  3. Domoticz
  4. Domotiocz + Rain gauge
61 Posts 12 Posters 45.6k Views 12 Watching
  • TheoLT TheoL
    @flopp Thank you. What do you mean by sending data correctly? Do you have an example sketch?
    F
    F
    flopp
    wrote on last edited by flopp
    #28
    Not correctly, I wrote depending.
    If you send data every 2 hours and ot every time the buck has tiped the rate will not be correct. Lets say you send/report every 2 hour, you report 10 mm, that means you have "collect" 10 mm for 2 hours. Maybe the hour was not raining, then the rate will show you 10mm/h, sorry if I confusing you.
    What I mean is that you should send/report directly when the buck has tiped then the rate in DZ will be correct rate/h.
    my sketch
    // Running this in Domoticz stable version 2.5 will not work - upgrade to beta.
    #define DIGITAL_INPUT_SENSOR 3 // The reed switch you attached. (Only 2 and 3 generates interrupt!)
    #define CHILD_ID 1 // Id of the sensor child
    #define BATT_CHILD 2
    #define NODE_ID AUTO // or AUTO to let controller assign
    #define SKETCH_NAME "Rain Gauge" // Change to a fancy name you like
    #define SKETCH_VERSION "1.8" // Your version
    unsigned long SLEEP_TIME = 180*60000; // Sleep time (in milliseconds).
    //unsigned long SLEEP_TIME = 20000; // use this instead for debug
    float hwRainVolume = 0; // Current rainvolume calculated in hardware.
    int hwPulseCounter = 0; // Pulsecount recieved from GW
    float fullCounter = 0; // Counts when to send counter
    float bucketSize = 0.5; // Bucketsize mm, needs to be 1, 0.5, 0.25, 0.2 or 0.1
    boolean pcReceived = false; // If we have recieved the pulscount from GW or not
    boolean reedState; // Current state the reedswitch is in
    boolean oldReedState; // Old state (last state) of the reedswitch
    unsigned long lastSend =0; // Time we last tried to fetch counter.
    MyMessage volumeMsg(CHILD_ID,V_RAIN);
    MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
    MyMessage battMsg(BATT_CHILD, V_VOLTAGE);
    #define VMIN 1.9 // Vmin (radio Min Volt)=1.9V (564v)
    #define VMAX 3.0 // Vmax = (2xAA bat)=3.0V (892v)
    int batteryPcnt = 0; // Calc value for battery %
    int batLoop = 0; // Loop to help calc average
    int batArray[3]; // Array to store value for average calc.
    int BATTERY_SENSE_PIN = A0; // select the input pin for the battery sense point
    long result;
    float batteryPcnt;
    float batteryVolt;
    pinMode(6,OUTPUT);
    digitalWrite(6,HIGH);
    //analogReference(INTERNAL); // For battery sensing
    pinMode(DIGITAL_INPUT_SENSOR, INPUT_PULLUP); // sets the reed sensor digital pin as input
    reedState = digitalRead(DIGITAL_INPUT_SENSOR); // Read what state the reedswitch is in
    oldReedState = reedState; // Set startup position for reedswitch
    //Begin (Change if you dont want static node_id! (NODE_ID to AUTO)
    gw.begin(incomingMessage, NODE_ID, false);
    // Register this device as Rain sensor (will not show in Domoticz until first value arrives)
    gw.present(CHILD_ID, S_RAIN);
    gw.present(BATT_CHILD, S_MULTIMETER);
    Serial.println("Startup completed");
    delay(100);
    //gw.begin(incomingMessage, NODE_ID, false);
    unsigned long currentTime = millis();
    //See if we have the counter/pulse from Domoticz - and ask for it if we dont.
    if (!pcReceived && (currentTime - lastSend > 5000)) {
    gw.request(CHILD_ID, V_VAR1);
    Serial.println("Request pulsecount");
    lastSend=currentTime;
    return;
    if (!pcReceived) {
    return;
    //Read if the bucket tipped over
    boolean tipped = oldReedState != reedState;
    //BUCKET TIPS!
    if (tipped==true) {
    Serial.println("The bucket has tipped over...");
    hwRainVolume = hwRainVolume + bucketSize;
    gw.send(volumeMsg.set((float)hwRainVolume,1));
    gw.wait(1000);
    fullCounter = fullCounter + bucketSize;
    //Count so we send the counter for every 1mm
    if(fullCounter >= 1){
    hwPulseCounter++;
    gw.send(lastCounterMsg.set(hwPulseCounter));
    gw.wait(1000);
    fullCounter = 0;
    readVcc();
    if (tipped==false) {
    //No bucket tipped over last sleep-period, check battery then...
    readVcc();
    Serial.println("sleep");
    digitalWrite(6,LOW);
    delay(1000);
    gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME);
    //The interupt can be CHANGE or FALLING depending on how you wired the hardware.
    //Read if we have a incoming message.
    if (message.type==V_VAR1) {
    hwPulseCounter = message.getULong();
    hwRainVolume = hwPulseCounter;
    pcReceived = true;
    Serial.print("Received last pulse count from gw: ");
    Serial.println(hwPulseCounter);
    delay(500);
    // Battery monitoring reading
    delay(500);
    // Calculate the battery in %
    float Vbat = sensorValue * VBAT_PER_BITS;
    if (batLoop > 1) {
    batteryPcnt = (batArray[0] + batArray[1] + batArray[2]);
    if (batteryPcnt > 100) {
    batteryPcnt=100;
    batLoop = 0;
    //Sends 1 per hour as a heartbeat.
    batLoop++;
    long readVcc() {
    Serial.println("readVcc");
    ADCSRA |= _BV(ADSC); // Convert
    result = ADCL;
    result |= ADCH<<8;
    result = 1126400L / result; // Back-calculate AVcc in mV
    //return result;
    batteryPcnt = (result - 3300) * 0.111111;
    batteryVolt = result/1000.000;
    gw.send(battMsg.set(batteryVolt, 3));
    /*Serial.print("battery volt:");
    Serial.println(batteryVolt, 3);
    Serial.print("battery percent:");
    Serial.println(batteryPcnt);
    TheoLT 1 Reply Last reply
    • F flopp
      my sketch
      long result;
      float batteryPcnt;
      float batteryVolt;
      pinMode(6,OUTPUT);
      delay(100);
      return;
      if (!pcReceived) {
      return;
      //BUCKET TIPS!
      if (tipped==true) {
      gw.wait(1000);
      hwPulseCounter++;
      gw.wait(1000);
      fullCounter = 0;
      readVcc();
      readVcc();
      delay(1000);
      pcReceived = true;
      delay(500);
      delay(500);
      if (batLoop > 1) {
      batteryPcnt=100;
      batLoop = 0;
      batLoop++;
      long readVcc() {
      result = ADCL;
      result |= ADCH<<8;
      //return result;
      TheoLT
      TheoLT
      TheoL
      @flopp Thank you for the explanation. I think I've got it.
      I've added a RAINRATE msg like this
      MyMessage rainRateMsg( CHILD_ID_RAIN_LOG, V_RAINRATE );
      But I don't think domoticz uses it.
      F 1 Reply Last reply
      • TheoLT
        TheoLT
        TheoL
        @sundberg84 Using a real pulse counter instead of a 1mm pulse counter seems to work perfectly. Luckily it makes the sketch a bunch easier to implement and read. And there will also be no loss of 0.2 or 0.5 mm rain fall whenever you reset the node while it didn't have a .0 value.
        • TheoLT TheoL
          F
          F
          flopp
          @TheoL RAINRATE is implemented according to this page https://github.com/domoticz/domoticz/blob/master/hardware/MySensorsBase.cpp but I don't know how to use it. I know that DZ doesn't work with this example https://www.mysensors.org/build/rain
          • F
            F
            flopp
            #32
            I have adjust my bucked to tip every ~0.25mm and calibrated it ofcourse
            AWIA 1 Reply Last reply
            • F flopp
              AWIA
              AWIA
              AWI
              Domoticz just recently changed the method of rain rate calculation. It does not interpret rainrate values sent by sensors but calculates this by the total value coming in.
              • AWIA AWI
                TheoLT
                TheoLT
                TheoL
                @AWI Thank you again. I already had a gut feeling this would be the case. I'll strip out the rain rate code from the sketch.
                • TheoLT TheoL
                  BulldogLowellB
                  BulldogLowellB
                  BulldogLowell
                  @TheoL
                  Great to see this project continuing to grow legs!
                  • HilltanH
                    HilltanH
                    Hilltan
                    • sundberg84S sundberg84
                      This is great!
                      1 year - times fly by, but my rainsensor is going strong!
                      I just wanted to celebrate 1 year for my Rainsensor on batteries, reporting every hour (or less when it rains). Still going strong and 81% battery left! Except for some range issues in the beginning you can see its working as it should:
                      Also It will be my (almost) 1000th post so thank you all for making MySensors such a great community. I just love every minute here!
                      F
                      F
                      flopp
                      WOW, nice. Would it be possible to see your Battery graph, if you have one?
                      I am send data every 2h or often when it rains but my battery is draining much quicker than yours. Maybe I will get 1 year out of it, so I am happy anyway.
                      But I am interested in your graph if the voltage is going down quicker in the beginning.
                      • HilltanH
                        HilltanH
                        Hilltan
                        Maybe a stupid question, but it is possible to replace the SI7021 sensor with a DHT-22 sensor (the code has to be changed offsourse)? And get everything to work with ThresholdUtil? I have all parts, but not the SI7021 sensor to build the rain gauge.
                        TheoLT AWIA 2 Replies Last reply
                        • HilltanH Hilltan
                          TheoLT
                          TheoLT
                          TheoL
                          @Hilltan That should really be easy. I've created the threshold util especially for this. You only have to replace the si7021 init part with the DHT22 init part and replace the reading part of the si7021 in the threshold util callback with reading the DHT22 part. Then you're done.
                          Just give it a try yourself. It's really not that hard.
                          There's however a reason why I use the si7021 instead of the DHT's. I've had serious troubles with the DHT sensors. Some of them wouldn't report the values to the gateway for a week. After the that the node spontaneously started reporting again. I have a sense bender running for more than a half year flawlessly. So in my opinion the si7021 is superior to the DHT.
                          HilltanH 1 Reply Last reply
                          • HilltanH Hilltan
                            AWIA
                            AWIA
                            AWI
                            @Hilltan Like @TheoL mentioned, try to avoid the DHT22, especially for battery powered operation. The DHT-22 is (apart from other disadvantages) specified for a working voltage from 3.3-6V. And tend to get unstable at low voltages.
                              Hmm.. @AWI, @TheoL maybe we should replace DHT example on the main site for something more modern?
                                TheoLT
                                TheoLT
                                TheoL
                                @hek That sounds like a good idea. Should we also indicate that the SI7021 is a sensor for more experienced users? Because you need to solder wires or headers to it.
                                  Yes, But they exist in breakout board variants. So it shouldn't be much more effort than connecting a DHT module.
                                    AWIA
                                    AWIA
                                    AWI
                                    wrote on last edited by AWI
                                    #44
                                    @hek @TheoL let's join forces. Dht21 or si7021 share the same code and both available on a board with level converter. And a sketch wit Bme280 (with pressure)
                                    Making a drawing (kicad) is not my thing. The rest ok
                                      Yep, note that the BMP180/BMP085 is described in the https://www.mysensors.org/build/pressure example. BME280 might be a better choice nowadays perhaps.
                                      • AWIA AWI
                                        TheoLT
                                        TheoLT
                                        TheoL
                                        @AWI Would love to join forces with you my friend. I can make a Fritzing ;-)
                                        • TheoLT TheoL
                                          AWIA
                                          AWIA
                                          AWI
                                          @TheoL deal:thumbsup:
