  3. Parking Sensor
Parking Sensor
74 Posts 28 Posters 56.2k Views 18 Watching
  • korttomaK korttoma
    @leothlon I'm not saying it can not be done but according to the datasheet the LED chip can consume up to 20mA ( http://www.adafruit.com/datasheets/WS2812.pdf ). So with 24 of them you will be looking at almost 500mA for just the LEDs.
    http://ncalculators.com/electrical/battery-life-calculator.htm
    btw, there is another thread about safe AC DC transformers here
    Dan S.D
    Dan S.D
    Dan S.
    @korttoma The online documentation I read said:
    "The pin labeled PWR +5V is the power input pin, and should be connected to a suitable power supply. An input voltage of 5 V is used to power the ring, and each LED on the ring can draw up to 50 mA at 5 V when outputting white at full brightness. That means the ring could draw up to a maximum of around 1.2 A."
    Although Hek's code does not operate all the pixels at full white brightness, I decided to play extra safe and use a 2A supply.
    korttomaK 1 Reply Last reply
    • Dan S.D Dan S.
      korttomaK
      korttomaK
      korttoma
      @Dan-S. Yeah I'm sure thats true. Please post a link to the documentation if you can find it. Anyhow I guess we can agree that running this device on batteries would be difficult.
      • Tomas
      Dan S.D L 2 Replies Last reply
        Dan S.D
        Dan S.D
        Dan S.
        @korttoma link text
          L
          L
          leothlon
          @korttoma
          Yea from my calculations i would need to change batteries about once a month.
          And with the amount of sun here in sweden i don't think solar charger would help much sadly.
            But isn't the distance sensor rather power hungry as well?
            The dist-sensor but be awake all the time taking measurements (which needs to be interpreted by the MCU).. so sleep mode is not an option on this.
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              You could wake it with a reed switch attached to the garage door...
              door open, sense and display until steady state and go to sleep on a timeout or door closed interrupt
              TD22057T 1 Reply Last reply
                TD22057T
                TD22057T
                TD22057
                I like that idea. I was planning on having garage door sensors tied in with this anyway. FYI here is a link to the ultrasonic module docs which list 15mA as the current draw.
                • rvendrameR
                  rvendrameR
                  rvendrame
                  Just to add my two cents, as I have a window nearby, I'm planning to run my parking sensor with a solar battery bank, like this one.
                  http://www.dx.com/p/solar-powered-13800mah-external-battery-charger-power-source-bank-silver-white-281953#.Ve8ICLTOmNM
                  I'm waiting for the ring now. It is the last piece missing ;-)
                  ESP8266 GW + mySensors 2.3.2
                  Alexa / Google Home
                    msebbe
                    This was fun to build :)
                    However, my HC-SR04 is making a high pitch sound when distance is close and a more static sound when distance is further. I have tried with 3 different modules and 2 different Nanos and 2 different power sources. Is this normal?
                    SparkmanS BulldogLowellB hekH 3 Replies Last reply
                    • M msebbe
                      SparkmanS
                      SparkmanS
                      Sparkman
                      @msebbe It's normal for a :dog: or a bat. :laughing: Either you have really good hearing, or there's something wrong with your HC-SR04. The ultrasound is supposed to be well above human hearing range (40 KHz). My HC-SR04 is quiet and I don't hear any sound from it.
                      • M msebbe
                        BulldogLowellB
                        BulldogLowellB
                        BulldogLowell
                        @msebbe
                        building on @Sparkman , perhaps it is some kind of resonance... something attached with a natural frequency that is excited by the vibrations of the speaker.
                        • M msebbe
                          @msebbe
                          I could hear mine as well when being close to it.
                          • SparkmanS Sparkman
                            msebbe
                            @Sparkman
                            It is correct that I have really good hearing.. But if I use the distance sensor sketch the HC-SR04 is not making any sound at all, first now with this sketch I hear it. Could it have something to do with the LED-strip I got from china?
                            • Dan S.D
                              Dan S.D
                              Dan S.
                              Was checking out operation of parking sensor after changing MAX_Distance to 200 from original 100--wanted earlier start from wall. Also changed the Panic distance to 60--more space from wall during testing. Noticed that the led ring did not start from 1 pixel and increase from there as the distance closed. It started at 7 lit pixels. Examined the formula for newLightPixels and made a change which corrected this.
                              The current newLightPixels formula is:
                              int newLightPixels = NUMPIXELS - (NUMPIXELS*(displayDist-PANIC_DISTANCE)/MAX_DISTANCE);
                              The portion of the newLightPixels formula (displayDist-PANIC_DISTANCE)/MAX_DISTANCE) is intended to map the interval between PANIC_DISTANCE and MAX_DISTANCE to the interval (0,1). In other words, when you are at the PANIC_DISTANCE it should calculate to 0 and when you are at MAX_DISTANCE it should calculate to 1, advancing linearly between the two values as the distance closes and vice versa. Clearly when a displayDist = PANIC_DISTANCE, the numerator of the division of the formula calculates to 0. However when displayDist = MAX_DISTANCE, it does not calculate to 1.
                              In order to correct this I changed the portion of the formula to:
                              (displayDist-PANIC_DISTANCE)/(MAX_DISTANCE-PANIC_DISTANCE))
                              Note the only difference is subtracting the PANIC_DISTANCE from the MAX_DISTANCE in the denominator. Now when the displayDist = MAX_DISTANCE, the formula returns the value 1. So the proposed new newLightPixels formula is:
                              int newLightPixels = NUMPIXELS - (NUMPIXELS*(displayDist-PANIC_DISTANCE)/(MAX_DISTANCE-PANIC_DISTANCE));
                              I tested it both by plugging values into the formula and in operation of the Parking Sensor. Now the leds climb smoothly from 0 as you enter the MAX_DISTANCE zone. rather than starting at some number other than 1 (7 in my case).
                              • Lawrence HelmL
                                Lawrence HelmL
                                Lawrence Helm
                                Cool, I had this happen as well, so great fix! Now all I need it to do is talk to domoticz, not picking it up yet... :)
                                • Dan S.D
                                  Dan S.D
                                  Dan S.
                                  Have one more proposed change to parking sensor code. Noticed that even when I was standing still there seemed to be quite a few changes in number of leds lit. In checking the internet, learned that variability of distance readings was particularly a problem for those using the sensor in robots. The preferred solution seemed to be taking the median of several readings.
                                  See:
                                  http://blog.microcentertech.com/2013/05/minipingbot-construction.html
                                  Fortunately, the Newping library has a built in function to address this issue by taking the median of several readings (default = 5). So I modified the code as follows:
                                  // int fullDist = sonar.ping_cm(); original code
                                  unsigned int fullDist = (sonar.ping_median() / US_ROUNDTRIP_CM);
                                  // Get average distance for 5 pings, convert to cm
                                  // US_ROUNDTRIP_CM = distance sound travels in cm/sec
                                  As a result, the jumping around of the number of leds appears to have decreased significantly and the response is much more stable. Hope this helps others.
                                  • Dan S.D Dan S.
                                    See:
                                    msebbe
                                    wrote on last edited by msebbe
                                    #52
                                    @Dan-S. Thanks for your investigation! I made the changes and it seems to work well!
                                    About the high pitch sound I mentioned earlier; I changed NEO_KHZ400.
                                    Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, NEO_PIN, NEO_GRB + NEO_KHZ400);
                                    to
                                    NEO_KHZ800
                                    This removed the annoying high pitch sound :D
                                    Dan S.D 1 Reply Last reply
                                    • M msebbe
                                      to
                                      NEO_KHZ800
                                      Dan S.D
                                      Dan S.D
                                      Dan S.
                                      @msebbe Glad everything worked out well for you. Your comment made me think about changing mine to 800 also. From what I could glean from looking on the internet, 800 is more appropriate for newer devices, e.g., the led ring. So I am going to change to 800 also. Thanks.
                                      • W
                                        W
                                        wergeld
                                        Just built this with my 4 year old. She loved it! She did the project management and directed me which wire goes where. Got to start them young!
                                        I was really shocked at the brightness of the LED ring. I mean, I knew it would be bright from looking at the videos, but wow.
                                        My setup was to connect my UNO to the PC, load code and branch power directly from the UNO's 5v pin. I had no cap or resistor in place either (neither was there a radio hooked-up). This was just a bench-top proof of concept and it worked right out the box (after I soldered leads to the ring). I went through all the adafruit example codes and worked without a hitch. I may, or may not, exceeded WAF level 10. Now she is giving me more projects for these "neopixel" lights.
                                          My girls like liked the neopixels as well ;)
