  3. Message during setup() doesn't work in version 2.0.x
5 Posts 3 Posters 1.1k Views 2 Watching
  • spacejayS Offline
    spacejayS Offline
    spacejay
    Hello all,
    I tried to convert the sketch from my relay node to the new version 2.0.x. In the setup() routine I set the state of the relay to off and sent the state to the controller. In version 1.5.4 worked this without problems. Now with version 2.0.0, it doesn't work anymore. It seems, that the node starts working just after setup() routine. Is there another possibility to run this command once after note setup/startup?
    Regards
    spacejay
    Y T 2 Replies Last reply
    • spacejayS spacejay
      Hello all,
      Regards
      spacejay
      Y Offline
      Y Offline
      @spacejay Start your loop() code like this:
          static bool first = true;
          if (first)
              // .. Your code that should only be executed on first run ..
              first = false;
          // .. your normal loop-contents ..
      spacejayS 1 Reply Last reply
        Hello all,
        Regards
        spacejay
        T Offline
        T Offline
        tekka
        wrote on last edited by tekka
        @spacejay @Yveaux Addressed in #513.
        • Y Yveaux
              if (first)
                  first = false;
          spacejayS Offline
          spacejayS Offline
          spacejay
          @Yveaux Yes, I already solved this in this way temporarily.
          @tekka Thanks for solving that bug!
          Y 1 Reply Last reply
            Y Offline
            Y Offline
            @spacejay it's always hard to judge a user's experience level. Anyway, great you created a workaround and can continue!
