbor
    Re: [0_1534265394169_UVSensor.ino](Uploading 100%) GUVA-S12SD UV sensor sketch required
    [0_1534265424506_UVSensor.ino](Uploading 100%)
    T 1 Reply Last reply
    • T tonbor
      tonbor
      wrote on last edited by tonbor
      • DESCRIPTION
      • Sensor: CJMCU-GUVA-S12SD/CJMCU-S12D
      • Sensor Arduino
      • SIG -> A0
      • GND -> GND
      • VCC -> 5V or 3.3v
      • part created by Henrik Ekblad henrik.ekblad@mysensors.org
      • Copyright (C) 2013-2015 Sensnology AB
      • Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
      • part Original link : CSDN 博客链接.
      • part by Tonbor august 2018
      //#define MY_RADIO_NRF5_ESB
      //#define MY_RADIO_RFM95
      #define UV_SENSOR_ANALOG_PIN 0
      #define CHILD_ID_UV 0
      uint32_t SLEEP_TIME = 30*1000; // Sleep time between reads (in milliseconds)
      MyMessage uvMsg(CHILD_ID_UV, V_UV);
      int lastSend =0;
      int sensorValue;
      long sum = 0;
      int vout = 0;
      int uv = 0;
      int lastUV = -1;
      sendSketchInfo("UV Sensor", "1.3");
      present(CHILD_ID_UV, S_UV);
      Serial.begin(115000);
      uint32_t currentTime = millis();
      sensorValue = 0;
      sum = 0;
      for (int i = 0 ; i < 1024 ; i++ ) {
      sensorValue = analogRead(UV_SENSOR_ANALOG_PIN);
      sum = sensorValue + sum;
      delay(2);
      vout = sum >> 10;
      vout = vout * 4980.0 / 1024;
      Serial.print("The Photocurrent value:");
      Serial.print(vout);
      Serial.println("mV");
      if (vout < 50) {
      uv = 0;
      else if (vout < 227) {
      uv = 1;
      else if (vout < 318) {
      uv = 2;
      else if (vout < 408) {
      uv = 3;
      else if (vout < 503) {
      uv = 4;
      else if (vout < 606) {
      uv = 5;
      else if (vout < 696) {
      uv = 6;
      else if (vout < 795) {
      uv = 7;
      else if (vout < 881) {
      uv = 8;
      else if (vout < 976) {
      uv = 9;
      else if (vout < 1079) {
      uv = 10;
      else {
      uv = 11;
      //Send value to gateway if changed, or at least every 5 minutes
      if ((uv != lastUV)||(currentTime-lastSend >= 5UL*60UL*1000UL)) {
      	lastSend=currentTime;
      	send(uvMsg.set(uv));
      	lastUV = uv;
      sleep(SLEEP_TIME);
