  2. Bug Reports
  3. ESP8266 WiFi gateway issue
49 Posts 6 Posters 28.4k Views 3 Watching
  • HoffanH Hoffan
    @snow
    But is your include button working now?
    Or maybe you don't use Vera as a controller
    snowS
    snowS
    snow
    @Hoffan No. I'm using DomoticZ
      @Hoffan
      The print looks a bit weird. I'll have to do some tests.
      HoffanH
      HoffanH
      Hoffan
      @hek
      That sounds good, Just ask if you want me to test something..
      • HoffanH
        HoffanH
        Hoffan
        @hek
        Any News here ?
        • snowS
          snowS
          snow
          Having another problem with a ESP8266 running as the gateway. Sensor build on Arduino Mini Pro loaded with example sketch DimmableLightWithRotaryEncoderButton.ino. Sensor and gateway firmware compiled from latest development branch v1.6 library.
          The controller is a domoticz.
          This is a output on the gateway console when I turn rotary encoder on the sensor.
          0;0;3;0;2;1.6.0-beta
          3;1;1;0;3;0
          3;1;1;0;3;8
          3;1;1;0;3;12
          3;1;1;0;3;16
          3;1;1;0;3;24
          3;1;1;0;3;30
          3;1;1;0;3;36
          3;1;1;0;3;44
          3;1;1;0;3;58
          3;1;1;0;3;76
          3;1;1;0;3;96
          3;1;1;0;3;100
          This is the output from gateway console when I move dimmer slider on the Domoticz
          3;1;1;1;3;87t Version
          3;1;1;1;3;80t Version
          3;1;1;1;3;53t Version
          3;1;1;1;3;47t Version
          3;1;1;1;3;33t Version
          3;1;1;1;3;20t Version
          3;1;1;1;3;13t Version
          3;1;1;1;3;73t Version
          The problem is that the ESP8266 gateway append unnecessary characters t Version at the end of each line.
          Also when dimmer slider is on the position 6%, gateway output is 3;1;1;1;3;73t Version Correct value should be 7 not 73
            wrote on last edited by hek
            #22
            @snow
            Could you perhaps enable "#define MY_DEBUG" in the gateway sketch?
            Would alos be interesting to see the result when you add
            Serial.println(inputString);
            Here:
            https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/core/MyProtocolMySensors.cpp#L36
            • snowS
              snowS
              snow
              wrote on last edited by snow
              #23
              Here is the output from the gateway console when I rotate knob on the encoder.
              connected with 00000000, channel 6
              ip:192.168.0.110,mask:255.255.255.0,gw:192.168.0.1
              .IP: 192.168.0.110
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:24
              0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:24
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:26
              0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:26
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:28
              0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:28
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:30
              0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:30
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:32
              0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:32
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:34
              0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:34
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:36
              0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:36
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:38
              0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:38
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:40
              0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:40
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:42
              0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:42
              Here is output from the gateway console, when I slide down dimmer on the Domoticz
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=2,pt=0,l=11,sg=0:03M Version
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:0
              0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:0
              0;0;3;0;9;Client 0: 3;1;1;1;3;93M Version
              0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:93M Version
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=0,l=11,sg=0:93M Version
              0;0;3;0;9;Client 0: 3;1;1;1;3;87M Version
              0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:87M Version
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=0,l=11,sg=0:87M Version
              0;0;3;0;9;Client 0: 3;1;1;1;2;03M Version
              0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=2,pt=0,l=11,sg=0,st=ok:03M Version
              0;0;3;0;9;Client 0: 3;1;1;1;2;13M Version
              0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=2,pt=0,l=11,sg=0,st=ok:13M Version
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=2,pt=0,l=11,sg=0:13M Version
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:93
              0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:93
              0;0;3;0;9;read: 3-3-0 s=255,c=0,t=17,pt=0,l=10,sg=0:1.6.0-beta
              0;0;3;0;9;read: 3-3-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
              0;0;3;0;9;Client 0: 3;255;3;0;6;M Version
              0;0;3;0;9;send: 0-0-3-3 s=255,c=3,t=6,pt=0,l=9,sg=0,st=ok:M Version
              0;0;3;0;9;read: 3-3-0 s=1,c=0,t=4,pt=0,l=0,sg=0:
              0;0;3;0;9;read: 3-3-0 s=255,c=3,t=11,pt=0,l=21,sg=0:DimmableLED /w bu
              0;0;3;0;9;read: 3-3-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.2
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=1,l=1,sg=0:93
              0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=1,l=1,sg=0,st=ok:93
              0;0;3;0;9;Client 0: 3;1;1;1;3;80M Version
              0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:80M Version
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=0,l=11,sg=0:80M Version
              0;0;3;0;9;Client 0: 3;1;1;1;3;73M Version
              0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:73M Version
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=0,l=11,sg=0:73M Version
              0;0;3;0;9;Client 0: 3;1;1;1;3;67M Version
              0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:67M Version
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=0,l=11,sg=0:67M Version
              0;0;3;0;9;Client 0: 3;1;1;1;3;60M Version
              0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:60M Version
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=0,l=11,sg=0:60M Version
              0;0;3;0;9;Client 0: 3;1;1;1;3;53M Version
              0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:53M Version
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=0,l=11,sg=0:53M Version
              0;0;3;0;9;Client 0: 3;1;1;1;3;47M Version
              0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:47M Version
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=0,l=11,sg=0:47M Version
              0;0;3;0;9;Client 0: 3;1;1;1;3;40M Version
              0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:40M Version
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=0,l=11,sg=0:40M Version
              The output from sensor console
              Starting...
              send: 3-3-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=ok:1.6.0-beta
              send: 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
              read: 0-0-3 s=255,c=3,t=6,pt=0,l=9,sg=0:M Version
              send: 3-3-0-0 s=1,c=0,t=4,pt=0,l=0,sg=0,st=ok:
              send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=21,sg=0,st=ok:DimmableLED /w button
              send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.2
              Sending in last known light level to controller: 93
              send: 3-3-0-0 s=1,c=1,t=3,pt=1,l=1,sg=0,st=ok:93
              Ready to receive messages...
              read: 0-0-3 s=1,c=1,t=3,pt=1,l=1,sg=0:93
              New light level received: 93
              Fading level: 1
              Fading level: 2
              Fading level: 3
              Fading level: 4
              Fading level: 5
              Fading level: 6
              Fading level: 7
              Fading level: 8
              Fading level: 9
              Fading level: 10
              Fading level: 11
              Fading level: 12
              Fading level: 13
              Fading level: 14
              Fading level: 15
              Fading level: 16
              Fading level: 17
              Fading level: 18
              Fading level: 19
              Fading level: 20
              Fading level: 21
              Fading level: 22
              Fading level: 23
              Fading level: 24
              Fading level: 25
              Fading level: 26
              Fading level: 27
              Fading level: 28
              Fading level: 29
              Fading level: 30
              Fading level: 31
              Fading level: 32
              Fading level: 33
              Fading level: 34
              Fading level: 35
              Fading level: 36
              Fading level: 37
              Fading level: 38
              Fading level: 39
              Fading level: 40
              Fading level: 41
              Fading level: 42
              Fading level: 43
              Fading level: 44
              Fading level: 45
              Fading level: 46
              Fading level: 47
              Fading level: 48
              Fading level: 49
              Fading level: 50
              Fading level: 51
              Fading level: 52
              Fading level: 53
              Fading level: 54
              Fading level: 55
              Fading level: 56
              Fading level: 57
              Fading level: 58
              Fading level: 59
              Fading level: 60
              Fading level: 61
              Fading level: 62
              Fading level: 63
              Fading level: 64
              Fading level: 65
              Fading level: 66
              Fading level: 67
              Fading level: 68
              Fading level: 69
              Fading level: 70
              Fading level: 71
              Fading level: 72
              Fading level: 73
              Fading level: 74
              Fading level: 75
              Fading level: 76
              Fading level: 77
              Fading level: 78
              Fading level: 79
              Fading level: 80
              Fading level: 81
              Fading level: 82
              Fading level: 83
              Fading level: 84
              Fading level: 85
              Fading level: 86
              Fading level: 87
              Fading level: 88
              Fading level: 89
              Fading level: 90
              Fading level: 91
              Fading level: 92
              Fading level: 93
              read: 0-0-3 s=1,c=1,t=3,pt=0,l=11,sg=0:80M Version
              send: 3-3-0-0 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:80M Version
              New light level received: 80
              Fading level: 92
              Fading level: 91
              Fading level: 90
              Fading level: 89
              Fading level: 88
              Fading level: 87
              Fading level: 86
              Fading level: 85
              Fading level: 84
              Fading level: 83
              Fading level: 82
              Fading level: 81
              Fading level: 80
              read: 0-0-3 s=1,c=1,t=3,pt=0,l=11,sg=0:73M Version
              send: 3-3-0-0 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:73M Version
              New light level received: 73
              Fading level: 79
              Fading level: 78
              Fading level: 77
              Fading level: 76
              Fading level: 75
              Fading level: 74
              Fading level: 73
              read: 0-0-3 s=1,c=1,t=3,pt=0,l=11,sg=0:67M Version
              send: 3-3-0-0 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:67M Version
              New light level received: 67
              Fading level: 72
              Fading level: 71
              Fading level: 70
              Fading level: 69
              Fading level: 68
              Fading level: 67
              read: 0-0-3 s=1,c=1,t=3,pt=0,l=11,sg=0:60M Version
              send: 3-3-0-0 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:60M Version
              New light level received: 60
              Fading level: 66
              Fading level: 65
              Fading level: 64
              Fading level: 63
              Fading level: 62
              Fading level: 61
              Fading level: 60
              read: 0-0-3 s=1,c=1,t=3,pt=0,l=11,sg=0:53M Version
              send: 3-3-0-0 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:53M Version
              New light level received: 53
              Fading level: 59
              Fading level: 58
              Fading level: 57
              Fading level: 56
              Fading level: 55
              Fading level: 54
              Fading level: 53
              read: 0-0-3 s=1,c=1,t=3,pt=0,l=11,sg=0:47M Version
              send: 3-3-0-0 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:47M Version
              New light level received: 47
              Fading level: 52
              Fading level: 51
              Fading level: 50
              Fading level: 49
              Fading level: 48
              Fading level: 47
              read: 0-0-3 s=1,c=1,t=3,pt=0,l=11,sg=0:40M Version
              send: 3-3-0-0 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:40M Version
              New light level received: 40
              Fading level: 46
              Fading level: 45
              Fading level: 44
              Fading level: 43
              Fading level: 42
              Fading level: 41
              Fading level: 40
              I hope it will be helpful
                It almost looks like Domoticz sends the "Version" stuff. Is it possible to see what Domoticz sends? Anot logs over there?
                • snowS
                  snowS
                  snow
                  Output from RPi console. pi@domoticz ~/domoticz $ sudo ./domoticz -verbose 1
                  2015-11-08 15:06:57.916  MySensors: connected to: 192.168.0.110:5003
                  2015-11-08 15:06:57.916  MySensors: Gateway Ready...
                  2015-11-08 15:06:58.917  MySensors: Gateway Version: 1.6.0-beta
                  2015-11-08 15:07:12.928  MySensors: Node: 3, Sketch Name: DimmableLED /w button
                  2015-11-08 15:07:13.932  MySensors: Node: 3, Sketch Version: 1.2
                  subtype       = AC
                  Sequence nbr  = 0
                  ID            = 0000003
                  Unit          = 1
                  Command       = On
                  2015-11-08 15:07:13.936  (MySensors) Lighting 2 (LED Dimmer)
                  subtype       = AC
                  Sequence nbr  = 0
                  ID            = 0000003
                  Unit          = 1
                  Command       = Set Level: 12
                  2015-11-08 15:07:32.010  (MySensors) Lighting 2 (LED Dimmer)
                  subtype       = AC
                  Sequence nbr  = 1
                  ID            = 0000003
                  Unit          = 1
                  Command       = Set Level: 11
                  2015-11-08 15:07:33.981  (MySensors) Lighting 2 (LED Dimmer)
                  subtype       = AC
                  Sequence nbr  = 2
                  ID            = 0000003
                  Unit          = 1
                  Command       = Set Level: 10
                  2015-11-08 15:07:35.984  (MySensors) Lighting 2 (LED Dimmer)
                  subtype       = AC
                  Sequence nbr  = 3
                  ID            = 0000003
                  Unit          = 1
                  Command       = Set Level: 9
                  2015-11-08 15:07:38.055  (MySensors) Lighting 2 (LED Dimmer)
                  subtype       = AC
                  Sequence nbr  = 4
                  ID            = 0000003
                  Unit          = 1
                  Command       = Set Level: 8
                  I'll try to build Serial Gateway and do the same test
                  • GizMoCuzG
                    GizMoCuzG
                    GizMoCuz
                    There is a small problem with domoticz regarding the light level (fixed in beta #3563)
                    When the slider was set to 100%, around 93% was send to the node
                    BUT, what domoticz sends, is OK, there is NO version stuff added (really strange your seeing this!)
                    I made a test sketch, and this is the output:
                    Starting...
                    send: 254-254-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=ok:1.6.0-beta
                    send: 254-254-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                    read: 0-0-254 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                    send: 254-254-0-0 s=1,c=0,t=4,pt=0,l=0,sg=0,st=ok:
                    send: 254-254-0-0 s=255,c=3,t=11,pt=0,l=21,sg=0,st=ok:DimmableLED /w button
                    send: 254-254-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.2
                    sensor started, id=254, parent=0, distance=1
                    read: 0-0-254 s=1,c=1,t=2,pt=0,l=1,sg=0:0
                    send: 254-254-0-0 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:0
                    V_LIGHT received: 0
                    read: 0-0-254 s=1,c=1,t=2,pt=0,l=1,sg=0:1
                    send: 254-254-0-0 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:1
                    V_LIGHT received: 1
                    read: 0-0-254 s=1,c=1,t=3,pt=0,l=2,sg=0:43
                    send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:43
                    V_DIMMER received: 43
                    read: 0-0-254 s=1,c=1,t=3,pt=0,l=2,sg=0:86
                    send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:86
                    V_DIMMER received: 86
                    read: 0-0-254 s=1,c=1,t=3,pt=0,l=3,sg=0:100
                    send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=3,sg=0,st=ok:100
                    V_DIMMER received: 100
                    All perfect
                    Sketch:
                    // Enable debug prints
                    #define MY_NODE_ID 254
                    #define SN "DimmableLED /w button"
                    #define SV "1.2"
                    #define CHILD_ID_LIGHT 1
                    MyMessage dimmerMsg(CHILD_ID_LIGHT, V_DIMMER);
                    Serial.println("Ready to receive messages...");
                    present(CHILD_ID_LIGHT, S_DIMMER);
                    sendSketchInfo(SN, SV);
                    Serial.print("V_LIGHT received: ");
                    } else if (message.type == V_DIMMER) {
                    Serial.print("V_DIMMER received: ");
                    else {
                    Serial.print("Unhandled message received: ");
                    snowS 1 Reply Last reply
                      @GizMoCuz
                      How do you terminate the strings in Domoticz? Only \n or both \n and \r?
                      Does the controller have exactly the same behaviour when communicating with an ethernet gateway as serial gateway?
                      • GizMoCuzG GizMoCuz
                        Starting...
                        V_LIGHT received: 0
                        V_LIGHT received: 1
                        All perfect
                        Sketch:
                        #define SV "1.2"
                        else {
                        snowS
                        snowS
                        snow
                        @GizMoCuz
                        I have tested Your sketch and the same stuff is added at the end
                        Starting...
                        read: 0-0-254 s=255,c=3,t=6,pt=0,l=7,sg=0:Mersion
                        V_LIGHT received: 0
                        V_LIGHT received: 1
                        read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:93Mersion
                        send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:93Mersion
                        V_DIMMER received: 93Mersion
                        read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:86Mersion
                        send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:86Mersion
                        V_DIMMER received: 86Mersion
                        read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:79Mersion
                        send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:79Mersion
                        V_DIMMER received: 79Mersion
                        read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:71Mersion
                        send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:71Mersion
                        V_DIMMER received: 71Mersion
                        read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:64Mersion
                        send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:64Mersion
                        V_DIMMER received: 64Mersion
                        read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:57Mersion
                        send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:57Mersion
                        V_DIMMER received: 57Mersion
                        read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:50Mersion
                        send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:50Mersion
                        V_DIMMER received: 50Mersion
                        read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:43Mersion
                        send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:43Mersion
                        V_DIMMER received: 43Mersion
                        read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:36Mersion
                        send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:36Mersion
                        V_DIMMER received: 36Mersion
                        read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:29Mersion
                        send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:29Mersion
                        V_DIMMER received: 29Mersion
                        read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:21Mersion
                        send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:21Mersion
                        V_DIMMER received: 21Mersion
                        read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:14Mersion
                        send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:14Mersion
                        V_DIMMER received: 14Mersion
                        read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:74Mersion
                        send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:74Mersion
                        V_DIMMER received: 74Mersion
                        read: 0-0-254 s=1,c=1,t=2,pt=0,l=9,sg=0:04Mersion
                        send: 254-254-0-0 s=1,c=1,t=2,pt=0,l=9,sg=0,st=ok:04Mersion
                        V_LIGHT received: 04Mersion
                        Is it possible as some crap is sitting in my ESP8266 EEPROM memory?
                        • GizMoCuzG
                          GizMoCuzG
                          GizMoCuz
                          wrote on last edited by GizMoCuz
                          #29
                          @hek, with \n
                          MySensors is implemented in domoticz for a long time now... there should be nothing wrong with it.....
                          Also in my sketches all is received perfectly
                          Could there be a difference between the ESP8266 and nRF ?
                          I only use the nRF currently (and probably will for ever as i have 20 more chips and a lot more arduino's g)
                          Also i do not send anything with the word version in it, it looks this is a left over from sending the sketch information ?
                          I dont know how you guys get that nice colors in the log (brown/white/green), but the green number is OK, that white behind it is not
                          • GizMoCuzG
                            GizMoCuzG
                            GizMoCuz
                            @hek, as demonstrated with the new V_CUSTOM, there is send a lot of information from domoticz -> node, and all prints well, so maybe thats a confirm that this part is working OK (at least on the nRF024)
                            • GizMoCuzG
                              GizMoCuzG
                              GizMoCuz
                              I also find it strange that at the beginning V_LIGHT correctly displays 0 or 1, and at the end 04 ? (0 = OK)
                              • snowS
                                snowS
                                snow
                                I made a Serial Gateway and updated Domoticz to latest beta, and this is the output from the same sensor.
                                0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=1,sg=0,st=ok:7
                                0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=1,sg=0:7
                                2;1;1;1;3;7
                                0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:14
                                0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:14
                                2;1;1;1;3;14
                                0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:21
                                0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:21
                                2;1;1;1;3;21
                                0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:29
                                0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:29
                                2;1;1;1;3;29
                                0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:36
                                0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:36
                                2;1;1;1;3;36
                                0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:43
                                0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:43
                                2;1;1;1;3;43
                                0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:50
                                0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:50
                                2;1;1;1;3;50
                                0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:57
                                0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:57
                                2;1;1;1;3;57
                                0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:64
                                0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:64
                                2;1;1;1;3;64
                                0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:71
                                0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:71
                                2;1;1;1;3;71
                                0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:79
                                0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:79
                                2;1;1;1;3;79
                                0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:86
                                0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:86
                                2;1;1;1;3;86
                                0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:93
                                0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:93
                                2;1;1;1;3;93
                                0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=3,sg=0,st=ok:100
                                0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=3,sg=0:100
                                2;1;1;1;3;100
                                All OK
                                  @snow
                                  Could you try replacing this in MySensors/core/MyGatewayTransportEthernet.cpp
                                  bool _readFromClient(uint8_t i) {
                                  	while (clients[i].connected() && clients[i].available()) {
                                  		char inChar = clients[i].read();
                                  		if (inputString[i].idx < MY_GATEWAY_MAX_RECEIVE_LENGTH - 1) {
                                  			// if newline then command is complete
                                  			if (inChar == '\n') {
                                  				// a command was issued by the client
                                  				// we will now try to send it to the actuator
                                  				// echo the string to the serial port
                                  				debug(PSTR("Client %d: %s\n"), i, inputString[i].string);
                                  				// add string terminator and clear the string:
                                  				inputString[i].string[inputString[i].idx] = 0;
                                  				inputString[i].idx = 0;
                                  				bool ret = protocolParse(_ethernetMsg, inputString[i].string);
                                  				if (ret) {
                                  					return ret;
                                  				// add it to the inputString:
                                  				inputString[i].string[inputString[i].idx++] = inChar;
                                  			debug(PSTR("Client %d: Message too long\n"), i);
                                  			// Finished with this client's message. Next loop() we'll see if there's more to read.
                                  	return false;
                                  And let me know how it behaves.
                                  • GizMoCuzG
                                    GizMoCuzG
                                    GizMoCuz
                                    I think that will solve the issue... @snow, waiting patiently for your reply ;)
                                    • snowS
                                      snowS
                                      snow
                                      It's much better now. I can control dimmer from the domoticz. :)
                                      0;0;3;0;9;Client 0 connected
                                      0;0;3;0;9;Client 0: 0;0;3;0;2;Get Version
                                      0;0;3;0;9;read: 2-2-0 s=255,c=0,t=17,pt=0,l=10,sg=0:1.6.0-beta
                                      0;0;3;0;9;read: 2-2-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                      0;0;3;0;9;Client 0: 2;255;3;0;6;M Version
                                      2;255;3;0;6;M
                                      0;0;3;0;9;send: 0-0-2-2 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
                                      0;0;3;0;9;read: 2-2-0 s=1,c=0,t=4,pt=0,l=0,sg=0:
                                      0;0;3;0;9;read: 2-2-0 s=255,c=3,t=11,pt=0,l=21,sg=0:DimmableLED /w bu
                                      0;0;3;0;9;read: 2-2-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.2
                                      0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=1,l=1,sg=0:100
                                      0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=1,l=1,sg=0,st=ok:100
                                      0;0;3;0;9;Client 0: 2;1;1;1;3;93M
                                      2;1;1;1;3;93
                                      0;0;3;0;9;Client 0: 2;1;1;1;3;86
                                      2;1;1;1;3;86
                                      0;0;3;0;9;Client 0: 2;1;1;1;3;79
                                      2;1;1;1;3;79
                                      0;0;3;0;9;Client 0: 2;1;1;1;3;71
                                      2;1;1;1;3;71
                                      0;0;3;0;9;Client 0: 2;1;1;1;3;64
                                      2;1;1;1;3;64
                                      0;0;3;0;9;Client 0: 2;1;1;1;3;57
                                      2;1;1;1;3;57
                                      0;0;3;0;9;Client 0: 2;1;1;1;3;50
                                      2;1;1;1;3;50
                                      0;0;3;0;9;Client 0: 2;1;1;1;3;43
                                      2;1;1;1;3;43
                                      0;0;3;0;9;Client 0: 2;1;1;1;3;36
                                      2;1;1;1;3;36
                                      2;1;1;1;3;36
                                      0;0;3;0;9;Client 0: 2;1;1;1;3;29
                                      2;1;1;1;3;29
                                      0;0;3;0;9;Client 0: 2;1;1;1;3;21
                                      2;1;1;1;3;21
                                      0;0;3;0;9;Client 0: 2;1;1;1;3;14
                                      2;1;1;1;3;14
                                      0;0;3;0;9;Client 0: 2;1;1;1;3;74
                                      2;1;1;1;3;7
                                      0;0;3;0;9;Client 0: 2;1;1;1;2;0
                                      2;1;1;1;2;0
                                      0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:0
                                      0;0;3;0;9;read: 2-2-0 s=1,c=1,t=2,pt=0,l=1,sg=0:0
                                      0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=2,l=2,sg=0:0
                                      0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:0
                                        Great, I'll push this fix ASAP.
                                        • HoffanH
                                          HoffanH
                                          Hoffan
                                          @Hoffan said:
                                          anyone that knows if include button working now? With vera as controller
