716 Posts 111 Posters 703.2k Views 93 Watching
  • M Matt
    Hey I recently got a batch of ten pro 3.3v pro minis from ebay, I removed vreg + LED on two of them and they no longer work... Well, I cant upload. I have done this low power mod heaps of times, the boards are different from ones Ive seen before, has anyone here had this problem? Or am I just a problem magnet? Have yet to solder programming headers on a non modified board to see if its a bad batch... Maybe main power is routed through the vreg or LED regardless or something? I dont have the eyesight or mag abilities to play around...
    0_1482260686279_upload-22833514-2461-4622-9259-2d9e9fa6ed9b
    sundberg84S
    sundberg84S
    @Matt - I have killed some when i tried to remove them led/reg with a knife (ie cutting). So i began desoldering them which workes nice. I have killed one because of a short circuit and one because i damaged the pad.
    Could be as you say another routing if its a new clone. Removing the led/resisotor led to being with should not affect this as it most likely only goes to ground.
    • sundberg84S sundberg84
      Matt
      wrote on last edited by Matt
      #253
      @sundberg84
      Thanks for your reply. Given I've done six or seven to date without issue I am somewhat skeptical that I have borked two in a row. I use a fine tip hakko iron, solder sucker, wick + a tiny wee flathead screwdriver for the butchery.
      Maybe its time I invested in a magnifying glass heh.
      Is it necessary to remove the vreg as I would think its not doing anything anyway as we are powering via VCC rather than raw?
      • M Matt
        @sundberg84
        sundberg84S
        sundberg84S
        @Matt - Sounds strange. Magnifying glass is cheap and good :+1:
          Matt
          @sundberg84
          Yeah it is a bit. As I said, may yet be a bad batch, too busy with other things right now to test a third one.
          Mind you, just found this and as I suspected, there appears to be no point in removing the regulator if we are powering directly via vcc.
          • M Matt
            ferroF
            ferroF
            ferro
            Did you try to use side pins for Vcc/Gnd connections from usb-ttl adapter? It is known for some clones that Vcc/Gnd pins on programming header do not work after regulator and led are removed and side pins must be used for uploading sketch...
            • ferroF ferro
              Matt
              @ferro ooh hey, didn't know that... Will have a go. Thanks!
              • M Matt
                Matt
                Nup, didn't work. Must have killed them somehow by removing the regulator. Have a third one running just fine, minus the LED.... Oh well.
                  Matt
                  Had further problems with intermittent sends. Sometimes on initial presentation it only sends the sketch name and not version number. Also sends are infrequent up to six hours apart. When it does send it often only sends one child_id when there are three to send.
                  Previously I thought this was most likely an issue with a noisy boost converter. However I just tried replacing the 4.7uf cap on the radio with a 47uf one. Problem solved!
                  Matt
                  • M Matt
                    Matt
                    sundberg84S
                    sundberg84S
                    @Matt - Nice to hear problem solved! Its again the sensitive radio and the booster might be the cause since changing the cap worked.
                    One trick is also to add a delay(10) between the presentations if possible. Sometimes the radio cant keep up or something...
                    • EfflonE
                      EfflonE
                      Efflon
                      Gah! I ordered through the https://www.openhardware.io/order/4/PCB10X link from Itead but got the rev8 boards. Thought the "I always update the gerber files for sale" meant it was safe to order...
                      • EfflonE Efflon
                        #262
                        @Efflon did the order say version m5 when you ordered? Which date did you place the order?
                        EfflonE 1 Reply Last reply
                          EfflonE
                          EfflonE
                          Efflon
                          @mfalkvidd I ordered January 2 and can't remember what version was stated. I'm quite sure I picked Itead because it had a higher version numer (and a slightly higher price), honestly don't remember. All I know is that I didn't read this thread but rather just browsed through the page and clicked order. Afterwards I realized it wasn't clear if it was the 5V or 3.3V version but the order said 5x5cm. I also missed to choose color but "grönt är skönt".
                          Guess what confused me most was the statement "It may say another rev. at the orderpage but this is not EasyPCB rev but the rev for manufacturer." causing me to be trigger happy :smile:
                          • EfflonE Efflon
                            sundberg84S
                            sundberg84S
                            @Efflon - sorry to hear you got rev 8 if you wanted rev 9.
                            I wrote this notice just because itead was so slow updating to the right revision! I also spoke to hek about this a month ago according to my chat log.
                              Sorry to hear... Checked the log. The order was for manufacturer revision 4 (which is what @sundberg84 call rev 8 ).
                              The system automatically increments the revision number each time an author makes a new release. Each manufacturer must set price on each revision(which in some cases may take a while if they do this manually). Until they've done that, any older revision where they've set a price is still available for purchase.
                              The revision is stated below the big order-button.
                              • AmputA
                                AmputA
                                Amput
                                wrote on last edited by Amput
                                #266
                                Could anyone explain me, why position (polarity) of condensers 4.7uF on REV 8(blue) and REV 9 (red) are different?
                                ferroF 1 Reply Last reply
                                • AmputA Amput
                                  ferroF
                                  ferroF
                                  ferro
                                  @Amput said in 💬 Easy/Newbie PCB for MySensors:
                                  It's a bug in v8 fixed in v9, so v9 is correct, see link this post
                                  AmputA 1 Reply Last reply
                                  • martinsM
                                    martinsM
                                    martins
                                    @SUNDBERG84 - Do you have a board/design for the RFM69 radio ?
                                    Rergards,
                                    Martin
                                    ferroF sundberg84S 2 Replies Last reply
                                    • martinsM martins
                                      Rergards,
                                      Martin
                                      ferroF
                                      ferroF
                                      ferro
                                      @martins - you can use NRF2RFM69 if you want to use RFM69 with Newbie PCB board. I'm using it too, works fine with 3.3V arduino. For 5V arduino you will need to add level logic converter too.
                                      martinsM 1 Reply Last reply
                                      • ferroF ferro
                                        martinsM
                                        martinsM
                                        martins
                                        @ferro
                                        Pity because that would double the cost of the sensor board:
                                        Order PCBs for Easy/Newbie PCB for MySensors : $15
                                        Order PCBs for NRF2RFM69 : $15
                                        Martin
                                        • ferroF ferro
                                          AmputA
                                          AmputA
                                          Amput
                                          @ferro said in 💬 Easy/Newbie PCB for MySensors:
                                          Thx for answer :-).
