1.1k Posts 105 Posters 758.7k Views 98 Watching
  • Nca78N Nca78
    I printed a small box and put my first "22" board in action on my entrance door. So far so good it's reporting the status reliably, and looking really tiny. A big difference with my first sensor 2 years ago in a big generic project box.
    Just need to clean the glue left from previous sensor now :)
    dakipro
    @nca78 said in What did you build today (Pictures) ?:
    "22" board
    Looks great, can we get more info about it/link?
    Nca78N 1 Reply Last reply
    • mfalkviddM
      I've continued my quest to get all MySensors defines documented, by creating some pull requests
      https://github.com/mysensors/MySensors/pull/1111
      https://github.com/mysensors/MySensors/pull/1108
      https://github.com/mysensors/MySensors/pull/1106
      https://github.com/mysensors/MySensors/pull/1105
      The only keywords left new are ones that I don't understand good enough to document. These are tracked in
      https://github.com/mysensors/MySensors/issues/1107 and https://github.com/mysensors/MySensors/issues/1090
      • mfalkviddM
        #491
        I also added buy links for a shielded PA+LNA module and a more reliable source for regular nrf24l01+, on request by @gohan who managed to dig up good Aliexpress buying sources. Thanks gohan!
        The buying links are available at https://www.mysensors.org/build/connect_radio and https://www.mysensors.org/store/radio
        • D dakipro
          "22" board
          @dakipro said in What did you build today (Pictures) ?:
          Not really, I posted about it long ago here (https://forum.mysensors.org/topic/7836/what-did-you-build-today-pictures/136) It's just made for me to play by making a sensor as small as possible, but it's pretty hard to solder and with CR1632 and nrf22 the battery life won't be that good (around 1 year) so I don't think I'll publish it.
          • sundberg84S
            sundberg84S
            These arrived today...
            New gateway and nodes with signing is first on my list.
            • ThucarT
              ThucarT
              Thucar
              Built half of my dutch bucket system. Namely the drain part. Irrigation to follow.
              0_1523760716315_P4141131_v1.JPG 0_1523760724731_P4141133_v1.JPG 0_1523760736892_P4141140_v1.JPG 0_1523760744189_P4141141_v1.JPG
              Controller: Node-Red
              Gateway: SerialGateway & GSMMQTTGateway
              MySensors: 2.2.0
              • dbemowskD
                dbemowskD
                Working on setting up a new work bench in my back room in my basement where my HA equipment rack is. I wanted to build a case for my serial nRF24L01-PA-LNA gateway built on a rev8 Easy Newbie board. I just had the board sitting on a shelf on my rack, and now I want to mount it on my MDF board with all of my other equipment. Here is the design that I came up with for the case.
                This is the inside bottom of the case:
                And here is inside the top of the case:
                It has a spot for 3 - 5mm LEDs for the transmit, receive and error lights. There is a hole on the right side of the case for the PA-LNA antenna connector. The oval hole on the lower right side of the case is for the DC in jack. I had one of these in my parts bin:
                The hole on the bottom right is for the FTDI adapter connection. I am using one of these adapters that has a mini-USB connector:
                I have the case running on the printer now. I will post pics when it is done.
                YveauxY dbemowskD 2 Replies Last reply
                • dbemowskD dbemowsk
                  @dbemowsk very impressed by your openscad designs, as always :+1:
                  • dbemowskD
                    dbemowskD
                    #497
                    For anyone interested, here is an OpenSCAD rendering of the MySensors logo:
                    I tried posting the OpenScad code for this, but it is too long to add to a normal post. So here is a link to the OpenSCAD file.
                    MySensors_logo.scad
                    Special thanks to @hek for giving me the .svg file that allowed me to create this. I would be curious to see peoples uses for this.
                      dbemowskD
                      dbemowskD
                      So I tried printing the cover for this with my original design using Cura as my slicer, and I couldn't get the logo to print right, plus the text under the LEDs was a bit too small. I then modified the design a bit and made the logo and text a bit bigger. I again tried printing it using Cura, but the logo still was missing some lines in the body. I then thought that part of the problem was the slicer I was using, so I tried it using Slic3r and I have to say, the logo came out MUCH better.
                      I ended up losing the Y in "My" Sensors and the ending "t" in "Transmit", but I am going to use the case the way I currently have it. Now I just have to assemble the new gateway. I am planning on making a whole new gateway and trying out the new 2.2.0 library. Hopefully my older 2.0.0 nodes will not have any issues with it, but that is why I plan on keeping my pro mini from my 2.0.0 gateway so I can revert back to that if I have to.
                      • D
                        dakipro
                        Built case for soldering tools, to easily move them out of the way.
                        Not really, bought it on banggood and asked wife to assemble it (she likes those type of projects, especially if the office might look a tiny bit cleaner) https://www.banggood.com/DIY-Self-assemble-RC-Model-Tools-Case-Screwdriver-Box-Gripper-Package-Plier-Stand-Retro-Style-p-1257252.html?cur_warehouse=CN
                        Laser cut plywood(or something), looks quite nice I think. I will order few more when they appear in stock.
                        • GertSandersG
                          GertSandersG
                          GertSanders
                          So here is my contribution to this tread: a differential drive "brain". A work in progress:
                          • dbemowskD
                            dbemowskD
                            Finally finished my 2.2.0 gateway and have it mounted in the new enclosure. It appears to be talking to my 2.0.0 sensors just fine.!
                            dbemowskD 1 Reply Last reply
                            • sundberg84S
                              sundberg84S
                              Another motion and led strip node.
                              • sundberg84S
                                sundberg84S
                                ...and deployed.
                                hekH nagelcN 2 Replies Last reply
                                • sundberg84S sundberg84
                                  ...and deployed.
                                  @sundberg84
                                  Nice, maybe add a diffuser? I've found that greaseproof paper (smörpapper in Swedish) works pretty well.
                                  • GertSandersG GertSanders
                                    @gertsanders what is that?
                                      ...and deployed.
                                      nagelcN
                                      nagelcN
                                      nagelc
                                      @sundberg84 Nice. I was wondering if I had an use for these. Now I want them everywhere!
                                      • nagelcN nagelc
                                        sundberg84S
                                        sundberg84S
                                        @nagelc - easy to hide, looks good and awsome as night-lights for the kids. Its also a bit woav factor connecting them to a motion detector so they lights up when someone walks by.
                                        • bjacobseB
                                          bjacobseB
                                          bjacobse
                                          #508
                                          Bathroom controller. It consist of a relaybox with a HLK 5v power source, it's hidden in the closet. Then I have realy to light, nightlight, mirrorheat, and extraction fan
                                          And then the controller it self it's a Wemos D1 Mini Pro, Si7021 Temp/Hum, sensor and a PIR HC-SR501
                                          3D file is created with Freecad, STL files are available here:
                                          https://www.thingiverse.com/thing:2890456
                                          dbemowskD gohanG 2 Replies Last reply
