  3. 💬 MDMSGate
💬 MDMSGate
atsha204amysensors gatewayesp8266ethernetmysensorsgatewaynrf24l01usbatmega328rfm69
82 Posts 22 Posters 42.5k Views 25 Watching
  • rubenverhoefR
    rubenverhoefR
    rubenverhoef
    I like your gateway! Can you maybe post it on OSHPark? so i can order the PCB?
    kalinaK 1 Reply Last reply
    • rubenverhoefR rubenverhoef
      kalinaK
      kalinaK
      kalina
      @rubenverhoef Thank you for your good feedback about my device. I have added gerber files to the section "Design files" and you can make the order of pcb youself. But if you want, i can sell to you assembled device (with case, as on the photo). Now i am testing my project and i have checked Atmega328p, Wi-Fi module, CP2102 and Ethernet. After that, i am planning to adapt DualOptiBoot for my device. NRF24 and RFM69 I will check in two weeks...
      TheoLT 1 Reply Last reply
      • kalinaK kalina
        TheoLT
        TheoLT
        TheoL
        @kalina Interesting project. Just out of curiosity. What would a complete mounted device cost?
        • TheoLT TheoL
          kalinaK
          kalinaK
          kalina
          @TheoL The price of complete mounted device no more than 35$. But if no need to install all the components, the cost will be lower.
          • G
            G
            gloob
            I will add my interest for an assembled device. It looks really good.
            • G gloob
              kalinaK
              kalinaK
              kalina
              @gloob OK. I will report about all development stages. I think that by the end of September I will produce the first lot in 10-20 pcs.
              • G
                G
                gonzalonal
                Hi Kalina.
                Nice design. Congratulations.
                Two questions for you:
                1-Have you considered adding RS485 support so as to comply with all the supported GW for MySensors? It would make your desing really complete and extremely flexible and adaptative.
                2- Are you willing to share your design files so we can make custom modifications to it?
                • G gonzalonal
                  Hi Kalina.
                  kalinaK
                  kalinaK
                  kalina
                  @gonzalonal Hi Gonzalonal! Thank you for your interest in my project. I'm answering your questions.
                  1. I'm new in the project "Mysensors" and I applied in my device Atmega328 microcontroller (exactly the same as in the Arduino uno and nano). The use of this microcontroller will give an opportunity to create quickly software for all users. One of the drawbacks of this microcontroller is just one UART, but for adding RS-485 need one more. I do not use a software UART.
                  2. I see no reason to make the modifications until the original version hasn't checked. For this question we can come back after the software will be developed and the device will be tested.
                  As I wrote earlier, in September I will produce about 10 devices and if you wish, you may join for the device testing.
                  sinczeS 1 Reply Last reply
                  • kalinaK kalina
                    sinczeS
                    sinczeS
                    sincze
                    MySensors Evangelist
                    @kalina interesting device indeed put me on the list of people being interested in your design board :)
                    • KoreshK
                      KoreshK
                      Koresh
                      wrote on last edited by Koresh
                      Can you a little clarify how this device will work in mysensors environment? If I understand right this board has two uplink transport modules (rfm & nrf) and three gateway modules (standard serial, ethernet and wi-fi via ESP8266). So are you planning solder all of those modules on the board? I am not sure, but as I know we can use only one uplink transport (nrf ir rfm or rs485) and one gateway (serial/ethernet/wi-fi). So we can use only one of six possible configurations. May be it is not cost effective to solder all components at once?
                      PS
                      Only one small suggestion from me. Your board contains only one chip with QFN package. It can raise PCBA price so it may be reasonable to use usb-ttl converter not in QFN\BGA package. But of course it's for you to decide :)
                      • KoreshK Koresh
                        PS
                        kalinaK
                        kalinaK
                        kalina
                        @Koresh Thanks for a good question. Yes, you are right, and I want to explain the main idea.
                        1. My pcb is universal. At this moment, I don't know who of the first users will choose one of available operating modes (serial or Wi-Fi or Ethernet, NRF24 or RFM69) and therefore I will solder the first 10 devices completely. Of course, in the future I will divide assemblies into RFM or NRF24, and also Ethernet or Wi-Fi or Serial. It is six possible configurations about which you spoke.
                        2. I want to accent on main idea of my device. The sketch for the Atmega328P microcontroller in all three modes will be as a serial gateway. Conversion of TCP packets to serial data will be execute in the PIC18F67J60 (Ethernet) microcontroller or in the ESP-12 (Wi-Fi). The necessary mode can be selected by jumpers of XP2 connector (see added picture).
                        3. About the choice of QFN package – I will think.0_1471013179762_Structure.jpg
                        • kalinaK
                          kalinaK
                          kalina
                          Hi everyone!
                          Today i have completed the development of new design of the enclosure. The sticker is printed on Oracal film.0_1474132068564_New_enclosure.jpg
                          sinczeS mfalkviddM 2 Replies Last reply
                          • kalinaK kalina
                            Hi everyone!
                            sinczeS
                            sinczeS
                            sincze
                            @kalina very nice very nice :)
                            • sinczeS sincze
                              kalinaK
                              kalinaK
                              kalina
                              @sincze Thank you, I try to make it nice and reliable!
                              • kalinaK
                                kalinaK
                                kalina
                                #23
                                I have good news - i have made 15 pcs MDMSGate, and as soon as i will add it to ebay you can buy it. Price for each (assembled board+enclosure+2.4GHz antena+microUBS cable) - 35$. Also, i have already updated my project files, you should look at their if you are going to buy this device.0_1476646824442_MDMSGate_1.jpg
                                  @kalina
                                  Will you also please add the design files to your project.
                                    @kalina
                                    kalinaK
                                    kalinaK
                                    kalina
                                    @hek This is my first complete device and I would like to know what else I have to add? Gerber files and scheme I have already added.
                                      I'm referring to the KIcad or Eagle source files so people can learn and fork from your fine project.
                                      • rubenverhoefR
                                        rubenverhoefR
                                        rubenverhoef
                                        I like the product and want to buy two of them. Is shipping to the Netherlands possible?
                                          kalinaK
                                          kalinaK
                                          kalina
                                          Hi @rubenverhoef. In my opinion, it shouldn't be problems with the delivery. There are some questions:
                                          1. How quickly will MDMSGates come to you?
                                          2. How much will shipping be cost (i mean DHL or other post service) ?
                                          3. What hardware (Wi-Fi, Ethernet, etc.) and software (bootloader, sketch, etc.) configuration do you need?
                                          We can discuss the details in the chat or on Skype, as you wish...
                                          rubenverhoefR 1 Reply Last reply
