  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 2.1m Views 44 Watching
  • Nca78N Nca78
    @nca78 said in nRF5 Bluetooth action!:
    @NeverDie I have tried the sketch nearly unchanged (only changed to lines because I use pin P0.01 so AIN2) and my current consumption is a bit over 30uA, do you have any idea of what I should check ? (I tried with both versions 0.1 and 0.3 of MySensors NRF5 boards).
    At the moment my board only has a led and a DRV5032FB (<<1uA) in addition to the nrf51 module.
    Ok, case closed, it was just because the SWD pins were still connected to my NRF52 DK. When I just connect VCC and GND it's down to something a bit below 5uA. I'm using a multimeter and DK is at 2.8V so real consumption will be a bit higher. But it should give me a battery life around 1year for my bedroom doors, so I'll just use my nrf51 modules for that and move to the more interesting nrf52.
    korttomaK
    korttomaK
    korttoma
    @nca78 would you mind sharing your sketch files for your door sensors?
    As I'm not a programmer and not so good at programing I usually rely on example code to get anything done. More examples gives me more understanding how things should be done.
    • Tomas
    Nca78N 1 Reply Last reply
    • korttomaK korttoma
      @korttoma sure I will when I make them next week, I just tested with LFCOMP script from neverdie at the moment.
        @toyman I guess I made an error then. Thanks for pointing that out. In general, I haven't gotten much feedback on the PCB's that I've posted, so any feedback is always appreciated. :)
        #1481
        @neverdie said in nRF5 Bluetooth action!:
        I actually think you were correct in your design, @NeverDie ;-)
        A while ago part of the e73-2g4m04s schematic was posted on this forum:
        Clearly the inductors to use the DC/DC converter are not connected to DCC. There is however a capacitor C17 from DEC4 to GND.
        The Nordic reference schematic shows the missing L2 and L3, but capacitor C10 is actually present in the e73-2g4m04s (the mentioned C17, albeit only 100nF instead of 1.0uF in the reference):
        Therefore I think your breakout is correct, as only the inductors between DCC and DEC4 need to be added to match the reference schematic :+1:
        • YveauxY Yveaux
          @yveaux :)
            @Mika what is your experience regarding battery consumption on these?
            LINK
            I put together a sketch witch seems to work fine but one CR2032 just lasts a couple of days.
            Sketch:
            // Define a static node address, remove if you want auto address assignment
            //#define MY_NODE_ID 26                                                          // Kök
            #define MY_NODE_ID 27                                                          // Test device
            #define MY_RADIO_NRF5_ESB
            #define SN "NRF5 Scene"
            #define SV "1.0"
            #define CHILD_ID_SCENE 1
            // PIN for the buttons
            byte buttonOne = 28;
            //Bounce debouncer[NUMBUTTONS];
            int buttonOneoldValue;
            // Pin definitions
            #define DIGITAL_INPUT_INT 28   // The digital input you attached your interrupt  (Only 2 and 3 generates interrupt!)
            // Sensor messages
            MyMessage msgOn(CHILD_ID_SCENE, V_SCENE_ON);
            // Global settings
            uint16_t SceneOne = 0;
            uint16_t SceneTwo = 1;
            void blinkityBlink(uint8_t repetitions) {
                wait(20);
                wait(100);
                wait(20);
                if (x<(repetitions-1)) {  //skip waiting at the end of the final repetition
                  wait(500);
             * Setup code
              blinkityBlink(2);  //signify power-up and start of operations
              hwPinMode(DIGITAL_INPUT_INT, INPUT_PULLUP);
                /// Make input & enable pull-up resistors on switch pins
              hwPinMode(buttonOne, INPUT_PULLUP);
              buttonOneoldValue = -1;
              sendBattLevel();
            void presentation()  {
              sendSketchInfo(SN, SV);
              //present the scene controller to gateway
              wait(10);
              present(CHILD_ID_SCENE, S_SCENE_CONTROLLER);
              wait(10);
             *  Main loop function
              // Check for button activity
              int value = digitalRead(buttonOne);
              if (value != buttonOneoldValue)
                  // Send in the new value
                  if (value == LOW)
                    send(msgOn.set(SceneOne));
                    wait(20);
                    send(msgOn.set(SceneTwo));
                    sendBattLevel();
                  buttonOneoldValue = value;
              sleep(digitalPinToInterrupt(DIGITAL_INPUT_INT), CHANGE, 0);
             * Parameters
            void sendBattLevel()
                long vcc = hwCPUVoltage();
                // Calculate percentage
                vcc = vcc - 1800; // subtract 1.9V from vcc, as this is the lowest voltage we will operate at
                long percent = vcc / 14.0;
                sendBatteryLevel(percent);
            I noticed that the chip sais:
            N51822
            QFABC0
            1646UU
            QFAB translates to 16kB RAM, 128kB flash and I can not even select this option in the arduino IDE. Can this be the problem?
            @d00616 refer to his document for some high current consumption issue but I'm not sure what to do with the info.
            Is there something wrong with my sketch or is there just an old crappy chip on the device??
            @korttoma said in nRF5 Bluetooth action!:
            LINK
            N51822
            QFABC0
            1646UU
            So I tried your code with a more recent version of the chip and I have a power consumption around 1mA.
            This is not surprising because in fact issue 39 seems to not be completely fixed, if I believe this link:
            https://devzone.nordicsemi.com/f/nordic-q-a/577/current-consumption-when-using-rtc-ppi-and-gpiote#post-id-18533
            "The third revision hardware of the nRF51 has a solution for the GPIOTE OUT tasks, which has very low current consumption (<1uA). The third revision nRF51 hardware will be released in a few days. The third revision hardware still does not have a solution for the GPIOTE IN events, they still consume high current, so for low current applications, use the GPIOTE PORT event instead or the app_button libary."
            From what I see it was never fixed.
            korttomaK Nca78N 2 Replies Last reply
              I'm seeing a special offer for this at 2€ with coupon https://www.aliexpress.com/item/nRF52832-2-4GHz-Wireless-rf-Module-CDSENET-E73-2G4M04S-SPI-SMD-rf-Receiver-transmitter-Bluetooth-Module/32819293925.html
              Should i go ahead?
              NeverDieN O 2 Replies Last reply
                Should i go ahead?
                @gohan Gee, I don't know. Can you really afford $2.55? ;)
                  I don't know if it is a good one and I already have a bunch of stuff I bought still in the drawer :sweat_smile:
                    @gohan For the price, it's good. I like Fanstel's better, but they have fewer exposed pins and cost more.
                    • Nca78N Nca78
                      LINK
                      N51822
                      QFABC0
                      1646UU
                      korttomaK
                      korttomaK
                      korttoma
                      Thanks again for pointing out a possible solution but again I do not know how. I will just have to be patient and wait for someone to post an example of how to use one of the methods you mentioned.
                      • Tomas
                        smilvert
                        I have started to test a NRF51822
                        and I can upload to it with Arduino IDE but I want to use vim + platformio. And I think i'm quite close :)
                        When I ran platformio upload --target upload
                        GNU MCU Eclipse 64-bits Open On-Chip Debugger 0.10.0+dev-00392-gbe9ef0b0 (2018-01-12-14:56)
                        Licensed under GNU GPL v2
                        For bug reports, read
                        0x4000
                        adapter speed: 1000 kHz
                        Info : Unable to match requested speed 1000 kHz, using 950 kHz
                        Info : clock speed 950 kHz
                        Info : using stlink api v2
                        Info : Target voltage: 3.225841
                        Info : nrf51.cpu: hardware has 4 breakpoints, 2 watchpoints
                        Info : Listening on port 3333 for gdb connections
                        xPSR: 0xc1000000 pc: 0x000021a4 msp: 0x20004000
                        ** Programming Started **
                        auto erase enabled
                        Warn : Unknown device (HWID 0x000000d1)
                        Warn : using fast async flash loader. This is currently supported
                        Warn : only with ST-Link and CMSIS-DAP. If you have issues, add
                        Warn : "set WORKAREASIZE 0" before sourcing nrf51.cfg/nrf52.cfg to disable it
                        target halted due to breakpoint, current mode: Thread
                        xPSR: 0x61000000 pc: 0x2000001e msp: 0x20004000
                        wrote 33792 bytes from file .pioenvs/nrf51_dk/firmware.hex in 1.594509s (20.696 KiB/s)
                        ** Programming Finished **
                        ** Verify Started **
                        xPSR: 0x61000000 pc: 0x2000002e msp: 0x20004000
                        verified 32960 bytes in 0.236646s (136.015 KiB/s)
                        ** Verified OK **
                        ** Resetting Target **
                        shutdown command invoked
                        and the output in Arduino IDE looks like:
                        Open On-Chip Debugger 0.10.0-dev-00254-g696fc0a (2016-04-09-12:07)
                        debug_level: 0
                        0x4000
                        nrf51.cpu: target state: halted
                        xPSR: 0xc1000000 pc: 0x0000251c msp: 0x20004000
                        auto erase enabled
                        wrote 31744 bytes from file /tmp/arduino_build_390477/Si7021_TemperatureNode_v007_voltage__version_7_board_.ino.hex in 1.500105s (20.665 KiB/s)
                        verified 31580 bytes in 0.234860s (131.312 KiB/s)
                        ** Verified OK **
                        and my platfromio.ini looks like:
                        [env:nrf51_dk]
                        platform = nordicnrf51
                        framework = arduino
                        board = nrf51_dk
                        upload_protocol = stlink
                        Should I modify the nrf51_dk.cfg or can anyone see whats the problem is?
                          What interface do you guys suggest for programming the nrf52832?
                            I'm trying to implement it right now, not really useful for me as I will only have one beacon board for which I will need it, but it's a good occasion to learn. I'll post my results here, but probably next week as I'll have short holidays :)
                            korttomaK 1 Reply Last reply
                            • Nca78N Nca78
                              korttomaK
                              korttomaK
                              korttoma
                              @nca78 :+1: no hurry ;)
                              • Tomas
                                Toyman
                                @gohan you mean programmer? Nothing beats DK with jlink.
                                Other options: jlink EDU, DIY BlackMagicProbe or STLink
                                  ok, I bought 2 of the nrf52 at half the price, now what would be the cheap solution among the programmers? Jlink is on the pricy side.
                                    @gohan said in nRF5 Bluetooth action!:
                                    Cheap jlink clones with 4 wires from AliExpress/Ebay seem to work. So does the ST-Link v2 which is probably the cheapest option.
                                      I got kind of lost with all those jlink clones with so many different versions. The ST-Link V2 I found it on digikey and similar sites for around 18/19€, is it the right one?
                                      O T 2 Replies Last reply
                                        O
                                        O
                                        Omemanti
                                        @gohan I use both the ST-LinkV2 (2 dollars from eBay) and the NRF52832-DK both work like a charm.
                                          Should i go ahead?
                                          O
                                          O
                                          Omemanti
                                          @gohan LOL, i need to stop buying these things, got 12 just waiting to be used.. but at this price, its almost impossible to not buy them :)
