  3. Can I use MySensors without a Controller?
6 Posts 3 Posters 2.0k Views 3 Watching
  • T Offline
    T Offline
    Tubes110
    Hello Everyone. I am new to MySensors but not to home automation or even automation in general. I have been in the building automation and process control industry for 20+ years. I have experience with DDC and PLC controls. I have deployed "controllers" from Iconics, Delta, KMC, and Induosft. We call them HMI's or Human Machine Interface. Before I moved 9 months ago, I had a system in my house that included some fully programmable Modbus thermostats/controllers, wireless sensors from Nathan Chantrell - tinyTX, and an Indusoft HMI. The sensors talked to a Arduino Mega gateway that converted all their data to Modbus that the front end read over RS485.
    OK, now to my question! I would like to use the MySensors stuff because it seems more robust and has lots of great options like acting like a repeater. Question is can I use this system without having to use a special controller software? Can I setup a router that also acts as a Modbus slave? Has anyone done this?
    Thanks!
    • T Offline
      T Offline
      tbowmo
      @Tubes110
      Welcome aboard :) In theory you do not need a controller. You can manuallyt assign ID to individual nodes. And then make a translation of some sorts between modbus / mysensors protocol.
      I don't know if anyone had made a router that can handle the translation between mysensors / modbus though, so you might need to make one from scratch yourself..
      T 1 Reply Last reply
      • T tbowmo
        @Tubes110
        T Offline
        T Offline
        Tubes110
        @tbowmo thanks for the info. So am I correct in saying I can manually set the address of each sensor node (and the "gateway" I suppose) and they will talk to each other? If this is the case, great! I can build out the Modbus part myself. Where can I find documents on what the sensor messages look like?
        Also, has anyone successfully ran a gateway firmare on an Arduino Mega? (I like the extra UARTs)
        • rejoe2R Offline
          rejoe2R Offline
          rejoe2
          @Tubes110
          Using a Mega should not be a big issue.
          Wrt. to using the MySensors framework without Controller you might look for "node to node communication" in the forum.
          A good starting point imo (starting with this posting): https://forum.mysensors.org/post/84724
          You have to configure all nodes with
          #define MY_TRANSPORT_WAIT_READY_MS 100
          as if the controller is not present, the nodes won't enter loop() (100 may be changed).
          Would be keen to see your final code; I'd like to bridge ebus communication to MySensors :grinning: , so your code could help to some extend.
          • T Offline
            T Offline
            tbowmo
            @Tubes110
            The serial protocol is described here
            @rejoe2
            The timeout you mention is only if you do not have a gateway in your system, and has nothing to do with a controller..
            rejoe2R 1 Reply Last reply
            • T tbowmo
              @Tubes110
              @rejoe2
              rejoe2R Offline
              rejoe2R Offline
              rejoe2
              @tbowmo Thx for clarification.
              As I only use serial GW's, I didn't notice the difference until now.
