  3. ethernet gateway tsp fail
6 Posts 2 Posters 78 Views 2 Watching
  • Stoica AndreeaS Offline
    Stoica Andreea
    Hello!
    I am using a raspberry pi 4 that has openhabian as an SO.
    I have installed mysensors binding in the karaf console with these 2 lines:
    bundle:install http://www.oberfoell.com/openhab2/org.openhab.binding.mysensors-2.5.0-SNAPSHOT.jar
    bundle:start 237
    Now, mysensors binding appears active:Screenshot 2020-10-05 at 22.30.52.png
    I have also installed the additional features as said here https://github.com/tobof/openhab2-addons/wiki/Installation (the mqtt and serial).
    I have followed the instructions here https://www.mysensors.org/build/raspberry and configured the gateway like this ./configure --my-gateway=ethernet --my-port=5003. I ran make afterwards.
    I am using a Wemos that has the following code
    #define MY_GATEWAY_ESP8266
    //#define MY_WIFI_SSID "DIGI-7xj8"
    //#define MY_WIFI_PASSWORD "redacted"
    #define MY_WIFI_SSID "TP-Link_DFA1"
    // Enable UDP communication
    #define MY_USE_UDP // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
    #define MY_HOSTNAME "ESP8266_GW"
    #define MY_PORT 5003
    #define MY_CONTROLLER_IP_ADDRESS 192,168,0,104
    #define IP_PORT 5003
    //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
    uint32_t SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
    #define DIGITAL_INPUT_SENSOR 3 // The digital input you attached your motion sensor. (Only 2 and 3 generates interrupt!)
    #define MY_NODE_ID 1
    #define CHILD_ID 1 // Id of the sensor child
    // Initialize motion message
    pinMode(DIGITAL_INPUT_SENSOR, INPUT); // sets the motion sensor digital pin as input
    present(CHILD_ID, S_MOTION);
    // Read digital motion value
    //bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
    bool tripped=true;
    Serial.println(tripped);
    //send(msg.set(tripped?"1":"0")); // Send tripped value to gw
    send(msg.set(tripped));
    Serial.println(WiFi.localIP());
    //sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
    //sleep(SLEEP_TIME);
    delay(SLEEP_TIME);
    When I run this command sudo ./bin/mysgw I have the following error:
    Do you have any suggestions?
    • Stoica AndreeaS Stoica Andreea
      Hello!
      bundle:start 237
      bool tripped=true;
      delay(SLEEP_TIME);
      @Stoica-Andreea are you planning to use both the raspberry pi gateway and the wemos gateway at the same time? If so, could you tell us more about what you are building?
      Or did you intend to use the wemos as a node? (Not a gateway)
        Stoica Andreea
        I intend to use wemos as a node and the raspberry as the gateway.
        I want to implement a system on openhab with the mysensors binding. I am trying to read a value from a sensor attached to wemos (I have removed the interactive part and I am only sending a true "1" value for the tripped variable) then send it to the raspberry pi and later display it via the openhab platform.
        For now, I am testing the interaction between wemos and raspberry in the openhabian terminal.
        • mfalkviddM Offline
          Thanks for explaining.
          Start with removing #define MY_GATEWAY_ESP8266 from the wemos sketch, and add #define MY_RADIO_RF24 instead. This will make the wemos a node instead of a gateway.
          Then check wiring on the raspberry pi, as discussed in the other thread. Communication will not work when the gateway is unable to initialize the nrf24 radio chip.
            Stoica Andreea
            I have missed an important detail in the earlier post.
            I am working on a project that has some constraints - I have to find a way to send data through Wifi and another way to send data through radio waves (the nrf).
            This post was regarding the Wifi connection. From what I understood from your last post, the communication between the gateway and the node is established through the nrf24 module and then the message is send via Wifi. Is that correct?
            Also, if you could point me out a method using mysensors with the Wifi only it would be very helpful.
              https://www.mysensors.org/about/overview tried to describe how MySensors works.
              A MySensors gateway can run on ta Raspberry Pi, or on a Wemos (or a number of other hardware).
              A MySensors gateway can communicate with a controller using a (virtual) usb port, wifi, wired internet, cellular internet, etc.
              For your wifi connection, you can use a wemos gateway if you like. In that case, there is no need to connect a nrf24 radio to the wemos.
              For "radio waves" you can build a MySensors node with nrf24 if you like. If you do that, you will need a gateway that also has a nrf24 radio.
