716 Posts 111 Posters 703.2k Views 93 Watching
  • AWIA AWI
    @Matt Take a look at link text
    Matt
    @AWI hey thanks! I especially like this
    Although.... Something tells me L should be in series on Vout, sureley if it was between BAT and 3.3 voltage weird things would happen....
    Might be time to finally try to figure out how to use that cheap old scope in my garage...
    Also, as it happens, am just getting in to RC stuff (well for my son, but you know...)
    • sundberg84S
      sundberg84S
      #246
      I have now updated this to Revision 9!
      • Bigger mounting holes 2.5mm
      • IRQ Jumper from Radio. This makes this trace disabled and D2 can be used for interupts unless jumper is connected.
      • BAT and REG jumpers changed positions for better tracing.
      • MysX 2,6
      • Text on voltage regulater (Vout/Vin/Gnd)
      • Bug with G on CAP now on the right side.
      • GND and VCC swapped - so you could use a 2 pin block for GND/RAW as well.
      • Capacitor to filter the booster output more (optional)
      Please wait for PCB house to update to new gerber files before ordering (It should say M.Rev 5 (Manufacturer rev 5) for lastest revision when selecting PCB house)
      I have not yet tested this rev... but no major changes so it should be pretty safe.
      If you want to be 100% sure, download and order Rev 8.
      scurbS M 2 Replies Last reply
      • sundberg84S sundberg84
        • MysX 2,6
        scurbS
        scurbS
        scurb
        @sundberg84
        Been a while since I made sensors now - but so what.. ordered 10 pcs in order to try it out :)
          • MysX 2,6
          Matt
            Wait, what?
            Missed this. I am using v8 boards. Cant seem to figure out how to search individual threads and 247 posts is a bit much to go through tonight. Will get the DMM out and try to figure it out, but what cap is labelled wrong?
          Matt
          • M Matt
              Wait, what?
            Matt
            sundberg84S
            sundberg84S
            @Matt - check the images: https://forum.mysensors.org/topic/2740/easy-newbie-pcb-for-mysensors/197
              Matt
              @sundberg84 cheers, no problem on my boards, multimeter confirms this...
                Matt
                wrote on last edited by Matt
                #251
                Hey I recently got a batch of ten pro 3.3v pro minis from ebay, I removed vreg + LED on two of them and they no longer work... Well, I cant upload. I have done this low power mod heaps of times, the boards are different from ones Ive seen before, has anyone here had this problem? Or am I just a problem magnet? Have yet to solder programming headers on a non modified board to see if its a bad batch... Maybe main power is routed through the vreg or LED regardless or something? I dont have the eyesight or mag abilities to play around...
                0_1482260686279_upload-22833514-2461-4622-9259-2d9e9fa6ed9b
                sundberg84S ferroF 2 Replies Last reply
                • M Matt
                  sundberg84S
                  sundberg84S
                  @Matt - I have killed some when i tried to remove them led/reg with a knife (ie cutting). So i began desoldering them which workes nice. I have killed one because of a short circuit and one because i damaged the pad.
                  Could be as you say another routing if its a new clone. Removing the led/resisotor led to being with should not affect this as it most likely only goes to ground.
                    Matt
                    #253
                    @sundberg84
                    Thanks for your reply. Given I've done six or seven to date without issue I am somewhat skeptical that I have borked two in a row. I use a fine tip hakko iron, solder sucker, wick + a tiny wee flathead screwdriver for the butchery.
                    Maybe its time I invested in a magnifying glass heh.
                    Is it necessary to remove the vreg as I would think its not doing anything anyway as we are powering via VCC rather than raw?
                    • M Matt
                      @sundberg84
                      sundberg84S
                      sundberg84S
                      @Matt - Sounds strange. Magnifying glass is cheap and good :+1:
                        Matt
                        @sundberg84
                        Yeah it is a bit. As I said, may yet be a bad batch, too busy with other things right now to test a third one.
                        Mind you, just found this and as I suspected, there appears to be no point in removing the regulator if we are powering directly via vcc.
                        • M Matt
                          ferroF
                          ferroF
                          ferro
                          Did you try to use side pins for Vcc/Gnd connections from usb-ttl adapter? It is known for some clones that Vcc/Gnd pins on programming header do not work after regulator and led are removed and side pins must be used for uploading sketch...
                          • ferroF ferro
                            Matt
                            @ferro ooh hey, didn't know that... Will have a go. Thanks!
                            • M Matt
                              Matt
                              Nup, didn't work. Must have killed them somehow by removing the regulator. Have a third one running just fine, minus the LED.... Oh well.
                                Matt
                                Had further problems with intermittent sends. Sometimes on initial presentation it only sends the sketch name and not version number. Also sends are infrequent up to six hours apart. When it does send it often only sends one child_id when there are three to send.
                                Previously I thought this was most likely an issue with a noisy boost converter. However I just tried replacing the 4.7uf cap on the radio with a 47uf one. Problem solved!
                                Matt
                                • M Matt
                                  Matt
                                  sundberg84S
                                  sundberg84S
                                  @Matt - Nice to hear problem solved! Its again the sensitive radio and the booster might be the cause since changing the cap worked.
                                  One trick is also to add a delay(10) between the presentations if possible. Sometimes the radio cant keep up or something...
                                  • EfflonE
                                    EfflonE
                                    Efflon
                                    Gah! I ordered through the https://www.openhardware.io/order/4/PCB10X link from Itead but got the rev8 boards. Thought the "I always update the gerber files for sale" meant it was safe to order...
                                    • EfflonE Efflon
                                      #262
                                      @Efflon did the order say version m5 when you ordered? Which date did you place the order?
                                      EfflonE 1 Reply Last reply
                                        EfflonE
                                        EfflonE
                                        Efflon
                                        @mfalkvidd I ordered January 2 and can't remember what version was stated. I'm quite sure I picked Itead because it had a higher version numer (and a slightly higher price), honestly don't remember. All I know is that I didn't read this thread but rather just browsed through the page and clicked order. Afterwards I realized it wasn't clear if it was the 5V or 3.3V version but the order said 5x5cm. I also missed to choose color but "grönt är skönt".
                                        Guess what confused me most was the statement "It may say another rev. at the orderpage but this is not EasyPCB rev but the rev for manufacturer." causing me to be trigger happy :smile:
                                        • EfflonE Efflon
                                          sundberg84S
                                          sundberg84S
                                          @Efflon - sorry to hear you got rev 8 if you wanted rev 9.
                                          I wrote this notice just because itead was so slow updating to the right revision! I also spoke to hek about this a month ago according to my chat log.
