  2. Bug Reports
  3. ESP8266 WiFi gateway issue
49 Posts 6 Posters 28.4k Views 3 Watching
    @GizMoCuz
    How do you terminate the strings in Domoticz? Only \n or both \n and \r?
    Does the controller have exactly the same behaviour when communicating with an ethernet gateway as serial gateway?
    • GizMoCuzG GizMoCuz
      There is a small problem with domoticz regarding the light level (fixed in beta #3563)
      When the slider was set to 100%, around 93% was send to the node
      BUT, what domoticz sends, is OK, there is NO version stuff added (really strange your seeing this!)
      I made a test sketch, and this is the output:
      Starting...
      send: 254-254-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=ok:1.6.0-beta
      send: 254-254-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
      read: 0-0-254 s=255,c=3,t=6,pt=0,l=1,sg=0:M
      send: 254-254-0-0 s=1,c=0,t=4,pt=0,l=0,sg=0,st=ok:
      send: 254-254-0-0 s=255,c=3,t=11,pt=0,l=21,sg=0,st=ok:DimmableLED /w button
      send: 254-254-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.2
      sensor started, id=254, parent=0, distance=1
      Ready to receive messages...
      read: 0-0-254 s=1,c=1,t=2,pt=0,l=1,sg=0:0
      send: 254-254-0-0 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:0
      V_LIGHT received: 0
      read: 0-0-254 s=1,c=1,t=2,pt=0,l=1,sg=0:1
      send: 254-254-0-0 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:1
      V_LIGHT received: 1
      read: 0-0-254 s=1,c=1,t=3,pt=0,l=2,sg=0:43
      send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:43
      V_DIMMER received: 43
      read: 0-0-254 s=1,c=1,t=3,pt=0,l=2,sg=0:86
      send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:86
      V_DIMMER received: 86
      read: 0-0-254 s=1,c=1,t=3,pt=0,l=3,sg=0:100
      send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=3,sg=0,st=ok:100
      V_DIMMER received: 100
      All perfect
      Sketch:
      // Enable debug prints
      #define MY_NODE_ID 254
      #define SN "DimmableLED /w button"
      #define SV "1.2"
      #define CHILD_ID_LIGHT 1
      MyMessage dimmerMsg(CHILD_ID_LIGHT, V_DIMMER);
      Serial.println("Ready to receive messages...");
      present(CHILD_ID_LIGHT, S_DIMMER);
      sendSketchInfo(SN, SV);
      Serial.print("V_LIGHT received: ");
      } else if (message.type == V_DIMMER) {
      Serial.print("V_DIMMER received: ");
      else {
      Serial.print("Unhandled message received: ");
      snowS
      snowS
      snow
      @GizMoCuz
      I have tested Your sketch and the same stuff is added at the end
      Starting...
      read: 0-0-254 s=255,c=3,t=6,pt=0,l=7,sg=0:Mersion
      V_LIGHT received: 0
      V_LIGHT received: 1
      read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:93Mersion
      send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:93Mersion
      V_DIMMER received: 93Mersion
      read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:86Mersion
      send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:86Mersion
      V_DIMMER received: 86Mersion
      read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:79Mersion
      send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:79Mersion
      V_DIMMER received: 79Mersion
      read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:71Mersion
      send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:71Mersion
      V_DIMMER received: 71Mersion
      read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:64Mersion
      send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:64Mersion
      V_DIMMER received: 64Mersion
      read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:57Mersion
      send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:57Mersion
      V_DIMMER received: 57Mersion
      read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:50Mersion
      send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:50Mersion
      V_DIMMER received: 50Mersion
      read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:43Mersion
      send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:43Mersion
      V_DIMMER received: 43Mersion
      read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:36Mersion
      send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:36Mersion
      V_DIMMER received: 36Mersion
      read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:29Mersion
      send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:29Mersion
      V_DIMMER received: 29Mersion
      read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:21Mersion
      send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:21Mersion
      V_DIMMER received: 21Mersion
      read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:14Mersion
      send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:14Mersion
      V_DIMMER received: 14Mersion
      read: 0-0-254 s=1,c=1,t=3,pt=0,l=9,sg=0:74Mersion
      send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=9,sg=0,st=ok:74Mersion
      V_DIMMER received: 74Mersion
      read: 0-0-254 s=1,c=1,t=2,pt=0,l=9,sg=0:04Mersion
      send: 254-254-0-0 s=1,c=1,t=2,pt=0,l=9,sg=0,st=ok:04Mersion
      V_LIGHT received: 04Mersion
      Is it possible as some crap is sitting in my ESP8266 EEPROM memory?
      • GizMoCuzG
        GizMoCuzG
        GizMoCuz
        wrote on last edited by GizMoCuz
        #29
        @hek, with \n
        MySensors is implemented in domoticz for a long time now... there should be nothing wrong with it.....
        Also in my sketches all is received perfectly
        Could there be a difference between the ESP8266 and nRF ?
        I only use the nRF currently (and probably will for ever as i have 20 more chips and a lot more arduino's g)
        Also i do not send anything with the word version in it, it looks this is a left over from sending the sketch information ?
        I dont know how you guys get that nice colors in the log (brown/white/green), but the green number is OK, that white behind it is not
        • GizMoCuzG
          GizMoCuzG
          GizMoCuz
          @hek, as demonstrated with the new V_CUSTOM, there is send a lot of information from domoticz -> node, and all prints well, so maybe thats a confirm that this part is working OK (at least on the nRF024)
          • GizMoCuzG
            GizMoCuzG
            GizMoCuz
            I also find it strange that at the beginning V_LIGHT correctly displays 0 or 1, and at the end 04 ? (0 = OK)
            • snowS
              snowS
              snow
              I made a Serial Gateway and updated Domoticz to latest beta, and this is the output from the same sensor.
              0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=1,sg=0,st=ok:7
              0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=1,sg=0:7
              2;1;1;1;3;7
              0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:14
              0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:14
              2;1;1;1;3;14
              0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:21
              0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:21
              2;1;1;1;3;21
              0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:29
              0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:29
              2;1;1;1;3;29
              0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:36
              0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:36
              2;1;1;1;3;36
              0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:43
              0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:43
              2;1;1;1;3;43
              0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:50
              0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:50
              2;1;1;1;3;50
              0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:57
              0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:57
              2;1;1;1;3;57
              0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:64
              0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:64
              2;1;1;1;3;64
              0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:71
              0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:71
              2;1;1;1;3;71
              0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:79
              0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:79
              2;1;1;1;3;79
              0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:86
              0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:86
              2;1;1;1;3;86
              0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:93
              0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:93
              2;1;1;1;3;93
              0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=3,sg=0,st=ok:100
              0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=3,sg=0:100
              2;1;1;1;3;100
              All OK
                @snow
                Could you try replacing this in MySensors/core/MyGatewayTransportEthernet.cpp
                bool _readFromClient(uint8_t i) {
                	while (clients[i].connected() && clients[i].available()) {
                		char inChar = clients[i].read();
                		if (inputString[i].idx < MY_GATEWAY_MAX_RECEIVE_LENGTH - 1) {
                			// if newline then command is complete
                			if (inChar == '\n') {
                				// a command was issued by the client
                				// we will now try to send it to the actuator
                				// echo the string to the serial port
                				debug(PSTR("Client %d: %s\n"), i, inputString[i].string);
                				// add string terminator and clear the string:
                				inputString[i].string[inputString[i].idx] = 0;
                				inputString[i].idx = 0;
                				bool ret = protocolParse(_ethernetMsg, inputString[i].string);
                				if (ret) {
                					return ret;
                				// add it to the inputString:
                				inputString[i].string[inputString[i].idx++] = inChar;
                			debug(PSTR("Client %d: Message too long\n"), i);
                			// Finished with this client's message. Next loop() we'll see if there's more to read.
                	return false;
                And let me know how it behaves.
                • GizMoCuzG
                  GizMoCuzG
                  GizMoCuz
                  I think that will solve the issue... @snow, waiting patiently for your reply ;)
                  • snowS
                    snowS
                    snow
                    It's much better now. I can control dimmer from the domoticz. :)
                    0;0;3;0;9;Client 0 connected
                    0;0;3;0;9;Client 0: 0;0;3;0;2;Get Version
                    0;0;3;0;9;read: 2-2-0 s=255,c=0,t=17,pt=0,l=10,sg=0:1.6.0-beta
                    0;0;3;0;9;read: 2-2-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                    0;0;3;0;9;Client 0: 2;255;3;0;6;M Version
                    2;255;3;0;6;M
                    0;0;3;0;9;send: 0-0-2-2 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
                    0;0;3;0;9;read: 2-2-0 s=1,c=0,t=4,pt=0,l=0,sg=0:
                    0;0;3;0;9;read: 2-2-0 s=255,c=3,t=11,pt=0,l=21,sg=0:DimmableLED /w bu
                    0;0;3;0;9;read: 2-2-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.2
                    0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=1,l=1,sg=0:100
                    0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=1,l=1,sg=0,st=ok:100
                    0;0;3;0;9;Client 0: 2;1;1;1;3;93M
                    2;1;1;1;3;93
                    0;0;3;0;9;Client 0: 2;1;1;1;3;86
                    2;1;1;1;3;86
                    0;0;3;0;9;Client 0: 2;1;1;1;3;79
                    2;1;1;1;3;79
                    0;0;3;0;9;Client 0: 2;1;1;1;3;71
                    2;1;1;1;3;71
                    0;0;3;0;9;Client 0: 2;1;1;1;3;64
                    2;1;1;1;3;64
                    0;0;3;0;9;Client 0: 2;1;1;1;3;57
                    2;1;1;1;3;57
                    0;0;3;0;9;Client 0: 2;1;1;1;3;50
                    2;1;1;1;3;50
                    0;0;3;0;9;Client 0: 2;1;1;1;3;43
                    2;1;1;1;3;43
                    0;0;3;0;9;Client 0: 2;1;1;1;3;36
                    2;1;1;1;3;36
                    2;1;1;1;3;36
                    0;0;3;0;9;Client 0: 2;1;1;1;3;29
                    2;1;1;1;3;29
                    0;0;3;0;9;Client 0: 2;1;1;1;3;21
                    2;1;1;1;3;21
                    0;0;3;0;9;Client 0: 2;1;1;1;3;14
                    2;1;1;1;3;14
                    0;0;3;0;9;Client 0: 2;1;1;1;3;74
                    2;1;1;1;3;7
                    0;0;3;0;9;Client 0: 2;1;1;1;2;0
                    2;1;1;1;2;0
                    0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:0
                    0;0;3;0;9;read: 2-2-0 s=1,c=1,t=2,pt=0,l=1,sg=0:0
                    0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=2,l=2,sg=0:0
                    0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:0
                      Great, I'll push this fix ASAP.
                      • HoffanH
                        HoffanH
                        Hoffan
                        @Hoffan said:
                        anyone that knows if include button working now? With vera as controller
                        • HoffanH
                          HoffanH
                          Hoffan
                          I can answer that question by my self.. Its still not working
                            @Hoffan, I verified the inclusion button functionality in the dev branch during the weekend (at least on AtMega but it should work fine on ESP as well).
                            Just make sure to enable the feature and set a valid ESP-pin. All is documented in sketch.
                            • HoffanH
                              HoffanH
                              Hoffan
                              @hek
                              Okey So i must enable it in the sketch even if i only use the start button in the GUI in Vera
                                @Hoffan
                                Not the "button" feature (unless you use it), but the "inclusion mode" feature must be enabled.
                                • HoffanH
                                  HoffanH
                                  Hoffan
                                  I don't know if i understan you right here, @Hek
                                  if i like to use the start button in vera should it look like this
                                  // Enable inclusion mode
                                  define MY_INCLUSION_MODE_FEATURE
                                  define MY_INCLUSION_MODE_DURATION 60
                                  #define MY_INCLUSION_MODE_BUTTON_PIN 3
                                    You only need these two:
                                    • HoffanH
                                      HoffanH
                                      Hoffan
                                      Yes That i understand, But Nothing is still happening in the GUI men i press start
                                        Anything in the gateway log?
                                        • HoffanH
                                          HoffanH
                                          Hoffan
