  3. Battery voltage calculation for 18650 batteries
2 Posts 2 Posters 1.7k Views 2 Watching
  • solaS
    solaS
    sola
    wrote on last edited by sola
    I have built a Dallas Temperature sensor around a Pro Mini 8Mhz.
    I am powering it with two li-ion 18650 cells connected in series (~8.4V maximum voltage when fully charged, 5.4V minimum voltage before cutoff) and powering the Pro Mini via the RAW port.
    I would like to send the current battery voltage info to the controller. I connected the wiring according to the "Battery Powering" page (1Mohm + 470kohm resistors, the resistor join point also connected to A0). The +V is the RAW port of the arduino (where the battery + is connected)
    The sketch works but seems to report wrong voltages.
    When there is no actual voltage (battery disconnected and arduino powered by the serial programmer), it reports 0.17V.
    When the battery is connected, it should report ~8V (SOC on the li-ion pack) but it reports 3.44V.
    Maybe the example sketch was specifically created for two AA batteries in series?
    My node sketch:
    #define MY_NODE_ID 78
    #include <OneWire.h>
    // Define sensor node childs
    #define CHILD_ID_BATT 1
    #define CHILD_ID_TEMP 0
    #define COMPARE_TEMP 0 // Send temperature only if changed? 1 = Yes 0 = No
    #define ONE_WIRE_BUS 7 // Pin where dallase sensor is connected
    unsigned long SLEEP_TIME = 1000; // Sleep time between reads (in milliseconds)
    // Battery related init
    float oldBatteryV = 0;
    MyMessage msgBatt(CHILD_ID_BATT, V_VOLTAGE);
    // Dallas Temperature related init
    int numSensors=0;
    bool receivedConfig = false;
    bool metric = true;
    void before()
      sensors.begin();
      // needed for battery soc
          analogReference(INTERNAL1V1);
          analogReference(INTERNAL);
         present(i, S_TEMP);
      // get the battery Voltage
      int battSensorValue = analogRead(BATTERY_SENSE_PIN);
      Serial.println(battSensorValue);
      float batteryV  = battSensorValue * 0.003363075;
      Serial.print(batteryV);
      Serial.println(" V");
    //  if (oldBatteryV != batteryV) {
        // Power up radio after sleep
        send(msgBatt.set(batteryV, 2));
        oldBatteryV = batteryV;
      sleep(conversionTime);
        #if COMPARE_TEMP == 1
          send(msgTemp.setSensor(i).set(temperature,1));
      sleep(SLEEP_TIME);
    Any help is appreciated.
    • solaS sola
      My node sketch:
      int numSensors=0;
      bool metric = true;
      void before()
        sensors.begin();
           present(i, S_TEMP);
        sleep(SLEEP_TIME);
      @sola yes, you are correct that the calculation is form2xAA. See the comment inside loop() on the example at https://www.mysensors.org/build/battery for the required calculation, and this part for the voltage divider:
      The ADC is set to use the internal reference value of 1.1V - so Vmax at ADCmax = 1.1*(16+4703)/4703 = 3.44V
      You'll need to change the resistors in the voltage divider to handle voltages as high as 8V.
