  3. Temp/Humidity/Light Sensor on battery
3 Posts 2 Posters 7.4k Views 2 Watching
  • D
    Dheeraj
    wrote on last edited by Dheeraj
    After a long time tried making a node with temperature, relative humidity and light sensors. 2015-04-03 13.00.18.jpg
    Running sensor node on 9v battery..actually i have bought ample of 9v batteries. sensor node is running for last 15 days.. ignore the dip in the battery levels due to non-battery mode .
    upload-cd163fd8-f48d-4e84-95f6-8d340f725709
    LDR and DHT11 sensors connected on PCB..
    upload-99d006c0-7a49-49f8-953d-964c221803be
    DwaltD 1 Reply Last reply
    • D Dheeraj
      DwaltD
      DwaltD
      Dwalt
      @Dheeraj Very nice. Do you mind sharing your sketch?
      • DwaltD Dwalt
        Dheeraj
        @Dwalt
        actually the sketch is simple.
        #define CHILD_ID_HUM 0
        #define CHILD_ID_TEMP 1
        #define CHILD_ID_LIGHT 2
        #define BATTERY_SENSE_PIN  A0  // select the input pin for the battery sense point
        #define LIGHT_SENSOR_ANALOG_PIN A1
        unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
        DHT dht;
        float lastTemp;
        float lastHum;
        boolean metric = true;
        int oldBatteryPcnt = 0;
        int battLoop =0;
        int lightLevel =0;
        int lastLightLevel =0;
          gw.begin(NULL,15);
          gw.sendSketchInfo("Temp Humidity Light", "1.0");
          check_batt();
          if (isnan(temperature)) {
            lastTemp = temperature;
            if (!metric) {
            Serial.print("T: ");
          if (isnan(humidity)) {
              lastHum = humidity;
              Serial.print("H: ");
              Serial.println(humidity);
          lightLevel = (analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
              Serial.println(lightLevel);
              gw.send(msg.set(lightLevel));
              lastLightLevel = lightLevel;
          battLoop++;
          if (battLoop > 10)
              check_batt();
              battLoop=0;
        void check_batt()
          // get the battery Voltage
          Serial.println(sensorValue);
          // vout = (sensorvalue x 3.3) / 1023
          //vin = vout /  (R2/(R1+R2));
          float batteryV  = ( sensorValue * 0.003225806 ) / 0.3; // divide R2/(R1+R2)
          int batteryPcnt = sensorValue / 10 ;
          if ( batteryPcnt > 100 )
          batteryPcnt = 100;
          Serial.print(batteryV);
          Serial.println(" V");
          Serial.print(batteryPcnt);
          Serial.println(" %");
          if (oldBatteryPcnt != batteryPcnt)
            // Power up radio after sleep
            oldBatteryPcnt = batteryPcnt;
        12.5k
