  3. Watchdog on Ethernet Gateway
ethernetgatewayattiny45watchdog
32 Posts 9 Posters 24.6k Views 1 Watching
  • BulldogLowellB
    BulldogLowellB
    BulldogLowell
    I'm still frustrated that my Ethernet Gateway will occaisionally lock up...
    I can't predict it, I have been logging it and it seems to me that I cannot find the cause or culprit.
    So, I was thinking about attaching an attiny45 to it, where it is constantly checking for a pulse... and can (hardware) reset the gateway in case of a lack of signal after a certain timeout. The less than $1.00 cost seems like reasonable insurance to keep things chugging along.
    Has anyone already done something like this (@axillent , @hek calling on your experience)? I've searched here with no luck...
    axillentA 1 Reply Last reply
      axillentA
      axillentA
      axillent
      @BulldogLowell which version of EthernetGateway you are running?
      does ping stops responding?
      I'm running 1.4.1 without any issues
      atmega contains a hardware watchdog without actual need of external one.
      With mysensors 1.3 I made an AVR version with support of the atmel's watchdog
      I think it can be a good idea to add watchdog support to the official arduino version of MySensors library.
      sense and drive
      • axillentA axillent
        BulldogLowellB
        BulldogLowellB
        BulldogLowell
        Also 1.4.1 While it vastly improved my performance across the board, I still get the (every two to three weeks) occasional lock-up. I can ping the gateway, but radio communication is kaput.
        I agree that we should include the watchdog functionality into both the Serial and Internet versions of gateway code. What can I do to help?
        I'll try the:
        wdt_enable();
        and we shall see if it tis the arduino locking up or the communication somewhere...
          I'll try the:
          wdt_enable();
          axillentA
          axillentA
          axillent
          @BulldogLowell wdt_enable alone cannot be sufficient
          first of all you need a bootloader having watchdog support
          official bootloader is not working with watchdog
          optiboot is working
          other alternative is to kill a bootloader but you will need ISP programmer to download sketches
          second wdt_reset need to be embedded into many places across sketch and library sources
          sense and drive
          BulldogLowellB tekkaT 2 Replies Last reply
            optiboot is working
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            OK, so for now it's a hardware plan!
              axillentA
              axillentA
              axillent
              @BulldogLowell why not to play around with your own copy of the sources?
              with success you can be a contributor of this nice feature
              sense and drive
                optiboot is working
                tekkaT
                tekkaT
                tekka
                wrote on last edited by tekka
                It's in general good practice to enable the watchdog to avoid deadlocks. What works best in my experience is to set the wdt to 8s and reset the wdt timer at the beginning of the main loop (as long as it takes max. 8s).
                Important: Avoid blocking functions and delay() - substitute delay() for mysensors::wait(), where the wdt is reset.
                The problems with the ethernet shield W5100 are discussed everywhere, resetting the arduino won't help in that case, but rather implementing an external watchdog that power-cycles the shield...
                  BulldogLowellB
                  BulldogLowellB
                  BulldogLowell
                  OK, I'll give it a stab.
                  you mean generally, or you are using it already on this application?
                  tekkaT 1 Reply Last reply
                    tekkaT
                    tekkaT
                    tekka
                    @BulldogLowell both, i'm using the wdt with Optiboot and MYSBootloader. Reading MCUSR during bootloading will give a hint on the reset cause...
                    • tekkaT tekka
                      tekkaT
                      tekkaT
                      tekka
                      Here a simple sketch:
                      #include <avr\wdt.h>
                        // set watchdog to 8s
                        wdt_enable(WDTO_8S);
                        // watchdog reset
                        wdt_reset();
                        // do some stuff that does not take longer than 8s
                       // else watchdog will trigger
                      • tekkaT tekka
                          // watchdog reset
                          wdt_reset();
                        BulldogLowellB
                        BulldogLowellB
                        BulldogLowell
                        yes, got that far ;) I thought you meant you had it working on a gateway.
                        Working with the (as @axillent said) the gateway, with all of its nuances and making it extensible for (the majority?) of the standard sensor sketches would be the challenge.
                          axillentA
                          axillentA
                          axillent
                          @BulldogLowell setting watchdog to timeout after 8 seconds can support you in most situations without a need to dig into library source
                          But you will be not guaranteed from all cases, it is possible that your arduino will be reset in normal situation where reset is not needed. But actually the same will happen if you will attach external watchdog as you state in you first post here
                          sense and drive
                            BulldogLowellB
                            BulldogLowellB
                            BulldogLowell
                            I have a lot more flexibility with hardware, i believe.... there is an (8s) limit on the Atmel watchdog, no?
                            axillentA Dan S.D 2 Replies Last reply
                              axillentA
                              axillentA
                              axillent
                              it is a limit of atmega328, other MCU can differ
                              but it is still possible to organize longer period by activating WDT ISR handler
                              this will be not the best practice but it will work
                              the best practice is to set very short timeout and to put wdt_reset() at all required points
                              sense and drive
                                What happens with watchdog while sleeping?
                                  axillentA
                                  axillentA
                                  axillent
                                  it depends on what do you want :)
                                  if i'm not mistaken LowPower library you are using is using watchdog while sleeping
                                  actually watchdog is only one timer running while POWER_DOWN
                                  it is a common way to wake up because of watchdog event from the deepest sleep if you need to wake up by time, not by external event
                                  sense and drive
                                  • G
                                    G
                                    Gambituk
                                    Hi, i would be interested in any more updates along this line. In my case my gateway is mostly stable as far as i can tell. several weeks without issues. My problem is that most of my nodes seem to lockup, so i would be totally interested in making them more robust either by software or if necessary with external chip as overlord watchdog
                                      Dan S.D
                                      Dan S.D
                                      Dan S.
                                      @BulldogLowell Any progress on this? My Ethernet gateway is quite reliable after solving power supply issues and implementing soft spi. But about once a month it stops and rebooting it makes it operative again. The failure seems to be periodic--once a month. May be a clue there--something reaching a limit? At any rate, any failure rate where I can't start it up without physically rebooting is too much.
                                        maha
                                        millis() has a rollover after approximately 50 days. Could that be something?
                                        Dan S.D 1 Reply Last reply
                                        • M maha
                                          Dan S.D
                                          Dan S.D
                                          Dan S.
                                          @maha Don't know. But your question did trigger the thought of using milils() to periodically trigger a reboot. Rather than check for a lockup with a watchdog routine I may try just rebooting it at a shorter time interval, e.g., every 2 weeks, than I have experienced the lockups using millis to measure the interval.
