  3. 3-in-1 Humidity Temp and Motion
motion3 in 1temphumidity
47 Posts 28 Posters 49.1k Views 22 Watching
  • O
    O
    Opus40
    hi,
    thanks I did some reading my self and realised I needed the resistor works a treat now. thanks for the reply.
    K 1 Reply Last reply
    • O Opus40
      hi,
      K
      K
      Konrad Walsh
      @Opus40 Great!
      I am currently finalising a 5 in 1 sensor... just testing and so far its working fantastic
      NuubiN 1 Reply Last reply
      • K Konrad Walsh
        @Opus40 Great!
        NuubiN
        NuubiN
        Nuubi
        wrote on last edited by Nuubi
        Hum-temp-motion-light-???
        • NuubiN Nuubi
          K
          K
          Konrad Walsh
          @Nuubi LOL.. its a secret!!!
          and I will share my carefully guarded secret... Air quality sensor!! or in other words.. smoke and gas detector...
          • N
            N
            NotYetRated
            Did you mount your PIR behind the rounded screen area on those cases? It works through that?
            I have yet to get to integrating PIR's in to my sensors, but do plan to, and was curious how to effectively mount them. Need to offer protection from the circuitry, but visibility to the sensor itself.
            • C4VetteC
              C4VetteC
              C4Vette
              wrote on last edited by C4Vette
              Question about a minor detail:
              Wouldn't a motionsenser trip be missed during:
              delay(dht.getMinimumSamplingPeriod()); ?
              For a DHT22 this is 2 seconds... or does the interrupt still has precedence?
              • C4VetteC C4Vette
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                @C4Vette you could just use a non-blocking method to read the temperature instead of the delay.
                The delay is method is in the library and used so that multiple reads to the sensor don't affect the reading (overheating the sensor).
                since SLEEP_TIME is 30s in the code above... I'd just read the temperature each time the sensor was awakened.
                you could just timestamp the last reading and check that at least the 2 seconds elapsed since the last reading before you take a new one (in the case that motion was detected.
                C4VetteC 1 Reply Last reply
                  C4VetteC
                  C4VetteC
                  C4Vette
                  @BulldogLowell
                  Ok, thanks for explaining. I'm no programmer but trying to understand the code. So because there is also a sleep-periode, the earlier mentioned delay could be omitted? I do not fully understand how the motion interrupt is working but I replaced the 30 second sleep with a few lines using millis, as you implied so that the loop keeps on running to do other things.
                  At the moment my sensor is a working combination of a LED-dimmer with a motion-sensor and now trying to add a DHT. This stuff is fun!
                  Posted some photo's at http://forum.mysensors.org/topic/781/my-led-dimmer-motion-temp-hum-sensor
                  • D
                    Dean
                    Nice set up!
                    • K Konrad Walsh
                      I am wanted to share my 3-in-1 sensor in case its of use to anyone
                      Its really just a combination of what's already available
                      I used the following hardware:
                      Arduino Nano LINK - Gave me both 3.3v and 5v output without having to mess with extra hardware(steppers)
                      1 x Motion Sensor LINK
                      1 x DHT22 LINK
                      Connections is as all other guides except:
                      Motion Sensor digital to Pin D3
                      and the DHT to Pin D4
                      Here is my code
                      #define CHILD_ID_HUM 0
                      #define CHILD_ID_TEMP 1
                      #define CHILD_ID_MOT 2   // Id of the sensor child
                      DHT dht;
                      float lastTemp;
                      float lastHum;
                      boolean metric = true;
                      MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
                        gw.begin();
                        gw.sendSketchInfo("Humidity/Motion", "1.0");
                        gw.present(CHILD_ID_MOT, S_MOTION);
                        // Read digital motion value
                        Serial.println(tripped);
                        gw.send(msgMot.set(tripped?"1":"0"));  // Send tripped value to gw
                        if (isnan(temperature)) {
                          lastTemp = temperature;
                          if (!metric) {
                          Serial.print("T: ");
                        if (isnan(humidity)) {
                            lastHum = humidity;
                            Serial.print("H: ");
                            Serial.println(humidity);
                        gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
                      If anyone wants more info please ask.. I will put up pictures or diagrams if needed
                      mvader
                      I'm having a problem with this build.
                      i'm using the same hardware.
                      I get nothing in the serial output screen.
                      i am able to compile and load the code.
                      when i measure on the 3.3 rail i get 3.8 (only when the radio is hooked up, i get 3.3 when nothing is hooked to the board)
                      when i measure on the 5v rail, i get 4.7v when the motion and temp sensor are hooked up.
                      I suspect my issues may be voltage related. although i'm not sure why i'm getting nothing on the serial monitor.
                      since you said you didn't need any steppers, do you have any suggestions?
                      thanks
                      • K Konrad Walsh
                        1 x DHT22 LINK
                        Here is my code
                        DHT dht;
                        float lastTemp;
                        float lastHum;
                          gw.begin();
                            if (!metric) {
                              lastHum = humidity;
                        Anthony Straw
                        @Konrad-Walsh my nano and pro mini on the way! double each! cant wait!! fed up all confused so have ard r3 n mega n nano n promini all tick tick!
                        • D
                          djolafritte
                          Works like a charm...
                          Thanks for sharing :)
                          • D
                            Dylano
                            dear all.
                            What battery u use?
                            And what is the battery time?
                            Domoticz, with a lot of working hardware, include mysensors :-)
                            OpenPLI, RuneAudio, Solarmeter, etc......
                            Not a great builder of software and hardware, more a user...
                            Only i try to do my best :-(
                            • V
                              V
                              viableoption
                              Looks pretty sweet. How is it working comparing to existing products with the same features?
                              • Łukasz KostrzewaŁ
                                Łukasz KostrzewaŁ
                                Łukasz Kostrzewa
                                Hi Konrad
                                Thx for great code. It works like charm but...
                                I have a question... It is possible to add to Your code one more (Door/Window) sensor?
                                Mayby You can post that code on this forum?
                                Best regards
                                • Łukasz KostrzewaŁ
                                  Łukasz KostrzewaŁ
                                  Łukasz Kostrzewa
                                  wrote on last edited by Łukasz Kostrzewa
                                  #29
                                  Hi to all
                                  I changed a little Konrad sketch and add to 3in1 Humidity Temp and Motion one more sensor (Door\Window)
                                  Here is my code:
                                  #define CHILD_ID_DOOR 3
                                  #define BUTTON_PIN_DOOR 2
                                  Bounce debouncer = Bounce();
                                  int oldValue=-1;
                                  DHT dht;
                                  float lastTemp;
                                  float lastHum;
                                  MyMessage msgDoor(CHILD_ID_DOOR,V_TRIPPED);
                                  gw.begin();
                                  pinMode(BUTTON_PIN_DOOR,INPUT);
                                  digitalWrite(BUTTON_PIN_DOOR,HIGH);
                                  debouncer.attach(BUTTON_PIN_DOOR);
                                  debouncer.interval(5);
                                  gw.sendSketchInfo("4in1", "1.0");
                                  gw.present(CHILD_ID_DOOR, S_DOOR);
                                  if (!metric) {
                                  lastHum = humidity;
                                  debouncer.update();
                                  // Get the update value
                                  int value = debouncer.read();
                                  if (value != oldValue) {
                                  // Send in the new value
                                  gw.send(msgDoor.set(value==HIGH ? 1 : 0));
                                  oldValue = value;
                                  //gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
                                  Now it is 4in1 :)
                                  • Łukasz KostrzewaŁ
                                    Łukasz KostrzewaŁ
                                    Łukasz Kostrzewa
                                    • kurniawan77K
                                      kurniawan77K
                                      kurniawan77
                                      wrote on last edited by kurniawan77
                                      #31
                                      Has the 3in1 sketch been updated to 2.0 yet? I need some help with it, im not tot keen with coding...
                                      R 1 Reply Last reply
                                      • kurniawan77K kurniawan77
                                        R
                                        R
                                        r-nox
                                        @kurniawan77
                                        This is HUM TEMP and PIR
                                        This is what I'm using and it runs in mysensors 2.0
                                        None battery powered. NO sleep mode and dirty code but it runs well enough for me right now.
                                        If you add or fix anything please post it for everyone.
                                        #define CHILD_ID_MOT 2 //me
                                        #define DIGITAL_INPUT_SENSOR 2   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                                        DHT dht;
                                        float lastTemp;
                                        float lastHum;
                                        boolean metric = false;
                                        unsigned long interval= 3000;//dht.getMinimumSamplingPeriod(); // the time we need to wait
                                        unsigned long previousMillis=0; // millis() returns an unsigned long.
                                        MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED); //me
                                         // metric = getConfig().isMetric;
                                          sendSketchInfo("3-1 Sensor", "1.0");
                                          present(CHILD_ID_MOT, V_TRIPPED); //me
                                        // only run loop if time has passed.
                                        unsigned long currentMillis = millis(); // grab current time
                                         // check if "interval" time has passed
                                         if ((unsigned long)(currentMillis - previousMillis) >= interval) {
                                              #ifdef MY_DEBUG
                                               Serial.print("Motion: ");
                                            if (!metric) {
                                            #ifdef MY_DEBUG
                                              lastHum = humidity;
                                              #ifdef MY_DEBUG
                                           // save the "current" time
                                           previousMillis = millis();
                                          //sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
                                        • ikkeTI
                                          ikkeTI
                                          ikkeT
                                          wrote on last edited by ikkeT
                                          #33
                                          My sample is here, unfortunately I didn't see this thread before starting it :)
                                          It works for temp, humidity, door and motion, and interrupts for door and motion, otherwise sleeps the intervals:
                                          https://github.com/ikke-t/sensebender
                                          There is also pro-mini to code to monitor only door and motion.
                                          This is also for 2.0 MySensors.
