  3. NRF24L01+PA+LNA power consumption
53 Posts 9 Posters 33.3k Views 9 Watching
  • Mark SwiftM Mark Swift
    @parachutesj
    Strange, how are you driving them, what volt control line, 5v?
    parachutesjP
    parachutesjP
    parachutesj
    @Mark-Swift
    no 3.3V.
    However as said, it is an original Uno. I have clones which deliver no clean or reliable signal. I measured it before but don't remember exactly but was quite off.
    Mark SwiftM 1 Reply Last reply
    • parachutesjP parachutesj
      @Mark-Swift
      no 3.3V.
      Mark SwiftM
      Mark SwiftM
      Mark Swift
      @parachutesj said:
      @Mark-Swift
      no 3.3V.
      The Uno has 5v control lines doesn't it?
      parachutesjP 1 Reply Last reply
        @parachutesj said:
        @Mark-Swift
        no 3.3V.
        parachutesjP
        parachutesjP
        parachutesj
        @Mark-Swift
        the digital ports? AFAIK yes.
        the radio VCC is connected to 3.3 (all to the pins as in the tutorial GND, VCC 3.3, D9-D13)
        The other setup is via external power (ipad USB-Adapter) to a breadboard, VIN directly from 5V to the Arduino and another line via 3.3V regulator to the NRF24 radio. all other lines again directly connected to the arduino.
        • AWIA AWI
          @Mark-Swift The ones you refer are shielded.. as far as I can see.
          0_1464696145069_upload-6475afd2-f07a-496f-be95-a8f71187f6cd
          So next level in debugging... how is you ground connected,. You can try to power the adapter plate from the supply of your UNO. The on board LM1117 should be able to accept upto 20V.
          Mark SwiftM
          Mark SwiftM
          Mark Swift
          @AWI Ground is connected from the baseboard back to the Uno, along with the VCC. That's how I'm currently powering it, 5V from uno into the adaptor plate. All other control lines directly into the Uno.
          • OitzuO
            OitzuO
            Oitzu
            hackaday caught wind on the tinfoil method.
            http://hackaday.com/2016/05/31/fixing-the-terrible-range-of-your-cheap-nrf24l01-palna-module/
            Maybe there also some points hidden in the comments that would help?
            • Mark SwiftM
              Mark SwiftM
              Mark Swift
              I saw this on Hackaday, could we make this change in MySensors?
              "Don’t use polling over SPI to check if there is a received packet like most of the libs out there do. This increases the noise. Use the IRQ pin"
              @hek
                In the development branch we do use irq nowadays, if you define
                #define MY_RF24_IRQ_PIN xx
                It also de-queues messages from the NRF24 quickly, which reduces missed messages.
                Mark SwiftM GertSandersG 2 Replies Last reply
                  Mark SwiftM
                  Mark SwiftM
                  Mark Swift
                  @hek amazing, I never knew that.
                  So all I would do is define this line in my sketch and connect up the IRQ line?
                  I presume I can use this on both my gateway (ESP8266) and my nodes (Nano / Uno)?
                    The ESP still doesn't support this feature due to lack of SPI transaction support (if I remember correctly? @Yveaux ).
                      @hek @Mark-Swift More precisely, it misses the interrupt protection for SPI transfers. Ref https://github.com/esp8266/Arduino/issues/1943.
                      But the queueing is not yet in development, as far as I know -- it is in my personan testing branch https://github.com/Yveaux/Arduino/tree/development_rxqueue
                      • OitzuO
                        OitzuO
                        Oitzu
                        @Mark-Swift there are basicly effects that could occur while you holding the module:
                        1.) You are forming a very small capacitor between you and the module.
                        Much unlikely to be the reason.
                        2.) You are functioning as an antenna for the module.
                        Also much unlikely, you would probably bring more noise then signal in the system.
                        3.) You function as a shield to the module.
                        More likely. I got the same behavior with insufficient shielding.
                        The shielding works ungrounded in low noise environment but needs to be grounded in a high noise environment.
                        This happens, as example, if a insufficient shielded switching power supply is nearby.
                        Please make absolutely sure that your shield is properly grounded!
                        • OitzuO Oitzu
                          Mark SwiftM
                          Mark SwiftM
                          Mark Swift
                          @Oitzu The shielded modules appear to have the shield well grounded?
                          • OitzuO
                            OitzuO
                            Oitzu
                            @Mark-Swift does "appear" mean you actually measured it all the way to ground or that you believe that it should be well grounded?
                              GertSandersG
                              GertSandersG
                              GertSanders
                              @hek
                              So it would make sense to connect the IRQ pin of the radio to the processor ? Any pin ? Or is it meant for INT0/INT1 pins only ?
                              karl261K 1 Reply Last reply
                              • GertSandersG GertSanders
                                @hek
                                karl261K
                                karl261K
                                karl261
                                @GertSanders Did you find an answer to this? With 2.0.0 would it be better to use IRQ now? Just connecting the pin and adding the IRQ line?
                                • karl261K karl261
                                  @karl261 It isn't used by default in 2.0.0, but can be used in the 2.0.1 development brach. I would advise you to connect the nRF irq pin to into (pin 2), to be prepared for later usage.
                                  • YveauxY Yveaux
                                    karl261K
                                    karl261K
                                    karl261
                                    @Yveaux So, basically this means that in the future we can have the arduino sleeping and when a message comes in it wakes up from the interrupt? Sounds like repeaters could run on battery then. If there is not too much traffic.
                                      No, running repeaters on battery is probably not possible. Keeping radio in listening-mode takes too much juice.
                                        karl261K
                                        karl261K
                                        karl261
                                        @hek Ah yes, that's right. The radio needs to be on. I forgot about that. We need an over the air interrupt... ;-)
                                        12.5k
