  3. Vera
  4. Well I'm lost
Well I'm lost
33 Posts 6 Posters 14.8k Views 2 Watching
  • 5546dug5
    5546dug5
    5546dug
    I do not see how to upload any of my screen shots to this forum
    Man I feel dumb.
      Upload images by drag-and-drop image in the compose window. Max size 2 Mb or so.
      The plugin version you can download directly from controller pages is the latest (1.4). If you want an older version you have to to to github and select an older tagged version using the "branches"-button.
      Always good to look in the serial console while your arduino is connected to the computer to get a feeling of what is happening inside the little thing.
      • I
        I
        integlikewhoa
        If you can't figure out how to post pics here, post them in the Vera Forum. Has anyone tried to help you there?
        I'm on ui5 so i'm not sure how much help I can be with UI7.
        UI5 was easy to get files installed and loaded and create a new device. I didn't get any startup error. But I did run into my NANO not creating a serial port in Vera so there was no option for me to make the association. Sounds like you might no have even gotten that far if you don't get a serial error.
        Even without the serial connected to the VERA or the sketch on the serial nano. you should still get VERA to take the plugin and not get a start up error. You will how ever get a serial port error.
        So I think your problem is VERA only at this point, having to do with the upload files and new device.
        Post some screen shots so we can confirm tho.
        • 5546dug5
          5546dug5
          5546dug
          ![Screenshot (10).png]Screenshot (11).png (/uploads/upload-41222fba-379a-4ba6-8c15-6c38c59bd00c.png)
          These are two of the screen shots I have the blue bar at the top shows two issues I can't resolve.
          Thanks for the info on how to load screen shots HEK !
          • 5546dug5
            5546dug5
            5546dug
            • greglG
              greglG
              gregl
              @5546dug said:
              his on my veralite ui5, I get the same as in "Lua Startup Failure" thread in this vera section.
              I see Plug in version 1.3 and no lib version. And not able to use the start function as device is not ready.
              My Veralite is located remotely so this is
              Ive not used UI7 serial gateway...but can you see the serial port being detected?
              Goto Apps/Develop Apps/Serial Port Configuration on UI7
              • 5546dug5
                5546dug5
                5546dug
                This is what I get on the serial port config
                • greglG
                  greglG
                  gregl
                  wrote on last edited by gregl
                  Ok thats good...( assuming your serial gw is the only device plugged into Vera) - so you need to now set the "Used by device" field and change it to your "my gateway" device.
                  and then reload Luup.
                  • 5546dug5
                    5546dug5
                    5546dug
                    I don't have a" my gateway" under "Used by Device" but have "My Sensors plug in" as shown in screenshot
                    Selected my sensors from the list and reloaded.
                    Still have a " not detected" looking under the device banner, wrote in red and the vera3 is very fast blinking on the usb port serial gw is connected to.
                    • greglG
                      greglG
                      gregl
                      Ok - that is the correct device.
                      Pull the power from the Vera ( hard restart) and see if it loads the plugin then.
                      • 5546dug5
                        5546dug5
                        5546dug
                        deleted gw from vera and reinstalled new device called it my sensor
                        logged out of vera and back in and was able to get to serial port config and pick "my sensor",
                        this time was able to set the baud to 115200 and then reload luup
                        the blue strip at top then said loading a device I/o and then dissappered.
                        going under device tab I still see in red writing "Cant detect device!" and still in ver 1.3
                        no number under lib ver.
                        after hard start there is no plugin or port config
                        by pulling usb out of vera and replacing it got me back to same spot ( with portconfiged but not detecting device. ) all I have is nano + radio and with serial software uploaded.
                        greglG 1 Reply Last reply
                        • I
                          I
                          integlikewhoa
                          I blame UI7 and have no idea why people use it. So many problems and I haven't found one advantage or UI5 yet.
                          shawn_kyS 1 Reply Last reply
                          • I integlikewhoa
                            shawn_kyS
                            shawn_kyS
                            shawn_ky
                            I bought a new VERA (First one) and it was set to UI7.... I guess the big deal is to get the auto update flag turned off by support and then resetup with UI5. Sounds like support is taking their time. I'll try and see if a chat button magically appears during their working hours and downgrade myself. It works for what I'm using so far, but haven't added the MySensors. Definitely don't want to have to deal with a mess there.
                            @5546dug You can find more info here: http://forum.micasaverde.com/index.php/topic,26766.0.html
                            • 5546dug5 5546dug
                              greglG
                              greglG
                              gregl
                              • Are you using version 1.3 of the plugin AND the mysensors library/sketch you deployed on the arduino NANO?
                              • if you like send the links from where you downloaded the software. Also how long ago did you d/l them? ( as i thought Hek made it quite a clean cutover from 1.3 to 1.4 on the website. But if you used links from micasaverde forum then you may very well have old versions.
                              Any reason why you are using 1.3, and not 1.4 ?
                              • 5546dug5
                                5546dug5
                                5546dug
                                I just used the plugin that is offered on my sensors website.
                                I did not see the files from 1.4 in the drop down list used to create device.
                                The word I was looking for last night was the usb light on the front of vera was fluttering as opposed to rapid blinking.
                                • 5546dug5
                                  5546dug5
                                  5546dug
                                  Well here we go again
                                  now at remote veralite with ui5 running win 8.1
                                  I have deleted all the old "MySensors Plugin" and started new.
                                  Same old thing, I get setup with ver 1.3 and no lib #
                                  I reloaded the files from my sensors vera page using the gitrepo have since bought a gravitech nano .
                                  My files under /users/.../arduino/ show two things not sure about there is file in there called arduino-master with all the libraries under /libraries/. Also there is file MySensors with / all the 1.4 lib version.
                                  Additionally, there is a file arduino/vera-master/ containing all the files from gitrepo but it is coming as ver 1.3
                                  also now after setting new device plugin for nano in ui5 when I go to set the config for serial port under used by device all there is is "MySensors Plugin" which I accepted and saved and up dated.
                                  Tried to reboot the vera and also to reset the nano.
                                  I'm running out of hair to pull!!
                                  • N
                                    N
                                    niccodemi
                                    @5546dug did you download Vera files from this website? There is "Download ZIP" button on the right side. Extract those files and upload one by one to Veralite. After that is done you should have Mysensors plugin under your Devices tab (same as on photo below except Lib version should stay blank until Veralite starts communicating with serial gateway).
                                    • 5546dug5
                                      5546dug5
                                      5546dug
                                      I believe that is what I have done,
                                      I extracted the files and uploaded to veralite and I get version 1.3
                                      Is there a way to delete these lua files on the veralite so to start fresh?
                                      These files were extracted to folder aurduino/vera-master
                                      then up to the vera if I purge 1.3 maybe 1.4 will populate veralte?
                                      • 5546dug5
                                        5546dug5
                                        5546dug
                                        thanks for your time @niccodemi
                                        • N
                                          N
                                          niccodemi
                                          @5546dug Delete Mysensors plugin. You don't have to delete lua files from Vera; just upload new ones (from previous link).
                                          As for deleting files from vera I believe you would have to ssh in vera.
