  3. Multiple Dallas Temperatuur sensors at one sensor node
36 Posts 9 Posters 8.4k Views 9 Watching
  • dzjrD
    dzjrD
    dzjr
    Dear MySensors friends,
    I made a ethernet gateway sensor node with which I used 4 soil moisture sensors, four relays and 8 Dallas temp sensors (4x soil (1m, 50cm, 20cm 10cm), 1x waterhole temperature, temperature of the node, 10 cm high and 1.5 mtr high) temp can read / operate.
    I control the ground moisture sensors with a transistor circuit.
    After some trying and especially reading a lot on this forum I finally have the node working.
    There is only one thing that does not work, if I connect up to 4 dallas sensors, I just see them in the controller (I use domoticz).
    However, if I connect a 5th dallas sensor, I do not see an update for any sensor.
    My first thought was a food problem, so the dallas gave a seperate 5 volts (common 5 volts for the arduino uno and the 4 relays), the GND still connected to the arduino, but unfortunately this did not offer a solution.
    Is this a known problem, or am I doing something wrong?
    I read that there should be no problems when connecting multiple dallas sensors to other platforms.
    I hope someone can help me.
    And yes, I have the "#define MAX_ATTACHED_DS18B20 " at ten, I also used the standard sketch for the temperature, with a small adjustment to get a other the child id than the relays .
    Below the output of the debug:
    0 MCO:BGN:INIT GW,CP=R-NGA---,VER=2.3.0
    3 MCO:BGN:BFR
    859 GWT:TIN:IP=192.168.0.145
    1861 MCO:BGN:STP
    1863 MCO:REG:NOT NEEDED
    1865 MCO:BGN:INIT OK,TSP=NA
    34658 GWT:TSA:ETH OK
    34750 GWT:RFC:MSG=0;0;3;0;2;
    34755 GWT:RFC:MSG=0;0;3;0;2;Get Version
    34806 GWT:RFC:MSG=0;1;1;0;2;0
    35142 GWT:RFC:MSG=0;1;1;0;2;1
    35406 GWT:RFC:MSG=0;1;1;0;2;0
    41319 GWT:RFC:MSG=0;0;3;0;18;PING
    44960 GWT:RFC:MSG=0;4;1;0;2;1
    47435 GWT:RFC:MSG=0;3;1;0;2;1
    48705 GWT:RFC:MSG=0;2;1;0;2;1
    51245 GWT:RFC:MSG=0;0;3;0;18;PING
    61170 GWT:RFC:MSG=0;0;3;0;18;PING
    mfalkviddM zboblamontZ 2 Replies Last reply
    • dzjrD dzjr
      3 MCO:BGN:BFR
      1861 MCO:BGN:STP
      @dzjr the log from the node would probably give useful information.
      My guess is that sending (or presenting) too many messages strains the radio which causes transmission failures. Try adding wait(100); after each present/send.
      dzjrD 1 Reply Last reply
        dzjrD
        dzjrD
        dzjr
        @mfalkvidd
        Thanks for the fast response,
        The node And the gateway is the same sketch, And this is all what the debug give, only more ping's And the relay .
        I Will try the wait in the present And the loop.
        • wallyllamaW
          wallyllamaW
          wallyllama
          Is it any 5th temp sensor? In other words could it be a bad temp sensor? Also 1-wire doesnt like 'star' wiring, are all the sensors wired with short connections to the main cable? More like ,, and less |_| and for sure not |/
          • dzjrD dzjr
            3 MCO:BGN:BFR
            1861 MCO:BGN:STP
            zboblamontZ
            zboblamontZ
            zboblamont
            @dzjr Assuming it is not a wiring problem, I suggest running a temporary test sketch on the Node to ensure you are communicating with all the OneWire sensors.
            Once local communication with all 5 is confirmed, then check your original sketch to see how all 5 devices are presented and identified to the Controller, or whether the Controller assigns Child IDs (not ideal for multiple sensors), and reload your original sketch.
            Next check that all 5 show up on presentation to Domoticz, they should list under hardware even if only become active once temperatures are first reported.
            If you have not done it this way, the table/array method is highly recommended for multiple sensors -
            My 3v Node sketch lists 12 DS18B20s with their unique digital addresses, presenting preset Child IDs to the Gateway, and reporting temperatures against those fixed Child IDs. They cannot be re-sequenced by the Controller, and I know precisely which device has failed when and if it does, none have.
            Should a chip fail, the digital address can be rewritten in the sketch and the reporting will continue against that fixed Child ID.
            The same array sequence is used to request temperatures and all report to Domoticz every 5 minutes unless the previous reading is unchanged.
            O dzjrD 2 Replies Last reply
            • zboblamontZ zboblamont
              O
              O
              oneyb
              @zboblamont would you please direct me to the table/array method. I can imagine a few approaches, but am very interested how you have it set up. Thanks!
              • O oneyb
                zboblamontZ
                zboblamontZ
                zboblamont
                wrote on last edited by zboblamont
                @oneyb Sure, you can Google it but will post my own node's sketch as it is to hand, have omitted the Node device specific lib from the top however...
                   The MySensors Arduino library handles the wireless radio link and protocol
                   between your home built sensors/actuators and HA controller of choice.
                   The sensors forms a self healing radio network with optional repeaters. Each
                   repeater and gateway builds a routing tables in EEPROM which keeps track of the
                   network topology allowing messages to be routed to nodes.
                   Created by Henrik Ekblad <henrik.ekblad@mysensors.org>
                   Copyright (C) 2013-2015 Sensnology AB
                   Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
                   Documentation: http://www.mysensors.org
                   Support Forum: http://forum.mysensors.org
                   This program is free software; you can redistribute it and/or
                   modify it under the terms of the GNU General Public License
                   version 2 as published by the Free Software Foundation.
                   DESCRIPTION
                   Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
                   http://www.mysensors.org/build/temp
                   Enhanced Version to keep ChildIDs fix based on petewill's http://forum.mysensors.org/topic/2607/video-how-to-monitor-your-refrigerator.
                  - Present Dallas-Hardware-ID as comment https://github.com/rejoe2/MySensors-Dallas-Address-ChildID-Consistency
                //#define MY_DEBUG
                // Enable to print out an array of the attached DallasSensors to Serial
                // comment this after initial setup and adopt MAX_ATTACHED_DS18B20 accordingly
                ////#define PRINT_ARRAY
                ////#define MY_RADIO_NRF24
                #define MY_RADIO_RFM69  // Define for using RFM69 radio
                #define MY_RFM69_FREQUENCY RF69_433MHZ  // Define for frequency setting. Needed if you're radio module isn't 868Mhz (868Mhz is default in lib)
                #define LedPin 6
                #define MY_RFM69_NETWORKID 101  // Default is 100 in lib. Uncomment it and set your preferred network id if needed
                #define MY_NODE_ID 5  //Manually set the node ID here. Comment out to auto assign
                #include <OneWire.h>
                #define COMPARE_TEMP 1 // Send temperature only if changed?
                #define ERASE_HASH // Clear EEPROM, if no 1w-device is present?
                #define ONE_WIRE_BUS 16 // Pin where dallase sensor is connected
                #define MAX_ATTACHED_DS18B20 12
                uint8_t DS_First_Child_ID = 7; //First Child-ID to be used by Dallas Bus; set this to be higher than other Child-ID's who need EEPROM storage to avoid conflicts
                unsigned long SLEEP_TIME = 300000; // Sleep time between reads (in milliseconds)WAS 30000
                boolean metric = true;
                MyMessage DallasMsg(0, V_TEMP);
                //MyMessage msgId(0, V_ID);
                #ifdef PRINT_ARRAY
                DeviceAddress dallasAddresses[8];
                #else
                DeviceAddress dallasAddresses[] = {
                  {0x28, 0xFF, 0xB0, 0xA8, 0x74, 0x16, 0x03, 0x67},
                  {0x28, 0xFF, 0x78, 0xED, 0x74, 0x16, 0x04, 0x99},
                  {0x28, 0xFF, 0x86, 0xC7, 0x73, 0x16, 0x05, 0xD2},
                  {0x28, 0xFF, 0xE6, 0xD4, 0x73, 0x16, 0x05, 0x73},
                  {0x28, 0xFF, 0xD6, 0xDB, 0x74, 0x16, 0x03, 0xCA},
                  {0x28, 0xFF, 0x6E, 0x29, 0x80, 0x16, 0x05, 0x03},
                  {0x28, 0xFF, 0xB9, 0xE1, 0x73, 0x16, 0x05, 0x40},
                  {0x28, 0xFF, 0x9B, 0x5E, 0x80, 0x16, 0x05, 0x59},
                  {0x28, 0xFF, 0x5F, 0xFC, 0x74, 0x16, 0x03, 0x04},
                  {0x28, 0xFF, 0x18, 0xD0, 0x73, 0x16, 0x05, 0x79},
                  {0x28, 0x23, 0xAE, 0x10, 0x0A, 0x00, 0x00, 0x32},
                  {0x28, 0xAF, 0xA7, 0x10, 0x0A, 0x00, 0x00, 0x56},
                int  resolution = 10;
                int  conversionTime = 750;
                void before() {
                  conversionTime = 750 / (1 << (12 - resolution));
                  sensors.begin();
                  //numSensors = sensors.getDeviceCount();
                #ifdef PRINT_ARRAY
                  printAddressArray();
                void presentation()  {
                  sendSketchInfo("Dallas Temp, fix Array", "1.0");
                  for (int i = 0; i < MAX_ATTACHED_DS18B20; i++) {
                    present(DS_First_Child_ID + i, S_TEMP);
                //  for (int i = 0; i < MAX_ATTACHED_DS18B20; i++) {
                //      send(msgId.setSensor(DS_First_Child_ID + i).set(dallasAddresses[i], 8));
                //metric = getControllerConfig().isMetric;
                pinMode(LedPin, OUTPUT);
                  wait(conversionTime);
                    // Fetch and round temperature to one decimal; original method uses "sensors.getTempCByIndex(i)"
                    float temperature = static_cast<float>(static_cast<int>((metric ? sensors.getTempC(dallasAddresses[i]) : sensors.getTempF(dallasAddresses[i])) * 10.)) / 10.;
                    // Only send data if temperature has changed and no error @@@@@@@@@@ The compare is not working properly here
                #if COMPARE_TEMP == 1
                #else
                      send(DallasMsg.setSensor(i + DS_First_Child_ID).set(temperature, 1));
                      lastTemperature[i] = temperature;
                  wait(25);
                  digitalWrite(LedPin,HIGH);
                  wait(25);
                  digitalWrite(LedPin,LOW);
                  wait(25);
                  sleep(SLEEP_TIME);
                //Helper funktion for setting things up
                ////void printAddressArray() {
                  // start serial port
                ////  Serial.begin(115200);
                  // show the addresses we found on the bus
                ////  Serial.println("Copy the following to the DallasAddresses array,");
                ////  Serial.print("set MAX_ATTACHED_DS18B20 to ");
                ////  Serial.println(sensors.getDeviceCount());
                ////  Serial.println("and comment line #define PRINT_ARRAY for regular operation");
                ////  for (uint8_t i = 0; i < sensors.getDeviceCount(); i++) {
                ////    if (!sensors.getAddress(dallasAddresses[i], i))
                ////      Serial.print("Unable to find address for Device ");
                ////      Serial.println(i);
                ////      Serial.println();
                ////    Serial.print("{");
                ////    for (uint8_t j = 0; j < 8; j++)
                ////      Serial.print("0x");
                ////      // zero pad the address if necessary
                ////      if (dallasAddresses[i][j] < 16) Serial.print("0");
                ////      Serial.print(dallasAddresses[i][j], HEX);
                ////      if (j < 7) Serial.print(", ");
                ////      else Serial.println("},");
                ////  wait(SLEEP_TIME * 20);
                This is the work of others more clever but it works a treat, hopefully it helps.
                The REM'd part at the bottom if I recall correctly test runs the individual devices... It's been a while....
                • wallyllamaW wallyllama
                  dzjrD
                  dzjrD
                  dzjr
                  @wallyllama said in Multiple Dallas Temperatuur sensors at one sensor node:
                  |_|
                  @wallyllama i use the "waterproof" sensors, and i made a connection for three sensors, the fourth sensor (no waterproof) i solderd on the shield on top of the uno, and the fifth sensor in connected thru the cable (is also a waterproof sensor) also directly on the shield.
                  So, technical i made a star network of dalles sensors.
                  and i have the problem with several "5th" sensors.
                    dzjrD
                    dzjrD
                    dzjr
                    @zboblamont
                    Thank you for your reply,
                    Good tip, I had already done something with the standard dallas tester sketch, but I only came to a maximum of 3 sensors ....
                    I will create a separate node with only the temp sketch from the BUILD section of Mysensors.
                    Incidentally, believe it or not, I had your example to give each sensor address a unique CHILD-ID already applied in my sketch, but since I did not see all the sensors I first went back a step.
                    When I get results I post it immediately!
                    • dzjrD dzjr
                      @zboblamont
                      zboblamontZ
                      zboblamontZ
                      zboblamont
                      @dzjr Check that you can address all the sensors and retrieve the temperatures, from your previous post you may have a problem with your topology not conforming to the One-Wire architecture.
                      Also see my reply to @oneyb, locking the chip unique addresses to child IDs saves on analgesics...
                        dzjrD
                        dzjrD
                        dzjr
                        @zboblamont
                        Tomorrow I'm going to make a decent connection strip for the sensors, I had done it with some wires, but that does not work ideal of course.
                        • dzjrD dzjr
                          @zboblamont
                          zboblamontZ
                          zboblamontZ
                          zboblamont
                          @dzjr If you cannot daisy chain them because there is no sequential route between locations, use a separate pin for each data line (powered via resistor) and communicate with each line in turn.
                          The line here is using 3 cores in 20-30m of Cat5e cable to ensure each chip is physically sequential on the line.
                          When I added a further sensor location, a loop had to be spliced in to keep the line a daisy chain. It is a small house, the length is purely down to the route, and cable is cheap.
                          skywatchS dzjrD 2 Replies Last reply
                            skywatchS
                            skywatchS
                            skywatch
                            @dzjr What value pull-up resistor are you using?
                            • skywatchS skywatch
                              dzjrD
                              dzjrD
                              dzjr
                              @skywatch i use a 4K7 resistor
                                dzjrD
                                dzjrD
                                dzjr
                                @zboblamont
                                Thank you for your tips, at least I now have more knowledge about onewire.
                                Last night there was something else in between, but now I have put the sensors in a daisy chain (see photo).
                                First I tested it with the "standard" Arduino dallas temperature sketch "oneWireSearch", I got up to 7 sensors in this one.
                                I connected the cable of the waterproof sensors to the three wires (GND, 5V and the onewire pin (pin7)), threaded and twisted together.
                                When I connect an 8th sensor, the search sketch says that no sensors can be found, it does not matter which sensor is the 8th.
                                If I connect the 7 sensors to the gateway node, I see the 7 sensors in domoticz, so that's where it is.
                                it is then 6 wired sensors and a sensor on the PCB.
                                does anyone know if the onewire bus might be a twisted pair?
                                or is the distance between the branches too short?
                                If the problem remains, I just make extra oneWire bus for the 4 ground temperature sensors as you already suggested ...
                                • dzjrD dzjr
                                  @zboblamont
                                  zboblamontZ
                                  zboblamontZ
                                  zboblamont
                                  @dzjr Now you have to figure out why only #8 did not work, so progress ;) even if a digital device on One-Wire has not yet sunk in...
                                  There is no physical loop 8 I can see, so how is#8 connected in the chain?
                                    dzjrD
                                    dzjrD
                                    dzjr
                                    @zboblamont
                                    No, the 8th sensor is not connected because the search sketch does not find any sensor.
                                    Even with a 9th sensor, the sketch unfortunately does not find anything.
                                    and indeed there is no loop, on the other side of the wires I connected a multimeter to measure the 5V / GND voltage.
                                    The yellow bus wire has an open end.
                                    I also tried to connect a sensor at the end of the line as the 8th sensor.
                                    and I have used several sensors as "8th", so it is very likely that the sensors are okay
                                    • zboblamontZ
                                      zboblamontZ
                                      zboblamont
                                      @dzjr Sorry for any misunderstanding, the loops I was referring to are the sensor cable loops in your photo.
                                      I did read somewhere that different pullup resistors were recommended by different suppliers of the waterproof versions, values from 10k to 2k2, rather than the usual 4k7, some said the pullup should be on the Arduino end, others on the last sensor on the line, so worth experimenting, perhaps even a sacrificial length of additional cable to alter or extend spacing ?
                                      What is crucial to these devices is digital signal timing, hence constraints on layout architecture and cable capacitance, the pullup resistor only alters the circuit's speed of High/Low transitions.
                                      Here bare DS18B20s on Cat5 cable (low capacitance) works fine on a 3v Arduino for 12 sensors, so it can be done.
                                        If you have access to an oscilloscope, see what the signal looks like at the end. I had a problem a while ago with too long cable for i2c. See https://forum.mysensors.org/post/92967 for pictures.
                                        Stronger pullup at the end of the cable might help.
                                        • wallyllamaW
                                          wallyllamaW
                                          wallyllama
                                          https://www.maximintegrated.com/en/app-notes/index.mvp/id/148
                                          Here is maxim's guide on wiring for 1-wire. There are a few things to note, one is the "weight" of each sensor's cable. Read that section closely. Another is hubs. Hubs are basically a 1 wire switch that connects each segement of the network 1 at a time, so you can essentially walk though each ray of your star. The third is the suggestion above to use multiple pins on the arduino and just make several simpler networks.
                                          G dzjrD 2 Replies Last reply
