  3. [SOLVED] I use serial GW 2.1.1 and my sensor node won't connect
26 Posts 6 Posters 8.1k Views 4 Watching
  • bjacobseB
    bjacobseB
    bjacobse
    I have programmed a Arduino Nano with GW 2.1.1 and my node below is not connecting.
    What I find a bit strange is that my "old" 1.5.4 nodes are connecting to the serial gatewayt and appears in Domoticcz - which I somehow then think I am using old version of gateway version?
    I am using Ubuntu 16.04LTS, Arduino 1.8.5 and Mysensors 2.1.1 according to the library manager.
    My node is an Arduino Pro mini, (as it's a reuse of an old 1.5.4 I have cleared eeprom memory).
    Anyone can help getting further?
    Below is the serial outpout from my node, it seems that it's not find a gateway?
    0 TSM:INIT
    0 TSF:WUR:MS=0
    16 TSM:INIT:TSP OK
    16 TSM:FPAR
    32 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2064 !TSM:FPAR:NO REPLY
    2064 TSM:FPAR
    2080 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4112 !TSM:FPAR:NO REPLY
    4112 TSM:FPAR
    4128 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6160 !TSM:FPAR:NO REPLY
    6160 TSM:FPAR
    6176 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8208 !TSM:FPAR:FAIL
    8208 TSM:FAIL:CNT=1
    8208 TSM:FAIL:PDT
    18235 TSM:FAIL:RE-INIT
    • bjacobseB
      bjacobseB
      bjacobse
      I can answer myself as I found this very useful link
      https://www.mysensors.org/build/parser
      No potential parents replied to find parent request, so I assume the gateway isn't adding the node to the network
      • bjacobseB
        bjacobseB
        bjacobse
        serial output from Gateway
        0;255;3;0;9;TSM:INIT
        0;255;3;0;9;TSF:WUR:MS=0
        0;255;3;0;9;TSM:INIT:TSP OK
        0;255;3;0;9;TSM:INIT:GW MODE
        0;255;0;0;18;2.1.1
        0;255;3;0;9;MCO:BGN:STP
        0;255;3;0;9;TSF:MSG:READ,2-12-0,s=1,c=1,t=13,pt=2,l=2,sg=0:30
        2;1;1;0;13;30
        0;255;3;0;9;!TSF:MSG:LEN,0!=9
        0;255;3;0;9;TSF:MSG:READ,12-12-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        0;255;3;0;9;TSF:MSG:BC
        0;255;3;0;9;TSF:MSG:FPAR REQ,ID=12
        0;255;3;0;9;TSF:PNG:SEND,TO=0
        0;255;3;0;9;TSF:CKU:OK
        0;255;3;0;9;TSF:MSG:GWL OK
        0;255;3;0;9;!TSF:MSG:SEND,0-0-12-12,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
        • bjacobseB
          bjacobseB
          bjacobse
          I just wonder why the gateway isn't accepting and providing a node number to the node?
            GW doesn't provide id to nodes, so in this case you need to use static id.
            in case it still don't work, perhaps try a cleareeprom, or dev branch.
            Else it's maybe on hardware side. We ran a few intensive tests with a dozen of nodes yesterday, and it was looking good here but that wasn't the same config (not same mcus, but i had two nrf24 in the equation, plus some others different radios).
            If you can't get it working, could you also upload your sketch please?
            bjacobseB 1 Reply Last reply
            • bjacobseB
              bjacobseB
              bjacobse
              I only used the template for binary sensor, and added voltage measurement.
              I thought that the node gets an id from gateway? in the "old" 1.5.4 I didn't do anything special to assign node id. I was sure that nodes automatically gets assigned an node id form gateway?
              my sketch below:
              #define SKETCH_NAME "Valdemar Binary Sensor"
              #define SKETCH_MAJOR_VER "1"
              #define SKETCH_MINOR_VER "0"
              #define PRIMARY_CHILD_ID 3
              #define SECONDARY_CHILD_ID 4
              int oldBatteryPcnt = 0;
              	// Setup the buttons
              	// Activate internal pull-ups
                  analogReference(INTERNAL1V1);
                  analogReference(INTERNAL);
              	present(SECONDARY_CHILD_ID, S_DOOR);
              	uint8_t value;
              	static uint8_t sentValue=2;
              	static uint8_t sentValue2=2;
              	sleep(5);
              	if (value != sentValue) {
              		send(msg.set(value==HIGH));
              		sentValue = value;
              	if (value != sentValue2) {
              		send(msg2.set(value==HIGH));
              		sentValue2 = value;
                  // get the battery Voltage
                #ifdef MY_DEBUG
                  Serial.println(sensorValue);
                #ifdef MY_DEBUG
                  Serial.print(batteryV);
                  Serial.println(" V");
                  Serial.print(batteryPcnt);
                  Serial.println(" %");
                      oldBatteryPcnt = batteryPcnt;
              	sleep(PRIMARY_BUTTON_PIN-2, CHANGE, SECONDARY_BUTTON_PIN-2, CHANGE, 0);
              • scalzS scalz
                bjacobseB
                bjacobseB
                bjacobse
                @scalz
                so it might be my Domoticz controller that won't provide a id to the sensor?
                I have tried in Domoticz to "allow new sensors for 5 min" but the sensor wont get an id...
                • bjacobseB bjacobse
                  @scalz
                  zboblamontZ
                  zboblamontZ
                  zboblamont
                  @bjacobse I may be completely off the beam here as have not read through it all, and still new at all this, but... Have you enabled "#define MY_INCLUSION_MODE_FEATURE" on the Gateway?
                  I read somewhere that this is needed for Domoticz after I could not get a Node to similarly connect.
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @bjacobse
                    What does the log in domoticz tell you, when you power up gateway / nodes?
                    "old" nodes (pre 2.1'ish) should be able to communicate with a new gateway (2.1), while the opposite is not true (new nodes running 2.1 is not able to connect to an old 1.5 gateway)
                    Anyways, check logs on both ends (node, and gateway) to see if there is anything suspicious there..
                    • zboblamontZ zboblamont
                      bjacobseB
                      bjacobseB
                      bjacobse
                      @zboblamont
                      I used the "original sketch and only updated the #define MY_RF24_PA_LEVEL RF24_PA_MAX
                      * LEDs (OPTIONAL):
                      * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
                      // RF24_PA_MIN RF24_PA_LOW RF24_PA_HIGH RF24_PA_MAX
                      // Enable serial gateway
                      #define MY_GATEWAY_SERIAL
                      #if F_CPU == 8000000L
                      #define MY_BAUD_RATE 38400
                      // Enable inclusion mode
                      // Set blinking period
                      // Flash leds on rx/tx/err
                      • tbowmoT tbowmo
                        @bjacobse
                        bjacobseB
                        bjacobseB
                        bjacobse
                        @tbowmo
                        Thank you for the input
                        the Domotics log:
                        2017-11-14 20:42:04.586 MySensors: Using serial port: /dev/ttyUSB-mysensor
                        2017-11-14 20:42:06.075 MySensors: Gateway Ready...
                        2017-11-14 20:42:06.150 MySensors: Gateway Version: 2.1.1
                        I am not sure how I also get debug/serial info out from the gateway meanwhile it's connected to the RPI that is running the Domoticz server, I will check the forum posts, as I haven't thought of this
                          @zboblamont
                          * LEDs (OPTIONAL):
                          zboblamontZ
                          zboblamontZ
                          zboblamont
                          @bjacobse Ok, not experienced enough to offer any further suggestions as still fumbling my own way,...
                          In my own setup it is standardised on RFM69 radio modules, and the Nework ID is defined at the Gateway and Node, the Node ID is defined at the Node.
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @bjacobse
                            As a start, you could shut down the domoticz instance, and connect a terminal program directly to your serial port instead. Then power cycle a few nodes, while recording the output from the gateway.
                            at the same time, if you could capture the serial output from the power up sequence / first transmission of one of the nodes.
                            • tbowmoT tbowmo
                              @bjacobse
                              bjacobseB
                              bjacobseB
                              bjacobse
                              @tbowmo
                              Thank you Thomas for good ideas :-) I will try this when I get time within a few days
                              • bjacobseB
                                bjacobseB
                                bjacobse
                                Gateway startup
                                0;255;0;0;18;2.1.1
                                • bjacobseB
                                  bjacobseB
                                  bjacobse
                                  Finally I got it, as I have used same hw configuration for ver1.5.4 as for ver 2.1.1 I did not expect any power issues...
                                  a hint for debugging in consol mode linux then use screen
                                  apt-get install screen
                                  then use like this, note that I use udev to always get Domoticz to use correct ttyUSBx, as I have several USB devices attached attached
                                  sudo screen /dev/ttyUSB-mysensor 115200
                                  to kill screen CTRL-a then k and y for confirm
                                  Then I realised that if I use gateway sketch un-modified it is working, and Domoticz is providing node id, (If Domotics is set to allow new sensors, in settings)
                                  So when I change on the PA_LEVEL_HIGH or PA_LEVEL_MAX and use more power consumption, apparently the gateway isn't working. I do have a amplified PA RF24L01 moduleboard.
                                  It's working when set as default PA_LEVEL_LOW
                                  //#define MY_RF24_PA_LEVEL RF24_PA_MAX
                                  I might have to look into a power USB hub ;-)
                                  Thank you guys for providing input to solve my issue
                                    mckvack
                                    I too had problems with my GW resetting.
                                    I use custom designed PCBs with Atmega328p-au using the internal oscillator. With some nodes the GW will reset when I turn them on. Sometimes changing to another NRF-module solved it but this time none of my NRF-modules worked so I searched and found this thread. Flashed the GW with v2.2.0-rc.2 and now all my problems are gone.
                                      Mario64
                                      I've got across similar problem. What works for you doesn't solve problem in my case.
                                      Decreasing power to PA_LEVEL_LOW or switching to MySensors v2.2.0-rc.2 gives no positive result.
                                      I have some experience with Arduino, but it is my first try with MySensors and Domoticz.
                                      If someone could advice how to cope with, thank you in advance.
                                      My Hardware:
                                      Arduino Nano, NRF21+ for GW & Node,
                                      the node is simple actuator: relay with button.
                                      GW output on Serial monitor:
                                      0;255;0;0;18;2.1.1
                                      Node output on Serial Monitor:
                                      0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.1.1
                                      3 TSM:INIT
                                      4 TSF:WUR:MS=0
                                      11 TSM:INIT:TSP OK
                                      13 TSM:FPAR
                                      15 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      2023 !TSM:FPAR:NO REPLY
                                      2025 TSM:FPAR
                                      2027 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      4035 !TSM:FPAR:NO REPLY
                                      4037 TSM:FPAR
                                      4039 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      6047 !TSM:FPAR:NO REPLY
                                      6049 TSM:FPAR
                                      6051 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      8060 !TSM:FPAR:FAIL
                                      8061 TSM:FAIL:CNT=1
                                      8064 TSM:FAIL:PDT
                                      18067 TSM:FAIL:RE-INIT
                                      18069 TSM:INIT
                                      18076 TSM:INIT:TSP OK
                                      18078 TSM:FPAR
                                      18080 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      20088 !TSM:FPAR:NO REPLY
                                      20090 TSM:FPAR
                                      20092 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      22102 !TSM:FPAR:NO REPLY
                                      22104 TSM:FPAR
                                      22106 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      24114 !TSM:FPAR:NO REPLY
                                      24116 TSM:FPAR
                                      24118 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      26126 !TSM:FPAR:FAIL
                                      26127 TSM:FAIL:CNT=2
                                      26129 TSM:FAIL:PDT
                                      etc...
                                      Scratches:
                                      //Gateway
                                      #define MY_INCLUSION_MODE_DURATION 120
                                      Node:
                                      #define MY_REPEATER_FEATURE
                                      #include <MyConfig.h>
                                      #define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
                                      #define BUTTON_PIN  5  // Arduino Digital I/O pin number for button
                                      #define CHILD_ID 10   // Id of the sensor (child)
                                      #define RELAY_ON 1
                                      #define RELAY_OFF 0
                                      Bounce debouncer = Bounce();
                                      int oldValue=0;
                                      bool state;
                                        // Setup the button
                                        pinMode(BUTTON_PIN,INPUT);
                                        // Setup debouncer
                                        debouncer.attach(BUTTON_PIN);
                                        debouncer.interval(5);
                                        // set relay on when starting up
                                        pinMode(RELAY_PIN, OUTPUT);
                                        state=true;
                                        digitalWrite(RELAY_PIN, RELAY_ON);
                                      void presentation()  {
                                        present(CHILD_ID, S_LIGHT);
                                        debouncer.update();
                                        // Get the update value
                                        int value = debouncer.read();
                                        if (value != oldValue && value==0) {
                                            send(msg.set(state?false:true), true); // Send new state and request ack back
                                            Serial.println("zmiana value na 0");
                                            // Change relay state localy, anyway
                                            state = !state;
                                            Serial.print("state = ");
                                            Serial.println(state);
                                        oldValue = value;
                                        if (message.isAck()) {
                                           state = message.getBool();
                                      • M Mario64
                                        My Hardware:
                                        0;255;0;0;18;2.1.1
                                        3 TSM:INIT
                                        4 TSF:WUR:MS=0
                                        11 TSM:INIT:TSP OK
                                        13 TSM:FPAR
                                        2025 TSM:FPAR
                                        4037 TSM:FPAR
                                        6049 TSM:FPAR
                                        8060 !TSM:FPAR:FAIL
                                        8061 TSM:FAIL:CNT=1
                                        8064 TSM:FAIL:PDT
                                        18069 TSM:INIT
                                        18078 TSM:FPAR
                                        20090 TSM:FPAR
                                        22104 TSM:FPAR
                                        24116 TSM:FPAR
                                        26129 TSM:FAIL:PDT
                                        etc...
                                        Scratches:
                                        //Gateway
                                        Node:
                                        #define RELAY_ON 1
                                        #define RELAY_OFF 0
                                        int oldValue=0;
                                        bool state;
                                          // Setup the button
                                          // Setup debouncer
                                          state=true;
                                          debouncer.update();
                                              state = !state;
                                          oldValue = value;
                                        bjacobseB
                                        bjacobseB
                                        bjacobse
                                        @mario64
                                        Which home automation system are you using?
                                        If using domoticz, then it's vital to accept new sensors, you find it setup->settings
                                        Hardware/Devices:
                                        Accept new Hardware Devices
                                        if this is disabled, no sensors are allowed to be created
                                          @mario64
                                          Hardware/Devices:
                                          Mario64
                                          wrote on last edited by Mario64
                                          Hi @bjacobse,
                                          thank you for answer. I'm back to my project after e few days.
                                          Actually, the "Accept new Hardware Devices" switch is on. I also used the "Alow for 5 minutes" button. Let me share more details:
                                          • pls find log of Domoticz:
                                           2018-01-22 09:55:34.871 MySensors: retrying in 30 seconds...
                                          2018-01-22 09:56:00.874 MySensors: Serial Worker stopped...
                                          2018-01-22 09:56:11.130 New sensors allowed for 5 minutes...
                                          2018-01-22 09:56:43.077 MySensors: Using serial port: /dev/ttyUSB0
                                          2018-01-22 10:02:38.123 MySensors: Serial Worker stopped...
                                          2018-01-22 10:02:39.134 MySensors: Using serial port: /dev/ttyUSB0
                                          2018-01-22 10:03:38.156 New sensors allowed for 5 minutes...
                                          2018-01-22 10:04:00.048 Error: Gwx hardware (2) nothing received for more than 1 Minute!....
                                          2018-01-22 10:04:01.049 Error: Restarting: Gwx
                                          2018-01-22 10:04:01.146 MySensors: Serial Worker stopped...
                                          2018-01-22 10:04:02.157 MySensors: Using serial port: /dev/ttyUSB0
                                          2018-01-22 10:05:30.219 Error: Gwx hardware (2) nothing received for more than 1 Minute!....
                                          2018-01-22 10:05:31.220 Error: Restarting: Gwx
                                          2018-01-22 10:05:32.170 MySensors: Serial Worker stopped...
                                          2018-01-22 10:05:33.181 MySensors: Using serial port: /dev/ttyUSB0
                                          2018-01-22 10:07:00.204 Error: Gwx hardware (2) nothing received for more than 1 Minute!....
                                          etc
                                          • screen shots:
                                          • list itemSetup->Hardware:
                                            ![Gateway settings]https://drive.google.com/file/d/1NjJZMlaM98XaZ-UCY93pyeHcKbT7ZZoh/view?usp=sharing
                                          • list itemSetup->Hardware Gwx setup:
                                            ![Gwx Setup]https://drive.google.com/file/d/1vDVDcLGaGK_g3-uYQrl_DnlHlbvjq87Z/view?usp=sharing
                                          • list itemSetup->Settings:
                                            ![Domoticz Settings]https://drive.google.com/file/d/15bkfnHx6rEcqRnTvLVOydwPK63dy83xe/view?usp=sharing
