  3. Double Micro (nano) Ampere meter
54 Posts 9 Posters 21.7k Views 11 Watching
  • A Offline
    A Offline
    AWI
    wrote on last edited by AWI
    A very low current (double) stand alone uA meter to tune MySensors battery nodes..
    0_1493111992919_upload-0091f8f7-8b1a-4d26-8c5d-f66cffe3408c
    I de' MySensor'ized this project because it is more usefull on the workbench for measuring the very low currents of MySensors battery nodes. I own several Ampere meters including the famous µCurrent. Many of these are not accurate enough or need a lot of wiring and additional equipment (µCurrent). I just wanted something simple and stand alone
    Using the low cost HX711 weight scale 24 bit AD converter a sub 10€ cost double µA meter was born. Some characteristics to fit MySensors projects:
    • range channel A: ± 20mA 5½-6½ digit µA
    • range channel B: ±40mA 5½-6½ digit µA
    • burden voltage 1µV/1µA (internal resistance 1Ω)
    • 'patch panel' on the connectors.
    • easy calibration.
    In comparison with the µCurrent and a standard multimeter in uA range
    0_1493113275783_upload-2a33c4be-759a-46c6-af8f-57862ecf4e3c
    The internals:
    0_1493113146906_upload-9152b445-76e8-44e6-8625-530f33a80d20
    Although it cannot compare in accuracy with the µCurrent (in combination with a good multimeter) it is more than useable and accurate to do some serious MySensors tuning.
    If there is some interest I will try to publish a decent built instruction on Openhardware.io.
    S N 2 Replies Last reply
    • A AWI
      • easy calibration.
      The internals:
      @AWI Impressive!
      • H Offline
        H Offline
        Looks great @AWI!
        • K Offline
          K Offline
          korttoma
          I need this! Please publish instructions ;)
          • Tomas
          • D Offline
            DavidZH
            Awsome!
            I'd like to compare your impressive array of measurement devices against my Agilent U1273A. Actually to decide if I need a µCurrent.... Maybe in an upcoming meetup in NL or BE this summer?
            A 1 Reply Last reply
              That looks impressive. I'll be waiting for the instructions too 😀
              • N Offline
                N Offline
                Wow, that looks nice, I'm stucked with my multimeter and couldn't find the parts avaiable for delivery here to build a µcurrent gold.
                Please publish the build instructions !
                (Maybe if you could give use the BOM first, then you'll have plenty of time to publish build instruction before we get delivered ;))
                • D DavidZH
                  Awsome!
                  A Offline
                  A Offline
                  AWI
                  @DavidZH Impressive only by numbers ;-) I am prepared to trade my µCurrent for the Agilent :blush:
                  A meetup sounds good..any specific plans yet?
                  D 1 Reply Last reply
                  • A Offline
                    A Offline
                    AWI
                    There it is Micro (nano) ampere meter (double). I need to add a schematic drawing. Any suggestions/ questions are welcome.
                      Why all those headers are needed?
                      • K Offline
                        K Offline
                        korttoma
                        Parts ordered :D
                        • Tomas
                          A Offline
                          A Offline
                          AWI
                          @gohan As mentioned in the description: I use it as a "patch panel" to distribute the power and ground to different devices. Wiring tends to get messy on my workbench...
                          0_1493190896839_upload-a61c084d-a4db-4964-957e-b3c442ec570e
                          Not mine but similar ;-)
                          S 1 Reply Last reply
                            Oh ok, you use it like an integrated breadboard 😀
                            • A AWI
                              @AWI - did you steal my image on my workbench ;) j/k.
                              We need to revive the old workbench topic again!
                                Are resistor needed with a tight tolerance or else?
                                  A Offline
                                  A Offline
                                  AWI
                                  @gohan No special tolerance resistors needed. The only reason for choosing metal film resistors is that their temperature coefficient is better than carbon types (typical 50ppm/°C compared to 200-500ppm/°C).
                                  As you will be calibrating the circuit you can choose from a large range (0.1 Ohm - 100 Ohm) for the shunt. This will only influence the burden voltage / sensitivity and range (Ohm's laws).
                                  • A AWI
                                    DavidZH
                                    @AWI Lemme think about that..... Uuuuuhm. no... 😈
                                    I have no plans for a meetup. Lacking a proper venue for such a thing. Unfortunately.
                                    • A AWI
                                      • easy calibration.
                                      The internals:
                                      N Offline
                                      N Offline
                                      I'm interested.
                                      N 1 Reply Last reply
                                      • N NeverDie
                                        I'm interested.
                                        N Offline
                                        N Offline
                                        @NeverDie said in Double Micro (nano) Ampere meter:
                                        I'm interested.
                                        In case you haven't seen it, it's here :
                                        https://forum.mysensors.org/topic/6723/micro-nano-ampere-meter-double/5
                                        • N Nca78
                                          I'm interested.
                                          N Offline
                                          N Offline
                                          @Nca78 said in Double Micro (nano) Ampere meter:
                                          I'm interested.
                                          Thanks! It looks a bit complicated to me. I've used one of these breakout boards (https://www.amazon.com/gp/product/B00OPVBEQO/ref=oh_aui_search_detailpage?ie=UTF8&psc=1) as a way to measure 24-bit voltage on capacitors, and it works really well. As you can perhaps tell from the photo:
                                          the chip is fairly simple to use. What I especially liked is that there was already a demo arduino sketch for interfacing with it. That was a real time saver. If I were to build something, I might try that first, if only because it seems like it might be easier (though perhaps, in part, because I'm already comfortable with it). Would using it in conjunction with a sense resistor be all it would take to make an accurate, high resolution current sensor?
                                          A 2 Replies Last reply
                                          12.1k
