  3. Infinite loop
Infinite loop
8 Posts 3 Posters 771 Views 3 Watching
  • Fumée BleueF
    Fumée BleueF
    Fumée Bleue
    I implemented a node with Arduino pro mini 3.3v with a RFM95w module. I used Mysensors PASSIVE node exemple.
    My problem is i have an infinite loop/reboot in my serial log. Do you have an idea why i'm having this issue ?
    __  __       ____
            |___/                      2.3.2
    16 MCO:BGN:INIT NODE,CP=RLNPA---,FQ=8,REL=255,VER=2.3.2
    28 TSM:INIT
    28 TSF:WUR:MS=0
    30 RFM95:INIT
    32 RFM95:INIT:PIN,CS=10,IQP=2,IQN=0
    47 RFM95:PTX:LEVEL=13
    49 TSM:INIT:TSP OK
    51 TSM:INIT:TSP PSM
    53 TSM:INIT:STATID=100
    55 TSF:SID:OK,ID=100
    57 TSM:FPAR
    59 TSM:FPAR:STATP=255
    61 TSM:ID
    61 TSM:ID:OK
    63 TSM:UPL:DISABLED
    65 TSM:READY:ID=100,PAR=255,DIS=1
    69 RFM95:SWR:SEND,TO=255,SEQ=0,RETRY=0
    __  __       ____
            |___/                      2.3.2
    28 TSM:INIT
    28 TSF:WUR:MS=0
    30 RFM95:INIT
    49 TSM:INIT:TSP OK
    51 TSM:INIT:TSP PSM
    57 TSM:FPAR
    61 TSM:ID
    61 TSM:ID:OK
    63 TSM:UPL:DISABLED
    __  __       ____
            |___/                      2.3.2
    28 TSM:INIT
    28 TSF:WUR:MS=0
    30 RFM95:INIT
    49 TSM:INIT:TSP OK
    51 TSM:INIT:TSP PSM
    57 TSM:FPAR
    61 TSM:ID
    61 TSM:ID:OK
    63 TSM:UPL:DISABLED
     * Copyright (C) 2013-2019 Sensnology AB
     * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
     * Version 1.0 - tekka
     * Passive node example: This is a passive & independent reporting node
    // Enable debug prints
    // Enable passive mode
    #define MY_PASSIVE_NODE
    // Passive mode requires static node ID
    #define MY_NODE_ID 100
    //#define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    #define MY_RADIO_RFM95
    #define   MY_DEBUG_VERBOSE_RFM95
    #define MY_RFM95_FREQUENCY  (RFM95_868MHZ)
    #define CHILD_ID 0   // Id of the sensor child
    // Initialize general message
    MyMessage msg(CHILD_ID, V_TEMP);
    	sendSketchInfo("Passive node", "1.0");
    	present(CHILD_ID, S_TEMP);
    	// generate some random data
    	send(msg.set(25.0+random(0,30)/10.0,2));
    	sleep(2000);
    • Fumée BleueF Fumée Bleue
      __  __       ____
              |___/                      2.3.2
      28 TSM:INIT
      28 TSF:WUR:MS=0
      30 RFM95:INIT
      49 TSM:INIT:TSP OK
      51 TSM:INIT:TSP PSM
      57 TSM:FPAR
      61 TSM:ID
      61 TSM:ID:OK
      63 TSM:UPL:DISABLED
      __  __       ____
              |___/                      2.3.2
      28 TSM:INIT
      28 TSF:WUR:MS=0
      30 RFM95:INIT
      49 TSM:INIT:TSP OK
      51 TSM:INIT:TSP PSM
      57 TSM:FPAR
      61 TSM:ID
      61 TSM:ID:OK
      63 TSM:UPL:DISABLED
      __  __       ____
              |___/                      2.3.2
      28 TSM:INIT
      28 TSF:WUR:MS=0
      30 RFM95:INIT
      49 TSM:INIT:TSP OK
      51 TSM:INIT:TSP PSM
      57 TSM:FPAR
      61 TSM:ID
      61 TSM:ID:OK
      63 TSM:UPL:DISABLED
      	sleep(2000);
      @Fumée-Bleue could very well be a power issue, because as soon as you try to send the node seems to restart. How do you power everything?
      • Fumée BleueF
        Fumée BleueF
        Fumée Bleue
        wrote on last edited by Fumée Bleue
        @Yveaux. good idea, yes the power supply is a bit special. It's une AC power 6v limited at 130mW. I used a Graetz rectifier and LDO 3,3v regulator. In fact, i have a similar project with NRF24L01 without issue. I think rfm95w consumes more energy than nrf241L01.
        For you, what is the best way to solve my problem ? Perhaps a super capacitor ?
          @Fumée-Bleue I would start by running your exact same software powered by a different power supply, preferably a lab supply supplying suffient current (look up the power requirements of RFM95 in Tx mode). That way you can rule out software.
          Next, just adding a large capacitor to your current supply might suffice, when you only incidentally send using the RFM95. A super cap can also work, but requires more components/is more expensive. Either do the calculation (always better), or experiment with some caps.
          Fumée BleueF 1 Reply Last reply
          • YveauxY Yveaux
            Fumée BleueF
            Fumée BleueF
            Fumée Bleue
            @Yveaux, I tried with an laboratoy power supply with the RMF95w and NRF24L01, and the same code.
            Test with RMF95w :
            • laboratery power supply : OK
            • 130mW power supply : KO
            Test with NRF24L01+ :
            • 130mW power supply : OK
            The consumption is the same in the two tests : 38mA max, 10mA mean, 4mA min.
            In fact I would like to understand why the arduino restarts, is there a watchdog in the Mysensors library to monitor the supply voltage?
            PS : I also tried with a larger capacitor without success.
            mfalkviddM YveauxY 2 Replies Last reply
              Test with RMF95w :
              @Fumée-Bleue there is no watchdag. Giving the components power outside the specifications will result in undefined behavior for that component. Underined can in some cases mean restart. In some cases we've seen continuous radio brodcast (blocking all other nodes). Undefined means anything can happen.
                Test with RMF95w :
                @Fumée-Bleue likely the brown-out detector from the atmega detects a low voltage. This mechanism protects the atmega from undefined behavior by resetting it.
                • Fumée BleueF
                  Fumée BleueF
                  Fumée Bleue
                  thank you for this additional information.
                  Tristan
