  3. Node error when power via vcc/gnd, OK when using FTDI connection
6 Posts 4 Posters 2.2k Views 4 Watching
  • S Offline
    sjoerd14
    I have a strange behaviour of the pro-mini (5v)
    When I connect to the VCC and GND on the side rows (next to A3 and D2) then I am not able to cumunicate (to Vera)
    When I connect using the FTDI or a the VCC an GDN of this connecter its working
    I tested it finally using the MYSController see for the first situation I and for second II in the screen print.
    Any one a suggestion what could cause this and/or how to solve this?
    R 1 Reply Last reply
    • S sjoerd14
      R Offline
      R Offline
      rvendrame
      @sjoerd14 How do you power the arduino when not via FTDI? The nRF radio is very sensitive to power noise (for example from cheap phone chargers).
      Do you have a cap between radio VCC/GND?
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      • S Offline
        sjoerd14
        I planned to use a phone checker 1A b7ut now during testing is connect in both cases using the laptop USB. The "NRF24L01+ Socket Adapter Board" from the shop to connect the radio.
        Last latest test was to add an (extra) 4.7 uF, without any diff.
        I am puzzled about the fact appertly the MYSCONTROLER receives the other messages. Why only an issue with the TX messages?
        I am wondering if vcc from the fdti and the other vcc pins are directly connected on the board?
        Thanks for your help.
        mfalkviddM Y 2 Replies Last reply
        • S sjoerd14
          You could measure the resistance between gnd on the side and gnd on the ftdi header. It should be 0 (or at least very close to 0). Then do the same for the two Vcc pins.
          • S sjoerd14
            Y Offline
            Y Offline
            @sjoerd14 According to the official Pro Mini schematics (https://www.arduino.cc/en/uploads/Main/Arduino-Pro-Mini-schematic.pdf) all VCC pins are connected.
            The RAW pin is a different story. This input is fed through a voltage regulator to create 5V on VCC.
            For a clone the schematic might be slightly different (e.g. SJ1 I have never seen on a clone) but function of VCC & RAW pins should be identical.
            • S Offline
              sjoerd14
              wrote on last edited by sjoerd14
              @mfalkvidd, I checked using the multimeter. In diode mode, I have 400 ohm between fdti and vcc. When powered a 0.4v drop.
              So both vcc's are not direct connected.
              Still strange it works OK with the 4.4v on the radio and not with 4.9
              At least we have now an idea what
              It's a deek robot clone.
              https://arduino-board.com/boards/dr-pro-mini
