  3. Parking Sensor
Parking Sensor
74 Posts 28 Posters 56.2k Views 18 Watching
  • Dan S.D Dan S.
    @chilump I hope so since that's exactly how I intend to use it. I will wire the arduino and the led ring directly (and separately ) to the adaptor. I don't want to have to deal with 2 separate power supplies.
    C
    C
    chilump
    @Dan-S. Thanks for the guidance! Looking forward to getting it working
    • L
      L
      leothlon
      This is looking great!
      But i'm not seeing any "sleeping" is there anyway to have this using the external interrupts on the arduino so it can be running on battery?
      ( sorry if i'm mistaken, i'm new to arduino :D )
      korttomaK 1 Reply Last reply
      • L leothlon
        korttomaK
        korttomaK
        korttoma
        @leothlon that LED ring would burn through your batteries quite fast.
        • Tomas
        L 1 Reply Last reply
        • korttomaK korttoma
          L
          L
          leothlon
          @korttoma
          Even if it's only active for about 3-4minutes per day?
          The problem is i got no way of getting power to where i want to place it.
          And also if i did it would have to be something like 230V to usb adapter.
          And plugging one of those in outside seems like a fire hazzard (even indoors they are known to start fires).
          What if i hook it up to a small solar panel to charge the batteries?
          Otherwise i guess i'll just have to stick with the old tennisball on a string method :D
          • L leothlon
            @korttoma
            korttomaK
            korttomaK
            korttoma
            @leothlon I'm not saying it can not be done but according to the datasheet the LED chip can consume up to 20mA ( http://www.adafruit.com/datasheets/WS2812.pdf ). So with 24 of them you will be looking at almost 500mA for just the LEDs.
            http://ncalculators.com/electrical/battery-life-calculator.htm
            btw, there is another thread about safe AC DC transformers here
            • Tomas
            Dan S.D 1 Reply Last reply
              Dan S.D
              Dan S.D
              Dan S.
              @korttoma The online documentation I read said:
              "The pin labeled PWR +5V is the power input pin, and should be connected to a suitable power supply. An input voltage of 5 V is used to power the ring, and each LED on the ring can draw up to 50 mA at 5 V when outputting white at full brightness. That means the ring could draw up to a maximum of around 1.2 A."
              Although Hek's code does not operate all the pixels at full white brightness, I decided to play extra safe and use a 2A supply.
              • Dan S.D Dan S.
                korttomaK
                korttomaK
                korttoma
                @Dan-S. Yeah I'm sure thats true. Please post a link to the documentation if you can find it. Anyhow I guess we can agree that running this device on batteries would be difficult.
                • Tomas
                Dan S.D L 2 Replies Last reply
                  Dan S.D
                  Dan S.D
                  Dan S.
                  @korttoma link text
                    L
                    L
                    leothlon
                    @korttoma
                    Yea from my calculations i would need to change batteries about once a month.
                    And with the amount of sun here in sweden i don't think solar charger would help much sadly.
                      But isn't the distance sensor rather power hungry as well?
                      The dist-sensor but be awake all the time taking measurements (which needs to be interpreted by the MCU).. so sleep mode is not an option on this.
                        BulldogLowellB
                        BulldogLowellB
                        BulldogLowell
                        You could wake it with a reed switch attached to the garage door...
                        door open, sense and display until steady state and go to sleep on a timeout or door closed interrupt
                        TD22057T 1 Reply Last reply
                          TD22057T
                          TD22057T
                          TD22057
                          I like that idea. I was planning on having garage door sensors tied in with this anyway. FYI here is a link to the ultrasonic module docs which list 15mA as the current draw.
                          • rvendrameR
                            rvendrameR
                            rvendrame
                            Just to add my two cents, as I have a window nearby, I'm planning to run my parking sensor with a solar battery bank, like this one.
                            http://www.dx.com/p/solar-powered-13800mah-external-battery-charger-power-source-bank-silver-white-281953#.Ve8ICLTOmNM
                            I'm waiting for the ring now. It is the last piece missing ;-)
                            ESP8266 GW + mySensors 2.3.2
                            Alexa / Google Home
                              msebbe
                              This was fun to build :)
                              However, my HC-SR04 is making a high pitch sound when distance is close and a more static sound when distance is further. I have tried with 3 different modules and 2 different Nanos and 2 different power sources. Is this normal?
                              SparkmanS BulldogLowellB hekH 3 Replies Last reply
                              • M msebbe
                                SparkmanS
                                SparkmanS
                                Sparkman
                                @msebbe It's normal for a :dog: or a bat. :laughing: Either you have really good hearing, or there's something wrong with your HC-SR04. The ultrasound is supposed to be well above human hearing range (40 KHz). My HC-SR04 is quiet and I don't hear any sound from it.
                                • M msebbe
                                  BulldogLowellB
                                  BulldogLowellB
                                  BulldogLowell
                                  @msebbe
                                  building on @Sparkman , perhaps it is some kind of resonance... something attached with a natural frequency that is excited by the vibrations of the speaker.
                                  • M msebbe
                                    @msebbe
                                    I could hear mine as well when being close to it.
                                    • SparkmanS Sparkman
                                      msebbe
                                      @Sparkman
                                      It is correct that I have really good hearing.. But if I use the distance sensor sketch the HC-SR04 is not making any sound at all, first now with this sketch I hear it. Could it have something to do with the LED-strip I got from china?
                                      • Dan S.D
                                        Dan S.D
                                        Dan S.
                                        Was checking out operation of parking sensor after changing MAX_Distance to 200 from original 100--wanted earlier start from wall. Also changed the Panic distance to 60--more space from wall during testing. Noticed that the led ring did not start from 1 pixel and increase from there as the distance closed. It started at 7 lit pixels. Examined the formula for newLightPixels and made a change which corrected this.
                                        The current newLightPixels formula is:
                                        int newLightPixels = NUMPIXELS - (NUMPIXELS*(displayDist-PANIC_DISTANCE)/MAX_DISTANCE);
                                        The portion of the newLightPixels formula (displayDist-PANIC_DISTANCE)/MAX_DISTANCE) is intended to map the interval between PANIC_DISTANCE and MAX_DISTANCE to the interval (0,1). In other words, when you are at the PANIC_DISTANCE it should calculate to 0 and when you are at MAX_DISTANCE it should calculate to 1, advancing linearly between the two values as the distance closes and vice versa. Clearly when a displayDist = PANIC_DISTANCE, the numerator of the division of the formula calculates to 0. However when displayDist = MAX_DISTANCE, it does not calculate to 1.
                                        In order to correct this I changed the portion of the formula to:
                                        (displayDist-PANIC_DISTANCE)/(MAX_DISTANCE-PANIC_DISTANCE))
                                        Note the only difference is subtracting the PANIC_DISTANCE from the MAX_DISTANCE in the denominator. Now when the displayDist = MAX_DISTANCE, the formula returns the value 1. So the proposed new newLightPixels formula is:
                                        int newLightPixels = NUMPIXELS - (NUMPIXELS*(displayDist-PANIC_DISTANCE)/(MAX_DISTANCE-PANIC_DISTANCE));
                                        I tested it both by plugging values into the formula and in operation of the Parking Sensor. Now the leds climb smoothly from 0 as you enter the MAX_DISTANCE zone. rather than starting at some number other than 1 (7 in my case).
                                        • Lawrence HelmL
                                          Lawrence HelmL
                                          Lawrence Helm
                                          Cool, I had this happen as well, so great fix! Now all I need it to do is talk to domoticz, not picking it up yet... :)
