  3. Vera Ethernet Gateway uno=wiznet 5100 shield
6 Posts 3 Posters 2.7k Views 1 Watching
  • andyunoA Offline
    andyunoA Offline
    andyuno
    Hi I wonder if anyone could help I read in the instructions that you should be able to use an Arduino uno and wiznet Shield in order to create a gateway, I've downloaded the ethernet gateway program which uploads fine but will not connect to my network, my network doesn't see it at all, tested all the hardware and all the hardware is working fine can anyone help
    Thanks Andy.
    :) Any Help is Appreciated Thank You.
    • YveauxY Offline
      YveauxY Offline
      Do you mean it doesn't connect to your wired ethernet network?
      Did you configure the IP address in the sketch to the subnet of your LAN, and can you ping the gateway from another computer?
      andyunoA 1 Reply Last reply
      • YveauxY Yveaux
        andyunoA Offline
        andyunoA Offline
        andyuno
        posted about 2 hours ago Reputation: 0 | Posts: 4
        Thank you for your reply yes I did mean it doesn't connect to my wired ethernet network, I also change the IP address.
        • andyunoA Offline
          andyunoA Offline
          andyuno
          Great news I've managed to solve this problem myself, :)
          • hekH Offline
            hekH Offline
            And what was the problem :question:
            • andyunoA Offline
              andyunoA Offline
              andyuno
              wrote on last edited by andyuno
              I change this line to
              Ethernet.begin(mac);
              my roots issued an IP address
