  3. 💬 MDMSGate
💬 MDMSGate
atsha204amysensors gatewayesp8266ethernetmysensorsgatewaynrf24l01usbatmega328rfm69
82 Posts 22 Posters 42.5k Views 25 Watching
    Looks really good. Especially like the picture with the dual radio antennas mounted. :)
    • kalinaK
      kalinaK
      kalina
      • kalinaK
        kalinaK
        kalina
        BOM is added.
        • kalinaK
          kalinaK
          kalina
          Today I received a printed circuit board from PCBWay.com and I will begin soldering the device tommorow. 0_1469479295106_IMG_20160725_221329.jpg
          • kalinaK
            kalinaK
            kalina
            2_1469688422763_MDMSGate_Foto_1.jpg 1_1469688422763_MDMSGate_Foto_2.jpg 0_1469688422763_MDMSGate_Foto_3.jpg
            • KoreshK
              KoreshK
              Koresh
              Looks very good. I like the blue mask! Did you solder this board using ordinary iron/fan or smd oven?
              • kalinaK
                kalinaK
                kalina
                Hi Koresh! First of all sorry for my English))) When i am soldering i use the soldering paste, plastic stencil and hot air gun. I have made some pictures which explain the process of soldering.
                2_1469727496777_Picture3.jpg 1_1469727496776_Picture2.jpg 0_1469727496776_Picture1.jpg
                • rubenverhoefR
                  rubenverhoefR
                  rubenverhoef
                  I like your gateway! Can you maybe post it on OSHPark? so i can order the PCB?
                  kalinaK 1 Reply Last reply
                  • rubenverhoefR rubenverhoef
                    kalinaK
                    kalinaK
                    kalina
                    @rubenverhoef Thank you for your good feedback about my device. I have added gerber files to the section "Design files" and you can make the order of pcb youself. But if you want, i can sell to you assembled device (with case, as on the photo). Now i am testing my project and i have checked Atmega328p, Wi-Fi module, CP2102 and Ethernet. After that, i am planning to adapt DualOptiBoot for my device. NRF24 and RFM69 I will check in two weeks...
                    TheoLT 1 Reply Last reply
                    • kalinaK kalina
                      TheoLT
                      TheoLT
                      TheoL
                      @kalina Interesting project. Just out of curiosity. What would a complete mounted device cost?
                      • TheoLT TheoL
                        kalinaK
                        kalinaK
                        kalina
                        @TheoL The price of complete mounted device no more than 35$. But if no need to install all the components, the cost will be lower.
                        • G
                          G
                          gloob
                          I will add my interest for an assembled device. It looks really good.
                          • G gloob
                            kalinaK
                            kalinaK
                            kalina
                            @gloob OK. I will report about all development stages. I think that by the end of September I will produce the first lot in 10-20 pcs.
                            • G
                              G
                              gonzalonal
                              Hi Kalina.
                              Nice design. Congratulations.
                              Two questions for you:
                              1-Have you considered adding RS485 support so as to comply with all the supported GW for MySensors? It would make your desing really complete and extremely flexible and adaptative.
                              2- Are you willing to share your design files so we can make custom modifications to it?
                              • G gonzalonal
                                Hi Kalina.
                                kalinaK
                                kalinaK
                                kalina
                                @gonzalonal Hi Gonzalonal! Thank you for your interest in my project. I'm answering your questions.
                                1. I'm new in the project "Mysensors" and I applied in my device Atmega328 microcontroller (exactly the same as in the Arduino uno and nano). The use of this microcontroller will give an opportunity to create quickly software for all users. One of the drawbacks of this microcontroller is just one UART, but for adding RS-485 need one more. I do not use a software UART.
                                2. I see no reason to make the modifications until the original version hasn't checked. For this question we can come back after the software will be developed and the device will be tested.
                                As I wrote earlier, in September I will produce about 10 devices and if you wish, you may join for the device testing.
                                sinczeS 1 Reply Last reply
                                • kalinaK kalina
                                  sinczeS
                                  sinczeS
                                  sincze
                                  MySensors Evangelist
                                  @kalina interesting device indeed put me on the list of people being interested in your design board :)
                                  • KoreshK
                                    KoreshK
                                    Koresh
                                    wrote on last edited by Koresh
                                    Can you a little clarify how this device will work in mysensors environment? If I understand right this board has two uplink transport modules (rfm & nrf) and three gateway modules (standard serial, ethernet and wi-fi via ESP8266). So are you planning solder all of those modules on the board? I am not sure, but as I know we can use only one uplink transport (nrf ir rfm or rs485) and one gateway (serial/ethernet/wi-fi). So we can use only one of six possible configurations. May be it is not cost effective to solder all components at once?
                                    PS
                                    Only one small suggestion from me. Your board contains only one chip with QFN package. It can raise PCBA price so it may be reasonable to use usb-ttl converter not in QFN\BGA package. But of course it's for you to decide :)
                                    • KoreshK Koresh
                                      PS
                                      kalinaK
                                      kalinaK
                                      kalina
                                      @Koresh Thanks for a good question. Yes, you are right, and I want to explain the main idea.
                                      1. My pcb is universal. At this moment, I don't know who of the first users will choose one of available operating modes (serial or Wi-Fi or Ethernet, NRF24 or RFM69) and therefore I will solder the first 10 devices completely. Of course, in the future I will divide assemblies into RFM or NRF24, and also Ethernet or Wi-Fi or Serial. It is six possible configurations about which you spoke.
                                      2. I want to accent on main idea of my device. The sketch for the Atmega328P microcontroller in all three modes will be as a serial gateway. Conversion of TCP packets to serial data will be execute in the PIC18F67J60 (Ethernet) microcontroller or in the ESP-12 (Wi-Fi). The necessary mode can be selected by jumpers of XP2 connector (see added picture).
                                      3. About the choice of QFN package – I will think.0_1471013179762_Structure.jpg
                                      • kalinaK
                                        kalinaK
                                        kalina
                                        Hi everyone!
                                        Today i have completed the development of new design of the enclosure. The sticker is printed on Oracal film.0_1474132068564_New_enclosure.jpg
                                        sinczeS mfalkviddM 2 Replies Last reply
                                        • kalinaK kalina
                                          Hi everyone!
                                          sinczeS
                                          sinczeS
                                          sincze
                                          @kalina very nice very nice :)
