  2. Bug Reports
  3. ESP8266 WiFi gateway issue
49 Posts 6 Posters 28.4k Views 3 Watching
  • HoffanH
    HoffanH
    Hoffan
    wrote on last edited by Hoffan
    All the sensors that i have include before i upgrade the ESP8266 Wifi GW is now working
    But its not working to include more, Nothing happens in Veran when i press start
    but the gateway say this
    0;0;3;0;9Client 0: 0;0;3;0;5;1t version
    every time i press start
    hekH 1 Reply Last reply
    • HoffanH Hoffan
      @snow
      Did you use the Development version of the ESP8266 Wifi gatewavy or for the sensor
      snowS
      snowS
      snow
      wrote on last edited by snow
      At the moment I only changed the gateway. It's already solved my problem with incorrect values.
      HoffanH 1 Reply Last reply
      • snowS snow
        HoffanH
        HoffanH
        Hoffan
        @snow
        But is your include button working now?
        Or maybe you don't use Vera as a controller
        snowS 1 Reply Last reply
        • HoffanH Hoffan
          @Hoffan
          The print looks a bit weird. I'll have to do some tests.
          • HoffanH Hoffan
            @snow
            snowS
            snowS
            snow
            @Hoffan No. I'm using DomoticZ
              @Hoffan
              HoffanH
              HoffanH
              Hoffan
              @hek
              That sounds good, Just ask if you want me to test something..
              • HoffanH
                HoffanH
                Hoffan
                @hek
                Any News here ?
                • snowS
                  snowS
                  snow
                  Having another problem with a ESP8266 running as the gateway. Sensor build on Arduino Mini Pro loaded with example sketch DimmableLightWithRotaryEncoderButton.ino. Sensor and gateway firmware compiled from latest development branch v1.6 library.
                  The controller is a domoticz.
                  This is a output on the gateway console when I turn rotary encoder on the sensor.
                  0;0;3;0;2;1.6.0-beta
                  3;1;1;0;3;0
                  3;1;1;0;3;8
                  3;1;1;0;3;12
                  3;1;1;0;3;16
                  3;1;1;0;3;24
                  3;1;1;0;3;30
                  3;1;1;0;3;36
                  3;1;1;0;3;44
                  3;1;1;0;3;58
                  3;1;1;0;3;76
                  3;1;1;0;3;96
                  3;1;1;0;3;100
                  This is the output from gateway console when I move dimmer slider on the Domoticz
                  3;1;1;1;3;87t Version
                  3;1;1;1;3;80t Version
                  3;1;1;1;3;53t Version
                  3;1;1;1;3;47t Version
                  3;1;1;1;3;33t Version
                  3;1;1;1;3;20t Version
                  3;1;1;1;3;13t Version
                  3;1;1;1;3;73t Version
                  The problem is that the ESP8266 gateway append unnecessary characters t Version at the end of each line.
                  Also when dimmer slider is on the position 6%, gateway output is 3;1;1;1;3;73t Version Correct value should be 7 not 73
                    wrote on last edited by hek
                    #22
                    @snow
                    Could you perhaps enable "#define MY_DEBUG" in the gateway sketch?
                    Would alos be interesting to see the result when you add
                    Serial.println(inputString);
                    Here:
                    https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/core/MyProtocolMySensors.cpp#L36
                    • snowS
                      snowS
                      snow
                      #23
                      Here is the output from the gateway console when I rotate knob on the encoder.
                      connected with 00000000, channel 6
                      ip:192.168.0.110,mask:255.255.255.0,gw:192.168.0.1
                      .IP: 192.168.0.110
                      0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:24
                      0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:24
                      0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:26
                      0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:26
                      0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:28
                      0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:28
                      0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:30
                      0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:30
                      0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:32
                      0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:32
                      0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:34
                      0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:34
                      0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:36
                      0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:36
                      0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:38
                      0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:38
                      0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:40
                      0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:40
                      0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:42
                      0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:42
                      Here is output from the gateway console, when I slide down dimmer on the Domoticz
                      0;0;3;0;9;read: 3-3-0 s=1,c=1,t=2,pt=0,l=11,sg=0:03M Version
                      0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:0
                      0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:0
                      0;0;3;0;9;Client 0: 3;1;1;1;3;93M Version
                      0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:93M Version
                      0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=0,l=11,sg=0:93M Version
                      0;0;3;0;9;Client 0: 3;1;1;1;3;87M Version
                      0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:87M Version
                      0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=0,l=11,sg=0:87M Version
                      0;0;3;0;9;Client 0: 3;1;1;1;2;03M Version
                      0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=2,pt=0,l=11,sg=0,st=ok:03M Version
                      0;0;3;0;9;Client 0: 3;1;1;1;2;13M Version
                      0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=2,pt=0,l=11,sg=0,st=ok:13M Version
                      0;0;3;0;9;read: 3-3-0 s=1,c=1,t=2,pt=0,l=11,sg=0:13M Version
                      0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:93
                      0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:93
                      0;0;3;0;9;read: 3-3-0 s=255,c=0,t=17,pt=0,l=10,sg=0:1.6.0-beta
                      0;0;3;0;9;read: 3-3-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                      0;0;3;0;9;Client 0: 3;255;3;0;6;M Version
                      0;0;3;0;9;send: 0-0-3-3 s=255,c=3,t=6,pt=0,l=9,sg=0,st=ok:M Version
                      0;0;3;0;9;read: 3-3-0 s=1,c=0,t=4,pt=0,l=0,sg=0:
                      0;0;3;0;9;read: 3-3-0 s=255,c=3,t=11,pt=0,l=21,sg=0:DimmableLED /w bu
                      0;0;3;0;9;read: 3-3-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.2
                      0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=1,l=1,sg=0:93
                      0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=1,l=1,sg=0,st=ok:93
                      0;0;3;0;9;Client 0: 3;1;1;1;3;80M Version
                      0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:80M Version
                      0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=0,l=11,sg=0:80M Version
                      0;0;3;0;9;Client 0: 3;1;1;1;3;73M Version
                      0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:73M Version
                      0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=0,l=11,sg=0:73M Version
                      0;0;3;0;9;Client 0: 3;1;1;1;3;67M Version
                      0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:67M Version
                      0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=0,l=11,sg=0:67M Version
                      0;0;3;0;9;Client 0: 3;1;1;1;3;60M Version
                      0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:60M Version
                      0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=0,l=11,sg=0:60M Version
                      0;0;3;0;9;Client 0: 3;1;1;1;3;53M Version
                      0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:53M Version
                      0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=0,l=11,sg=0:53M Version
                      0;0;3;0;9;Client 0: 3;1;1;1;3;47M Version
                      0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:47M Version
                      0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=0,l=11,sg=0:47M Version
                      0;0;3;0;9;Client 0: 3;1;1;1;3;40M Version
                      0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:40M Version
                      0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=0,l=11,sg=0:40M Version
                      The output from sensor console
                      Starting...
                      send: 3-3-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=ok:1.6.0-beta
                      send: 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                      read: 0-0-3 s=255,c=3,t=6,pt=0,l=9,sg=0:M Version
                      send: 3-3-0-0 s=1,c=0,t=4,pt=0,l=0,sg=0,st=ok:
                      send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=21,sg=0,st=ok:DimmableLED /w button
                      send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.2
                      Sending in last known light level to controller: 93
                      send: 3-3-0-0 s=1,c=1,t=3,pt=1,l=1,sg=0,st=ok:93
                      Ready to receive messages...
                      read: 0-0-3 s=1,c=1,t=3,pt=1,l=1,sg=0:93
                      New light level received: 93
                      Fading level: 1
                      Fading level: 2
                      Fading level: 3
                      Fading level: 4
                      Fading level: 5
                      Fading level: 6
                      Fading level: 7
                      Fading level: 8
                      Fading level: 9
                      Fading level: 10
                      Fading level: 11
                      Fading level: 12
                      Fading level: 13
                      Fading level: 14
                      Fading level: 15
                      Fading level: 16
                      Fading level: 17
                      Fading level: 18
                      Fading level: 19
                      Fading level: 20
                      Fading level: 21
                      Fading level: 22
                      Fading level: 23
                      Fading level: 24
                      Fading level: 25
                      Fading level: 26
                      Fading level: 27
                      Fading level: 28
                      Fading level: 29
                      Fading level: 30
                      Fading level: 31
                      Fading level: 32
                      Fading level: 33
                      Fading level: 34
                      Fading level: 35
                      Fading level: 36
                      Fading level: 37
                      Fading level: 38
                      Fading level: 39
                      Fading level: 40
                      Fading level: 41
                      Fading level: 42
                      Fading level: 43
                      Fading level: 44
                      Fading level: 45
                      Fading level: 46
                      Fading level: 47
                      Fading level: 48
                      Fading level: 49
                      Fading level: 50
                      Fading level: 51
                      Fading level: 52
                      Fading level: 53
                      Fading level: 54
                      Fading level: 55
                      Fading level: 56
                      Fading level: 57
                      Fading level: 58
                      Fading level: 59
                      Fading level: 60
                      Fading level: 61
                      Fading level: 62
                      Fading level: 63
                      Fading level: 64
                      Fading level: 65
                      Fading level: 66
                      Fading level: 67
                      Fading level: 68
                      Fading level: 69
                      Fading level: 70
                      Fading level: 71
                      Fading level: 72
                      Fading level: 73
                      Fading level: 74
                      Fading level: 75
                      Fading level: 76
                      Fading level: 77
                      Fading level: 78
                      Fading level: 79
                      Fading level: 80
                      Fading level: 81
                      Fading level: 82
                      Fading level: 83
                      Fading level: 84
                      Fading level: 85
                      Fading level: 86
                      Fading level: 87
                      Fading level: 88
                      Fading level: 89
                      Fading level: 90
                      Fading level: 91
                      Fading level: 92
                      Fading level: 93
                      read: 0-0-3 s=1,c=1,t=3,pt=0,l=11,sg=0:80M Version
                      send: 3-3-0-0 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:80M Version
                      New light level received: 80
                      Fading level: 92
                      Fading level: 91
                      Fading level: 90
                      Fading level: 89
                      Fading level: 88
                      Fading level: 87
                      Fading level: 86
                      Fading level: 85
                      Fading level: 84
                      Fading level: 83
                      Fading level: 82
                      Fading level: 81
                      Fading level: 80
                      read: 0-0-3 s=1,c=1,t=3,pt=0,l=11,sg=0:73M Version
                      send: 3-3-0-0 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:73M Version
                      New light level received: 73
                      Fading level: 79
                      Fading level: 78
                      Fading level: 77
                      Fading level: 76
                      Fading level: 75
                      Fading level: 74
                      Fading level: 73
                      read: 0-0-3 s=1,c=1,t=3,pt=0,l=11,sg=0:67M Version
                      send: 3-3-0-0 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:67M Version
                      New light level received: 67
                      Fading level: 72
                      Fading level: 71
                      Fading level: 70
                      Fading level: 69
                      Fading level: 68
                      Fading level: 67
                      read: 0-0-3 s=1,c=1,t=3,pt=0,l=11,sg=0:60M Version
                      send: 3-3-0-0 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:60M Version
                      New light level received: 60
                      Fading level: 66
                      Fading level: 65
                      Fading level: 64
                      Fading level: 63
                      Fading level: 62
                      Fading level: 61
                      Fading level: 60
                      read: 0-0-3 s=1,c=1,t=3,pt=0,l=11,sg=0:53M Version
                      send: 3-3-0-0 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:53M Version
                      New light level received: 53
                      Fading level: 59
                      Fading level: 58
                      Fading level: 57
                      Fading level: 56
                      Fading level: 55
                      Fading level: 54
                      Fading level: 53
                      read: 0-0-3 s=1,c=1,t=3,pt=0,l=11,sg=0:47M Version
                      send: 3-3-0-0 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:47M Version
                      New light level received: 47
                      Fading level: 52
                      Fading level: 51
                      Fading level: 50
                      Fading level: 49
                      Fading level: 48
                      Fading level: 47
                      read: 0-0-3 s=1,c=1,t=3,pt=0,l=11,sg=0:40M Version
                      send: 3-3-0-0 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:40M Version
                      New light level received: 40
                      Fading level: 46
                      Fading level: 45
                      Fading level: 44
                      Fading level: 43
                      Fading level: 42
                      Fading level: 41
                      Fading level: 40
                      I hope it will be helpful
                        It almost looks like Domoticz sends the "Version" stuff. Is it possible to see what Domoticz sends? Anot logs over there?
                        • snowS
                          snowS
                          snow
                          Output from RPi console. pi@domoticz ~/domoticz $ sudo ./domoticz -verbose 1
                          2015-11-08 15:06:57.916  MySensors: connected to: 192.168.0.110:5003
                          2015-11-08 15:06:57.916  MySensors: Gateway Ready...
                          2015-11-08 15:06:58.917  MySensors: Gateway Version: 1.6.0-beta
                          2015-11-08 15:07:12.928  MySensors: Node: 3, Sketch Name: DimmableLED /w button
                          2015-11-08 15:07:13.932  MySensors: Node: 3, Sketch Version: 1.2
                          subtype       = AC
                          Sequence nbr  = 0
                          ID            = 0000003
                          Unit          = 1
                          Command       = On
                          2015-11-08 15:07:13.936  (MySensors) Lighting 2 (LED Dimmer)
                          subtype       = AC
                          Sequence nbr  = 0
                          ID            = 0000003
                          Unit          = 1
                          Command       = Set Level: 12
                          2015-11-08 15:07:32.010  (MySensors) Lighting 2 (LED Dimmer)
                          subtype       = AC
                          Sequence nbr  = 1
                          ID            = 0000003
                          Unit          = 1
                          Command       = Set Level: 11
                          2015-11-08 15:07:33.981  (MySensors) Lighting 2 (LED Dimmer)
                          subtype       = AC
                          Sequence nbr  = 2
                          ID            = 0000003
                          Unit          = 1
                          Command       = Set Level: 10
                          2015-11-08 15:07:35.984  (MySensors) Lighting 2 (LED Dimmer)
                          subtype       = AC
                          Sequence nbr  = 3
                          ID            = 0000003
                          Unit          = 1
                          Command       = Set Level: 9
                          2015-11-08 15:07:38.055  (MySensors) Lighting 2 (LED Dimmer)
                          subtype       = AC
                          Sequence nbr  = 4
                          ID            = 0000003
                          Unit          = 1
                          Command       = Set Level: 8
                          I'll try to build Serial Gateway and do the same test
                          • GizMoCuzG
                            GizMoCuzG
                            GizMoCuz
                            There is a small problem with domoticz regarding the light level (fixed in beta #3563)
                            When the slider was set to 100%, around 93% was send to the node
                            BUT, what domoticz sends, is OK, there is NO version stuff added (really strange your seeing this!)
                            I made a test sketch, and this is the output:
                            Starting...
                            send: 254-254-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=ok:1.6.0-beta
                            send: 254-254-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                            read: 0-0-254 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                            send: 254-254-0-0 s=1,c=0,t=4,pt=0,l=0,sg=0,st=ok:
                            send: 254-254-0-0 s=255,c=3,t=11,pt=0,l=21,sg=0,st=ok:DimmableLED /w button
                            send: 254-254-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.2
                            sensor started, id=254, parent=0, distance=1
                            read: 0-0-254 s=1,c=1,t=2,pt=0,l=1,sg=0:0
                            send: 254-254-0-0 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:0
                            V_LIGHT received: 0
                            read: 0-0-254 s=1,c=1,t=2,pt=0,l=1,sg=0:1
                            send: 254-254-0-0 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:1
                            V_LIGHT received: 1
                            read: 0-0-254 s=1,c=1,t=3,pt=0,l=2,sg=0:43
                            send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:43
                            V_DIMMER received: 43
                            read: 0-0-254 s=1,c=1,t=3,pt=0,l=2,sg=0:86
                            send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:86
                            V_DIMMER received: 86
                            read: 0-0-254 s=1,c=1,t=3,pt=0,l=3,sg=0:100
                            send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=3,sg=0,st=ok:100
                            V_DIMMER received: 100
                            All perfect
                            Sketch:
                            // Enable debug prints
                            #define MY_NODE_ID 254
                            #define SN "DimmableLED /w button"
                            #define SV "1.2"
                            #define CHILD_ID_LIGHT 1
                            MyMessage dimmerMsg(CHILD_ID_LIGHT, V_DIMMER);
                            Serial.println("Ready to receive messages...");
                            present(CHILD_ID_LIGHT, S_DIMMER);
                            sendSketchInfo(SN, SV);
                            Serial.print("V_LIGHT received: ");
                            } else if (message.type == V_DIMMER) {
                            Serial.print("V_DIMMER received: ");
                            else {
                            Serial.print("Unhandled message received: ");
                              @GizMoCuz
                              How do you terminate the strings in Domoticz? Only \n or both \n and \r?
                              Does the controller have exactly the same behaviour when communicating with an ethernet gateway as serial gateway?
                              • GizMoCuzG GizMoCuz
                                Starting...
                                V_LIGHT received: 0
                                V_LIGHT received: 1
                                All perfect
                                Sketch:
                                #define SV "1.2"
                                else {
                                snowS
                                snowS
                                snow
                                @GizMoCuz
                                I have tested Your sketch and the same stuff is added at the end
                                Starting...
                                read: 0-0-254 s=255,c=3,t=6,pt=0,l=7,sg=0:Mersion
                                V_LIGHT received: 0
                                V_LIGHT received: 1
                                read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:93Mersion
                                send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:93Mersion
                                V_DIMMER received: 93Mersion
                                read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:86Mersion
                                send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:86Mersion
                                V_DIMMER received: 86Mersion
                                read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:79Mersion
                                send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:79Mersion
                                V_DIMMER received: 79Mersion
                                read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:71Mersion
                                send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:71Mersion
                                V_DIMMER received: 71Mersion
                                read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:64Mersion
                                send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:64Mersion
                                V_DIMMER received: 64Mersion
                                read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:57Mersion
                                send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:57Mersion
                                V_DIMMER received: 57Mersion
                                read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:50Mersion
                                send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:50Mersion
                                V_DIMMER received: 50Mersion
                                read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:43Mersion
                                send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:43Mersion
                                V_DIMMER received: 43Mersion
                                read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:36Mersion
                                send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:36Mersion
                                V_DIMMER received: 36Mersion
                                read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:29Mersion
                                send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:29Mersion
                                V_DIMMER received: 29Mersion
                                read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:21Mersion
                                send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:21Mersion
                                V_DIMMER received: 21Mersion
                                read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:14Mersion
                                send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:14Mersion
                                V_DIMMER received: 14Mersion
                                read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:74Mersion
                                send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:74Mersion
                                V_DIMMER received: 74Mersion
                                read: 0-0-254 s=1,c=1,t=2,pt=0,l=9,sg=0:04Mersion
                                send: 254-254-0-0 s=1,c=1,t=2,pt=0,l=9,sg=0,st=ok:04Mersion
                                V_LIGHT received: 04Mersion
                                Is it possible as some crap is sitting in my ESP8266 EEPROM memory?
                                • GizMoCuzG
                                  GizMoCuzG
                                  GizMoCuz
                                  wrote on last edited by GizMoCuz
                                  #29
                                  @hek, with \n
                                  MySensors is implemented in domoticz for a long time now... there should be nothing wrong with it.....
                                  Also in my sketches all is received perfectly
                                  Could there be a difference between the ESP8266 and nRF ?
                                  I only use the nRF currently (and probably will for ever as i have 20 more chips and a lot more arduino's g)
                                  Also i do not send anything with the word version in it, it looks this is a left over from sending the sketch information ?
                                  I dont know how you guys get that nice colors in the log (brown/white/green), but the green number is OK, that white behind it is not
                                  • GizMoCuzG
                                    GizMoCuzG
                                    GizMoCuz
                                    @hek, as demonstrated with the new V_CUSTOM, there is send a lot of information from domoticz -> node, and all prints well, so maybe thats a confirm that this part is working OK (at least on the nRF024)
                                    • GizMoCuzG
                                      GizMoCuzG
                                      GizMoCuz
                                      I also find it strange that at the beginning V_LIGHT correctly displays 0 or 1, and at the end 04 ? (0 = OK)
                                      • snowS
                                        snowS
                                        snow
                                        I made a Serial Gateway and updated Domoticz to latest beta, and this is the output from the same sensor.
                                        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=1,sg=0,st=ok:7
                                        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=1,sg=0:7
                                        2;1;1;1;3;7
                                        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:14
                                        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:14
                                        2;1;1;1;3;14
                                        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:21
                                        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:21
                                        2;1;1;1;3;21
                                        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:29
                                        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:29
                                        2;1;1;1;3;29
                                        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:36
                                        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:36
                                        2;1;1;1;3;36
                                        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:43
                                        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:43
                                        2;1;1;1;3;43
                                        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:50
                                        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:50
                                        2;1;1;1;3;50
                                        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:57
                                        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:57
                                        2;1;1;1;3;57
                                        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:64
                                        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:64
                                        2;1;1;1;3;64
                                        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:71
                                        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:71
                                        2;1;1;1;3;71
                                        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:79
                                        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:79
                                        2;1;1;1;3;79
                                        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:86
                                        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:86
                                        2;1;1;1;3;86
                                        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:93
                                        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:93
                                        2;1;1;1;3;93
                                        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=3,sg=0,st=ok:100
                                        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=3,sg=0:100
                                        2;1;1;1;3;100
                                        All OK
                                          @snow
                                          Could you try replacing this in MySensors/core/MyGatewayTransportEthernet.cpp
                                          bool _readFromClient(uint8_t i) {
                                          	while (clients[i].connected() && clients[i].available()) {
                                          		char inChar = clients[i].read();
                                          		if (inputString[i].idx < MY_GATEWAY_MAX_RECEIVE_LENGTH - 1) {
                                          			// if newline then command is complete
                                          			if (inChar == '\n') {
                                          				// a command was issued by the client
                                          				// we will now try to send it to the actuator
                                          				// echo the string to the serial port
                                          				debug(PSTR("Client %d: %s\n"), i, inputString[i].string);
                                          				// add string terminator and clear the string:
                                          				inputString[i].string[inputString[i].idx] = 0;
                                          				inputString[i].idx = 0;
                                          				bool ret = protocolParse(_ethernetMsg, inputString[i].string);
                                          				if (ret) {
                                          					return ret;
                                          				// add it to the inputString:
                                          				inputString[i].string[inputString[i].idx++] = inChar;
                                          			debug(PSTR("Client %d: Message too long\n"), i);
                                          			// Finished with this client's message. Next loop() we'll see if there's more to read.
                                          	return false;
                                          And let me know how it behaves.
