  3. Node request temperature from gateway
3 Posts 2 Posters 767 Views 2 Watching
  • D
    D
    Daniel Rus
    Hi guys,
    I am trying for the last days to make the gateway to send data to node.
    Till now i dont have any luck , i am using an Arduino Nano for the node and and Arduino Mega with Ethernet adapter.
    Below is my gateway code:
    #define MY_RF24_CE_PIN 6
    #define MY_RF24_CS_PIN 4
    #define MY_SOFTSPI
    #define MY_GATEWAY_SERIAL
    #define CHILD_ID 4   // Id of the sensor child
    MyMessage msg(CHILD_ID, V_TEMP);
    void presentation()  {
      present(CHILD_ID, S_TEMP);
    { float temperature = 99; // dht.getTemperature();
      send(msg.set(temperature, 1));
    and the code for the node is :
    #define MY_RF24_CE_PIN 10
    #define MY_RF24_CS_PIN 9
    #define MY_NODE_ID 2
    { request(4, V_TEMP, 0);
      if (message.type == V_TEMP) {
        Serial.print(message.sensor);
        Serial.print("\n");
        Serial.println(message.getFloat());
    The serial from the node:
    0;4;1;0;0;99.0
    2;4;2;0;0;
    2;4;2;0;0;
    0;4;1;0;0;99.0
    2;4;2;0;0;
    2;4;2;0;0;
    0;4;1;0;0;99.0
    2;4;2;0;0;
    0;4;1;0;0;99.0
    0;4;1;0;0;99.0
    2;4;2;0;0;
    0;4;1;0;0;99.0
    In the serial from the node with debug activated:
    __  __       ____
            |___/                      2.3.0
    16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.3.0
    25 TSM:INIT
    26 TSF:WUR:MS=0
    33 TSM:INIT:TSP OK
    35 TSM:INIT:STATID=2
    37 TSF:SID:OK,ID=2
    39 TSM:FPAR
    75 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    585 TSF:MSG:READ,0-0-2,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    589 TSF:MSG:FPAR OK,ID=0,D=1
    2082 TSM:FPAR:OK
    2083 TSM:ID
    2084 TSM:ID:OK
    2086 TSM:UPL
    2089 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2096 TSF:MSG:READ,0-0-2,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2101 TSF:MSG:PONG RECV,HP=1
    2103 TSM:UPL:OK
    2105 TSM:READY:ID=2,PAR=0,DIS=1
    2109 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2116 TSF:MSG:READ,0-0-2,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2123 TSF:MSG:SEND,2-2-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.0
    2131 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    4140 TSF:MSG:SEND,2-2-0-0,s=4,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
    4146 MCO:REG:REQ
    4149 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    4155 TSF:MSG:READ,0-0-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    4160 MCO:PIM:NODE REG=1
    4163 MCO:BGN:STP
    ok
    4164 MCO:BGN:INIT OK,TSP=1
    4168 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
    4176 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
    4186 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
    4194 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
    4201 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
    4208 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
    4216 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
    4224 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
    4232 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
    4239 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
    4246 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
    4254 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
    4261 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
    4269 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
    • D Daniel Rus
      Hi guys,
      #define MY_SOFTSPI
          Serial.print("\n");
      0;4;1;0;0;99.0
      2;4;2;0;0;
      2;4;2;0;0;
      0;4;1;0;0;99.0
      2;4;2;0;0;
      2;4;2;0;0;
      0;4;1;0;0;99.0
      2;4;2;0;0;
      0;4;1;0;0;99.0
      0;4;1;0;0;99.0
      2;4;2;0;0;
      0;4;1;0;0;99.0
      __  __       ____
              |___/                      2.3.0
      25 TSM:INIT
      26 TSF:WUR:MS=0
      33 TSM:INIT:TSP OK
      37 TSF:SID:OK,ID=2
      39 TSM:FPAR
      2082 TSM:FPAR:OK
      2083 TSM:ID
      2084 TSM:ID:OK
      2086 TSM:UPL
      2103 TSM:UPL:OK
      4146 MCO:REG:REQ
      4163 MCO:BGN:STP
      ok
      Welcome to the MySensors community @daniel-rus
      A gateway does not store any data. You need to use a controller. It looks like there is no controller in your system?
      If you haven’t already, see https://www.mysensors.org/about/network for an overview of how MySensors works.
      D 1 Reply Last reply
        D
        D
        Daniel Rus
        wrote on last edited by Daniel Rus
        @mfalkvidd Hi, I manage to make an MQTT gateway with home assistant as controller .
        The serial from gateway i can see that the gateway send data out from MQTT, but the node still not receive anything
        870503 TSF:MSG:READ,2-2-0,s=3,c=2,t=0,pt=0,l=0,sg=0:
        870508 GWT:TPS:TOPIC=mygateway1-out/2/3/2/0/0,MSG SENT
        870569 GWT:TPS:TOPIC=mygateway1-out/0/4/1/0/47,MSG SENT
        870587 GWT:TPS:TOPIC=mygateway1-out/0/3/1/0/0,MSG SENT
        871604 TSF:MSG:READ,2-2-0,s=3,c=2,t=0,pt=0,l=0,sg=0:
        871609 GWT:TPS:TOPIC=mygateway1-out/2/3/2/0/0,MSG SENT
        871670 GWT:TPS:TOPIC=mygateway1-out/0/4/1/0/47,MSG SENT
        871687 GWT:TPS:TOPIC=mygateway1-out/0/3/1/0/0,MSG SENT
