  3. Delay after TSF:TRI:TSB
19 Posts 5 Posters 4.4k Views 4 Watching
  • faustiF Offline
    faustiF Offline
    fausti
    Hi I’ve build an Motion+Light Sensor (connected to openHab) and it works pretty well, except that there is a tiny delay (1-2 sec) between waking up and sending the message – which is a bit of a pain, since e.g. connected lights will turn on with an delay.
    What I found out is, that the reason for the delay lies in the sensor itself – so no problems with the gateway. In the DEBUG of the sensor you can see TSF:TRI:TSB, and right there the sensor stops for about 1-2 seconds before sending it’s msg. (see picture below):
    Do I need to change somthing in "MyTransport" in order to get rid of this delay -> “TSB “ (Set transport to standby)? https://www.mysensors.org/apidocs-beta/group__MyTransportgrp.html#ga2c5750b886bd43338e04cd4cb132e589
    Or is there any other way - maybe I'm missing something (sketch down below).
    Hope You can help - many thanks in advance 🙂
     * MySensors node configuration
    // General settings
    #define SKETCH_NAME "Testo"
    #define SKETCH_VERSION "2.0"
    // NRF24 radio settings
    //#define MY_SIGNING_SIMPLE_PASSWD 1234
    // Advanced settings
    #define MY_BAUD_RATE 9600
     * NodeManager modules for supported sensors
    #define USE_ANALOG_INPUT
    #define USE_INTERRUPT
     * NodeManager built-in features
    // Enable/disable NodeManager's features
    #define FEATURE_DEBUG ON
    #define FEATURE_POWER_MANAGER ON
    #define FEATURE_INTERRUPTS ON
    #define FEATURE_CONDITIONAL_REPORT OFF
    #define FEATURE_EEPROM OFF
    #define FEATURE_SLEEP ON
    #define FEATURE_RECEIVE OFF
    #define FEATURE_TIME OFF
    #define FEATURE_RTC OFF
    #define FEATURE_SD OFF
    #define FEATURE_HOOKING OFF
     * Load NodeManager Library
    #include "NodeManagerLibrary.h"
    NodeManager node;
     * Add your sensors below
    // built-in sensors
    PowerManager power(5,6,0);
    // Attached sensors
    SensorMotion motion(node,3);
    SensorLDR ldr(node,A0);
     * Main Sketch
    // before
    void before() {
      // setup the serial port baud rate
      Serial.begin(MY_BAUD_RATE);
      * Configure your sensors below
      node.setReportIntervalSeconds(60);
      node.setSleepDays(1);
      * Configure your sensors above
      node.before();
    // presentation
    void presentation() {
      // call NodeManager presentation routine
      node.presentation();
    // setup
      // call NodeManager setup routine
      node.setup();
    // loop
      // call NodeManager loop routine
      node.loop();
    #if FEATURE_RECEIVE == ON
    // receive
      // call NodeManager receive routine
      node.receive(message);
    #if FEATURE_TIME == ON
    // receiveTime
    void receiveTime(unsigned long ts) {
      // call NodeManager receiveTime routine
      node.receiveTime(ts);
    • faustiF fausti
      // General settings
      NodeManager node;
      // built-in sensors
      // Attached sensors
       * Main Sketch
      // before
      void before() {
        node.before();
      // presentation
      // setup
        node.setup();
      // loop
        node.loop();
      // receive
      // receiveTime
      @fausti the line after indicated NACK. This means that the node did not get acknowledgement from the next node (usually the gateway). The node can't print the nack message until after it has tried and gotten timeout several times. That's why it takes some time. The first send attempt starts much earlier.
      faustiF 1 Reply Last reply
        faustiF Offline
        faustiF Offline
        fausti
        wrote on last edited by fausti
        @mfalkvidd many thanks for the quick answer! :-)
        Weirdly this behaviour only shows when I'm using the sleep mode. Also first time NACK appears is after the first Sleep - DEBUG after reset below, NACK at 8437. Any idea what i'm doing wrong or where i could fix it? :grimacing: :grimacing: many thanks in advance 🙂
        ⸮:⸮5 V=6
        0 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.3.0
        53 MCO:BGN:BFR
        NodeManager v1.7
        LIB V=2.3.0 R=N E=- T=N A=A S=- B=-
        MOTION I=1 P=1 T=16
        LDR I=2 P=16 T=23
        RADIO...108 TSM:INIT
        190 TSF:WUR:MS=0
        215 TSM:INIT:TSP OK
        235 TSF:SID:OK,ID=9
        256 TSM:FPAR
        305 TSF:MSG:SEND,9-9-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        2377 !TSM:FPAR:NO REPLY
        2402 TSM:FPAR
        2451 TSF:MSG:SEND,9-9-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        3278 TSF:MSG:READ,0-0-9,s=255,c=3,t=8,pt=1,l=1,sg=0:0
        3334 TSF:MSG:FPAR OK,ID=0,D=1
        4526 TSM:FPAR:OK
        4542 TSM:ID
        4556 TSM:ID:OK
        4571 TSM:UPL
        4589 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
        4661 TSF:MSG:READ,0-0-9,s=255,c=3,t=25,pt=1,l=1,sg=0:1
        4718 TSF:MSG:PONG RECV,HP=1
        4747 TSM:UPL:OK
        4765 TSM:READY:ID=9,PAR=0,DIS=1
        4802 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
        4876 TSF:MSG:READ,0-0-9,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        4941 TSF:MSG:SEND,9-9-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.0
        5021 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
        5091 TSF:MSG:READ,0-0-9,s=255,c=3,t=6,pt=0,l=1,sg=0:M
        OK
        5152 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=11,pt=0,l=5,sg=0,ft=0,st=OK:Testo
        5232 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:2.0
        PRES I=1 T=1 D=MOTION
        5310 TSF:MSG:SEND,9-9-0-0,s=1,c=0,t=1,pt=0,l=6,sg=0,ft=0,st=OK:MOTION
        PRES I=2 T=16 D=LDR
        5406 TSF:MSG:SEND,9-9-0-0,s=2,c=0,t=16,pt=0,l=3,sg=0,ft=0,st=OK:LDR
        READY
        5494 MCO:REG:REQ
        5525 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
        5597 TSF:MSG:READ,0-0-9,s=1,c=0,t=1,pt=0,l=6,sg=0:MOTION
        5656 TSF:MSG:ACK
        5675 TSF:MSG:READ,0-0-9,s=2,c=0,t=16,pt=0,l=3,sg=0:LDR
        5732 TSF:MSG:ACK
        5750 TSF:MSG:READ,0-0-9,s=255,c=3,t=27,pt=1,l=1,sg=0:1
        5808 MCO:PIM:NODE REG=1
        5832 MCO:BGN:STP
        MY I=9 M=1
        INT P=3 M=1
        INT P=2 M=255
        5853 MCO:BGN:INIT OK,TSP=1
        LDR I=2 V=60 %=5
        SEND D=0 I=2 C=0 T=23 S= I=0 F=0.00
        5928 TSF:MSG:SEND,9-9-0-0,s=2,c=1,t=23,pt=5,l=4,sg=0,ft=0,st=OK:5
        SLEEP 20864s
        6047 MCO:SLP:MS=20864000,SMS=1,I1=1,M1=1,I2=255,M2=255
        6125 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
        6199 TSF:MSG:READ,0-0-9,s=2,c=1,t=23,pt=5,l=4,sg=0:5
        6254 TSF:MSG:ACK
        6699 TSF:TDI:TSL
        6717 MCO:SLP:WUP=1
        6735 TSF:TRI:TSB
        8437 !TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=NACK:20864000
        INT P=3, V=1
        AWAKE
        MOTION I=1 P=3 V=1
        SEND D=0 I=1 C=0 T=16 S= I=0 F=0.00
        8536 TSF:MSG:SEND,9-9-0-0,s=1,c=1,t=16,pt=5,l=4,sg=0,ft=1,st=OK:1
        LDR I=2 V=59 %=5
        8675 TSF:MSG:SEND,9-9-0-0,s=2,c=1,t=23,pt=5,l=4,sg=0,ft=0,st=OK:5
        SLEEP 20864s
        8796 MCO:SLP:MS=20864000,SMS=1,I1=1,M1=1,I2=255,M2=255
        8869 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
        8943 TSF:MSG:READ,0-0-9,s=1,c=1,t=16,pt=5,l=4,sg=0:1
        8998 TSF:MSG:ACK
        9017 TSF:MSG:READ,0-0-9,s=2,c=1,t=23,pt=5,l=4,sg=0:5
        9072 TSF:MSG:ACK
        9443 TSF:TDI:TSL
        9459 MCO:SLP:WUP=1
        9480 TSF:TRI:TSB
        11180 !TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=NACK:20864000
        INT P=3, V=0
        AWAKE
        MOTION I=1 P=3 V=0
        11280 TSF:MSG:SEND,9-9-0-0,s=1,c=1,t=16,pt=5,l=4,sg=0,ft=1,st=OK:0
        LDR I=2 V=60 %=5
        11421 TSF:MSG:SEND,9-9-0-0,s=2,c=1,t=23,pt=5,l=4,sg=0,ft=0,st=OK:5
        SLEEP 20864s
        11542 MCO:SLP:MS=20864000,SMS=1,I1=1,M1=1,I2=255,M2=255
        11620 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
        11696 TSF:MSG:READ,0-0-9,s=1,c=1,t=16,pt=5,l=4,sg=0:0
        11751 TSF:MSG:ACK
        11771 TSF:MSG:READ,0-0-9,s=2,c=1,t=23,pt=5,l=4,sg=0:5
        11827 TSF:MSG:ACK
        12197 TSF:TDI:TSL
        Here the DEBUG if I exclude sleep (to --> //node.setSleepDays(1);) - then the sensor sends it's msg. fast and happily..
        ⸮:⸮5 V=6
        53 MCO:BGN:BFR
        NodeManager v1.7
        MOTION I=1 P=1 T=16
        LDR I=2 P=16 T=23
        190 TSF:WUR:MS=0
        215 TSM:INIT:TSP OK
        235 TSF:SID:OK,ID=9
        256 TSM:FPAR
        376 TSF:MSG:READ,0-0-9,s=255,c=3,t=8,pt=1,l=1,sg=0:0
        432 TSF:MSG:FPAR OK,ID=0,D=1
        2377 TSM:FPAR:OK
        2394 TSM:ID
        2408 TSM:ID:OK
        2422 TSM:UPL
        2441 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
        2512 TSF:MSG:READ,0-0-9,s=255,c=3,t=25,pt=1,l=1,sg=0:1
        2570 TSF:MSG:PONG RECV,HP=1
        2598 TSM:UPL:OK
        2617 TSM:READY:ID=9,PAR=0,DIS=1
        2654 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
        2727 TSF:MSG:READ,0-0-9,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        2793 TSF:MSG:SEND,9-9-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.0
        2873 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
        2942 TSF:MSG:READ,0-0-9,s=255,c=3,t=6,pt=0,l=1,sg=0:M
        OK
        3035 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=11,pt=0,l=5,sg=0,ft=0,st=OK:Testo
        3112 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:2.0
        3190 TSF:MSG:SEND,9-9-0-0,s=1,c=0,t=1,pt=0,l=6,sg=0,ft=0,st=OK:MOTION
        PRES I=2 T=16 D=LDR
        3289 TSF:MSG:SEND,9-9-0-0,s=2,c=0,t=16,pt=0,l=3,sg=0,ft=0,st=OK:LDR
        READY
        3377 MCO:REG:REQ
        3407 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
        3479 TSF:MSG:READ,0-0-9,s=255,c=3,t=27,pt=1,l=1,sg=0:1
        3536 MCO:PIM:NODE REG=1
        3561 MCO:BGN:STP
        MY I=9 M=1
        INT P=3 M=1
        INT P=2 M=255
        3581 MCO:BGN:INIT OK,TSP=1
        LDR I=2 V=57 %=5
        3657 TSF:MSG:SEND,9-9-0-0,s=2,c=1,t=23,pt=5,l=4,sg=0,ft=0,st=OK:5
        INT P=3, V=1
        MOTION I=1 P=3 V=1
        8374 TSF:MSG:SEND,9-9-0-0,s=1,c=1,t=16,pt=5,l=4,sg=0,ft=0,st=OK:1
        INT P=3, V=0
        MOTION I=1 P=3 V=0
        12304 TSF:MSG:SEND,9-9-0-0,s=1,c=1,t=16,pt=5,l=4,sg=0,ft=0,st=OK:0
        • faustiF fausti
          ⸮:⸮5 V=6
          53 MCO:BGN:BFR
          NodeManager v1.7
          MOTION I=1 P=1 T=16
          LDR I=2 P=16 T=23
          190 TSF:WUR:MS=0
          215 TSM:INIT:TSP OK
          235 TSF:SID:OK,ID=9
          256 TSM:FPAR
          2402 TSM:FPAR
          4526 TSM:FPAR:OK
          4542 TSM:ID
          4556 TSM:ID:OK
          4571 TSM:UPL
          4747 TSM:UPL:OK
          OK
          PRES I=2 T=16 D=LDR
          READY
          5494 MCO:REG:REQ
          5656 TSF:MSG:ACK
          5732 TSF:MSG:ACK
          5832 MCO:BGN:STP
          MY I=9 M=1
          INT P=3 M=1
          INT P=2 M=255
          LDR I=2 V=60 %=5
          SLEEP 20864s
          6254 TSF:MSG:ACK
          6699 TSF:TDI:TSL
          6717 MCO:SLP:WUP=1
          6735 TSF:TRI:TSB
          INT P=3, V=1
          AWAKE
          MOTION I=1 P=3 V=1
          LDR I=2 V=59 %=5
          SLEEP 20864s
          8998 TSF:MSG:ACK
          9072 TSF:MSG:ACK
          9443 TSF:TDI:TSL
          9459 MCO:SLP:WUP=1
          9480 TSF:TRI:TSB
          INT P=3, V=0
          AWAKE
          MOTION I=1 P=3 V=0
          LDR I=2 V=60 %=5
          SLEEP 20864s
          11751 TSF:MSG:ACK
          11827 TSF:MSG:ACK
          12197 TSF:TDI:TSL
          ⸮:⸮5 V=6
          53 MCO:BGN:BFR
          NodeManager v1.7
          MOTION I=1 P=1 T=16
          LDR I=2 P=16 T=23
          190 TSF:WUR:MS=0
          215 TSM:INIT:TSP OK
          235 TSF:SID:OK,ID=9
          256 TSM:FPAR
          2377 TSM:FPAR:OK
          2394 TSM:ID
          2408 TSM:ID:OK
          2422 TSM:UPL
          2598 TSM:UPL:OK
          OK
          PRES I=2 T=16 D=LDR
          READY
          3377 MCO:REG:REQ
          3561 MCO:BGN:STP
          MY I=9 M=1
          INT P=3 M=1
          INT P=2 M=255
          LDR I=2 V=57 %=5
          INT P=3, V=1
          MOTION I=1 P=3 V=1
          INT P=3, V=0
          MOTION I=1 P=3 V=0
          @fausti sorry, I don't know what nodemanager does behind the scene so there isn't really a way for me to troubleshoot.
          What is powered through pin 6?
            faustiF Offline
            faustiF Offline
            fausti
            @mfalkvidd thanks again!! :-)
            Yeah.. went through the whole NodeManager Library, tried many things, but couldn’t find the reason for this behaviour. probably I must build my sketch again on foot – without NodeManager, hoped it could save me some time. ^^
            PIN 6 powers an LDR together with PIN 5, read by PIN A0. But when I exclude all corresponding parts and even remove the hardware (10k + LDR) it won’t help.
            Oddly sleeping Time (MCO:SLP:MS=20864000 has the same value as the number after NACK (st=NACK:20864000). If I change the sleep time (e.g. from 1 day to 60 sec) both values are changing equally to the equivalent value in ms.
            @henrik-nielsen had a similar problem (maybe the same) https://forum.mysensors.org/topic/9598/smartsleep-wake-up-message-always-get-nack
            Later I’ll try the fix described by @berkseo.
            Thanks! :grinning:
            Y mfalkviddM 2 Replies Last reply
            • faustiF fausti
              Thanks! :grinning:
              Y Offline
              Y Offline
              @fausti are you using an amplified nrf24 pa+lna module by any chance?
              • faustiF fausti
                Thanks! :grinning:
                @fausti interesting that the sleep and the nack has the same value. Maybe something gets overwritten in memory.
                T 1 Reply Last reply
                  T Offline
                  T Offline
                  tekka
                  @mfalkvidd @fausti no, this is normal the smartsleep log:
                  ==> smart sleep enabled, IRQ on pin 1 set, going to sleep for 20864000 ms
                  ==> I_PRE_SLEEP_NOTIFICATION, 500ms to process any incoming message before going to seep
                  6254 TSF:MSG:ACK
                  6699 TSF:TDI:TSL
                  6717 MCO:SLP:WUP=1
                  6735 TSF:TRI:TSB
                  ==> sleep interrupted by IRQ 1
                  ==> I_POST_SLEEP_NOTIFICATION, node was sleeping for 20864000ms (but sleep was interrupted)
                  • T tekka
                    6254 TSF:MSG:ACK
                    6699 TSF:TDI:TSL
                    6717 MCO:SLP:WUP=1
                    6735 TSF:TRI:TSB
                    T Offline
                    T Offline
                    tekka
                    ...but, the delay between TSB and SEND is a bit odd;
                    9480 TSF:TRI:TSB
                    Enabling MY_DEBUG_VERBOSE_RF24 could eventually give some hints.
                    • T tekka
                      9480 TSF:TRI:TSB
                      T Offline
                      T Offline
                      tekka
                      FYI: I tried with both, 2.3.0 and 2.3.1-beta (incl. CE fix), on non-amplified and PA+LNA modules - I do not see any delay between TSB and SEND
                      6973 MCO:SLP:MS=5000,SMS=1,I1=1,M1=1,I2=255,M2=255
                      6979 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
                      7486 TSF:TDI:TSL
                      7487 MCO:SLP:WUP=1
                      7489 TSF:TRI:TSB
                      7492 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:5000
                      I assume you have a power issue, a bad module - or an artifact originating from the nodemanager?
                      • faustiF Offline
                        faustiF Offline
                        fausti
                        @Yveaux sensor is using standard NRF24L01+ (only the gw uses pa+lna - but I guess that won't be an issue?)
                        @tekka did you use the same sketch? You mentioned smartsleep, I haven't enabled that.. I'll try MY_DEBUG_VERBOSE_RF24 later, use a fresh NodeManager and will check all my hardware again and I still have to try that fix: https://forum.mysensors.org/topic/9598/smartsleep-wake-up-message-always-get-nack
                        I've build more than one sensor and all of them are showing that delay - using different power sources and I also tried different capacitor. Maybe after all it's the gw.. but can't think of a reason why sleeping would cause that behavior at gw.
                        I'll report later - Thanks for the quick help!!
                        T 2 Replies Last reply
                        • faustiF fausti
                          T Offline
                          T Offline
                          tekka
                          @fausti the log indicates that smartsleep is enabled - that said, smartsleep may originate from the nodemanager
                          • faustiF fausti
                            T Offline
                            T Offline
                            tekka
                            @fausti Can you re-test your setup with this patch (ideally, update GW and nodes): https://github.com/tekka007/MySensors/tree/RF24STDBYTiming - I've added a delay after setting the radio in standby mode.
                            • T tekka
                              faustiF Offline
                              faustiF Offline
                              fausti
                              @tekka WOW!! Your fix works like a dream - can't thank you enough! :pray: :tada:
                              For now I just used your patch at the sensor - but it allready runs perfectly - no lag/no NACK (see DEBUG below).
                              So the radio needs more time to settle? How long did you set the delay?
                              Many many thanks to @tekka and to you all for helping that fast and professional!!
                              [For so many hours I tried figuring out where the problem lies.. at least I know that library better now ^^ ]
                              0 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.3.1-beta
                              59 MCO:BGN:BFR
                              NodeManager v1.7
                              LIB V=2.3.1-beta R=N E=- T=N A=A S=- B=-
                              MOTION I=1 P=1 T=16
                              LDR I=2 P=16 T=23
                              RADIO...118 TSM:INIT
                              200 TSF:WUR:MS=0
                              223 TSM:INIT:TSP OK
                              245 TSF:SID:OK,ID=9
                              266 TSM:FPAR
                              315 TSF:MSG:SEND,9-9-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                              1208 TSF:MSG:READ,0-0-9,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                              1265 TSF:MSG:FPAR OK,ID=0,D=1
                              2390 TSM:FPAR:OK
                              2406 TSM:ID
                              2420 TSM:ID:OK
                              2435 TSM:UPL
                              2453 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                              2525 TSF:MSG:READ,0-0-9,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                              2582 TSF:MSG:PONG RECV,HP=1
                              2611 TSM:UPL:OK
                              2629 TSM:READY:ID=9,PAR=0,DIS=1
                              2666 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                              2740 TSF:MSG:READ,0-0-9,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                              2805 TSF:MSG:SEND,9-9-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.3.1-beta
                              2891 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                              2961 TSF:MSG:READ,0-0-9,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                              OK
                              3022 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=11,pt=0,l=5,sg=0,ft=0,st=OK:Testo
                              3102 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:2.0
                              3180 TSF:MSG:SEND,9-9-0-0,s=1,c=0,t=1,pt=0,l=6,sg=0,ft=0,st=OK:MOTION
                              PRES I=2 T=16 D=LDR
                              3276 TSF:MSG:SEND,9-9-0-0,s=2,c=0,t=16,pt=0,l=3,sg=0,ft=0,st=OK:LDR
                              READY
                              3364 MCO:REG:REQ
                              3395 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                              3467 TSF:MSG:READ,0-0-9,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                              3524 MCO:PIM:NODE REG=1
                              3551 MCO:BGN:STP
                              MY I=9 M=1
                              INT P=3 M=1
                              INT P=2 M=255
                              3569 MCO:BGN:INIT OK,TSP=1
                              LDR I=2 V=302 %=29
                              3645 TSF:MSG:SEND,9-9-0-0,s=2,c=1,t=23,pt=5,l=4,sg=0,ft=0,st=OK:29
                              SLEEP 20864s
                              3768 MCO:SLP:MS=20864000,SMS=1,I1=1,M1=1,I2=255,M2=255
                              3846 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
                              4419 TSF:TDI:TSL
                              4435 MCO:SLP:WUP=1
                              4456 TSF:TRI:TSB
                              4483 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:20864000
                              INT P=3, V=1
                              AWAKE
                              MOTION I=1 P=3 V=1
                              4579 TSF:MSG:SEND,9-9-0-0,s=1,c=1,t=16,pt=5,l=4,sg=0,ft=0,st=OK:1
                              LDR I=2 V=284 %=27
                              4718 TSF:MSG:SEND,9-9-0-0,s=2,c=1,t=23,pt=5,l=4,sg=0,ft=0,st=OK:27
                              SLEEP 20864s
                              4841 MCO:SLP:MS=20864000,SMS=1,I1=1,M1=1,I2=255,M2=255
                              4919 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
                              5494 TSF:TDI:TSL
                              5511 MCO:SLP:WUP=1
                              5531 TSF:TRI:TSB
                              5558 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:20864000
                              INT P=3, V=0
                              AWAKE
                              MOTION I=1 P=3 V=0
                              5654 TSF:MSG:SEND,9-9-0-0,s=1,c=1,t=16,pt=5,l=4,sg=0,ft=0,st=OK:0
                              LDR I=2 V=295 %=28
                              5793 TSF:MSG:SEND,9-9-0-0,s=2,c=1,t=23,pt=5,l=4,sg=0,ft=0,st=OK:28
                              SLEEP 20864s
                              5916 MCO:SLP:MS=20864000,SMS=1,I1=1,M1=1,I2=255,M2=255
                              5994 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
                              6569 TSF:TDI:TSL
                              • RayneR Offline
                                RayneR Offline
                                Rayne
                                @tekka This patch is not compiling correctly for ESP8266Gateway when using Wemos D1 Mini in the board manager, nor does it compile when the NodeMCU 1.0 board is selected either.
                                • RayneR Rayne
                                  @rayne it compiled fine when the change was merged into MySensors.
                                  Could you post the error message you're getting?
                                  RayneR 1 Reply Last reply
                                    RayneR Offline
                                    RayneR Offline
                                    Rayne
                                    @mfalkvidd Strange, when I compile for a arduino pro mini sensor, it compiles fine. However if I try to compile the esp8266gateway for a Wemos D1 Mini, the compiler complains about a file with no such directory.
                                    • RayneR Rayne
                                      @rayne see https://forum.mysensors.org/topic/9563/esp8266-fatal-error-gdb_hooks-h-no-such-file-or-directory-solved
                                        RayneR Offline
                                        RayneR Offline
                                        Rayne
                                        @mfalkvidd Ahhhh, that was it. I was still on 2.3.0 of the esp8266 core. Once I upgraded to 2.4.2 it compiled fine and was able to find gdb_hooks.h. I think I was on the older version due to some compatibility issues I had when I was making a WiFi Jammer for a buddy of mine some time ago. Hey thanks for your help @mfalkvidd . You are the man!
